²úÆ·Ãû³Æ£º
leutronÖÇÄÜÏà»ú---PicSight-Smart
ÐÍ ºÅ£º
Smart GigEϵÁÐ
Product Name |
Sensor Size |
Sensor Techn. |
Resolution |
Frames per Sec |
Shutter |
Color |
PicSight G32B-Smart502-AS |
1/2 |
CMOS |
659 x 494 |
196 |
global |
color |
PicSight G32M-Smart502-AS |
1/2 |
CMOS |
659 x 494 |
196 |
global |
monochrome |
PicSight G43AB-Smart502-AS |
1/3 |
CMOS |
752 x 480 |
64 |
global |
color |
PicSight G43AM-Smart502-AS |
1/3 |
CMOS |
752 x 480 |
64 |
global |
monochrome |
PicSight P133B-Smart502-AS |
1/2.7 |
CCD |
1300 x 968 |
9 |
global |
color |
PicSight P141B-Smart502-AS |
2/3 |
CCD |
1360 x 1024 |
20 |
global |
color |
PicSight P141M-Smart502-AS |
2/3 |
CCD |
1360 x 1024 |
20 |
global |
monochrome |
PicSight P142AB-Smart502-AS |
1/2 |
CCD |
1360 x 1024 |
15 |
global |
color |
PicSight P142AM-Smart502-AS |
1/2 |
CCD |
1360 x 1024 |
15 |
global |
monochrome |
PicSight P202B-Smart502-AS |
1/1.8 |
CCD |
1624 x 1236 |
14 |
global |
color |
PicSight P202M-Smart502-AS |
1/1.8 |
CCD |
1624 x 1236 |
14 |
global |
monochrome |
PicSight P203B-Smart502-AS |
1/2.7 |
CCD |
1640 x 1232 |
9 |
global |
color |
PicSight P32B-Smart502-AS |
1/2 |
CCD |
659 x 494 |
62 |
global |
color |
PicSight P32M-Smart502-AS |
1/2 |
CCD |
659 x 494 |
62 |
global |
monochrome |
PicSight P33B-Smart502-AS |
1/3 |
CCD |
659 x 494 |
62 |
global |
color |
PicSight P33M-Smart502-AS |
1/3 |
CCD |
659 x 494 |
62 |
global |
monochrome |
PicSight P34B-Smart502-AS |
1/4 |
CCD |
659 x 494 |
64 |
global |
color |
PicSight P34M-Smart502-AS |
1/4 |
CCD |
659 x 494 |
64 |
global |
monochrome |
PicSight P52B-Smart502-AS |
1/2 |
CCD |
782 x 582 |
63 |
global |
color |
PicSight P52M-Smart502-AS |
1/2 |
CCD |
782 x 582 |
63 |
global |
monochrome |
PicSight P83B-Smart502-AS |
1/3 |
CCD |
1024 x 768 |
32 |
global |
color |
PicSight P83M-Smart502-AS |
1/3 |
CCD |
1024 x 768 |
32 |
global |
monochrome |
PicSight R132M-Smart502-AS |
1/2 |
CMOS |
1280 x 1024 |
30 |
rolling |
monochrom |
PicSight R312AB-Smart502-AS |
1/2 |
CMOS |
2048 x 1536 |
12 |
rolling |
color |
PicSight R502B-Smart502-AS |
1/2.5 |
CMOS |
2592 x 1944 |
10 |
rolling |
color |
PicSight R502M-Smart502-AS |
1/2.5 |
CMOS |
2592 x 1944 |
10 |
rolling |
color |
Sensors: |
CCD and CMOS, 8, 10, 12 bit |
Resolutions: |
VGA up to 5 Mpixel |
Color: |
monochrome or color with Bayer pattern on sensor |
Lens mount: |
C-mount or CS-mount (option) |
Optical filters: |
IR-cut filter is built-in as standard, others as option (see list) |
Interface: |
GigEVision, 10/100/1000 Mbit |
Processor: |
32Bit RISC CPU |
Operating System: |
NXP real time operating system |
DDR-Memory: |
128MB |
Storage: |
32MB flash memory |
Lens controller: |
3 channel, 10-26VDC motorized zoom lenses |
On board Bayer decoding: |
yes (with RTF option) |
Power over Ethernet: |
yes - (with PoE option) |
Dimensions: |
straight: 98 x 44,8 x 31,4 mm / angled: 102,3 x 44,8 x 32,4 mm |
Housing options: |
straight or 90 degree angled |
Digital inputs |
1 x TTL, 2 x opto insulated |
Digital outputs |
1 x TTL, 3 x opto insulated |
Analog Video out: |
yes |
Hardware LUT: |
yes |
Image Memory: |
64 MB |
RS-232 inteface: |
yes |
Operating voltages: |
10 - 26 VDC |
Maximum cable length: |
100 Meter |
Connectors: |
RJ45, 12-pin Hirose, 26-pin SDR |
GigEVision compliant |
yes |
GeniCam compliant |
yes |
Image acquisition: |
any GigEVision Software, Simplon SDK or standalone | , Wrap>
1/2.5 |
CMOS |
2592 x 1944 |
10 |
rolling |
color |
Sensors: |
Resolutions: |
Color: |
Lens mount: |
Optical filters: |
Interface: |
Processor: |
32Bit RISC CPU |
Operating System: |
DDR-Memory: |
128MB |
Storage: |
32MB flash memory |
Lens controller: |
Dimensions: |
Housing options: |
Digital inputs |
Digital outputs |
Analog Video out: |
yes |
Hardware LUT: |
yes |
Image Memory: |
64 MB |
RS-232 inteface: |
yes |
10 - 26 VDC |
100 Meter |
Connectors: |
yes |
GeniCam compliant |
yes |
