Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú leutronÖÇÄÜÏà»ú---CheckSight series
²úÆ·Ãû³Æ£º leutronÖÇÄÜÏà»ú---CheckSight series
ÐÍ ºÅ£º
Æ· ÅÆ£º 3530
CheckSight®ÖÇÄÜÏà»úÊǸßÖÊÁ¿¹¤ÒµÏà»úºÍÔËÐÐWindows»òLinuxϵͳPCµÄ½áºÏ¡£Ïà»ú¿ÉÓõ½Leutron VisionÍêÕûµÄCCDºÍCMOS´«¸ÐÆ÷Ñ¡Ôñ£¬·Ö±æÂÊ´ÓVGAµ½5Mpixel¡£ËüÌṩÁËÒ»¸öǧÕ×ÒÔÌ«ÍøºÍ3¸öUSB2.0½Ó¿Ú£¬Í¬Ê±»¹ÓÐÒ»¸öDVI-D½Ó¿ÚºÍÒôƵI/OÁ¬½ÓÍâΧÉ豸£¬ÏÔʾÆ÷£¬ÑïÉùÆ÷ºÍÂó¿Ë·ç¡£    CheckSight®Ê¹ÓÃC-»òÕßCS-Mount¾µÍ·¡£1.6GHz Intel Atom ´¦ÀíÆ÷ºÍ1GB°åÉÏDDR2 RAMÌṩÁ˵͹¦ºÄϵĸ߼ÆËãÐÔÄÜ¡£Í¨¹ýCheckSight®ÖÇÄÜÏà»úµÄOSºÍÈí¼þ²Ù×÷£¬Äú¿ÉÒÔÌåÑéµ½ËüµÄ¸ßÐÔÄܺ͸ßÁé»îÐÔ¡£
CheckSight P34M
1/4
CCD
659 x 494
64
global
monochrome
CheckSight P33M
1/3
CCD
659 x 494
62
global
monochrome
CheckSight P32M
1/2
CCD
659 x 494
62
global
monochrome
CheckSight G32M
1/2
CMOS
659 x 494
196
global
monochrome
CheckSight G43AM
1/3
CMOS
752 x 480
64
global
monochrome
CheckSight P52M
1/2
CCD
782 x 582
63
global
monochrome
CheckSight P83M
1/3
CCD
1042 x 768
32
global
monochrome
CheckSight R132M
1/2
CMOS
1280 x 1024
30
rolling
monochrome
CheckSight P142AM
1/2
CCD
1360 x 1024
15
global
monochrome
CheckSight P141M
2/3
CCD
1360 x 1024
20
global
monochrome
CheckSight P202M
1/1.8
CCD
1624 x 1236
14
global
monochrome
CheckSight R502M
1/2.5
CMOS
2592 x 1944
10
rolling
monochrome
CheckSight P34B
1/4
CCD
659 x 494
64
global
color
CheckSight P33B
1/3
CCD
659 x 494
62
global
color
CheckSight P32B
1/2
CCD
659 x 494
62
global
color
CheckSight G32B
1/2
CMOS
659 x 494
196
global
color
CheckSight G43AB
1/3
CMOS
752 x 480
64
global
color
CheckSight P52B
1/2
CCD
782 x 582
63
global
color
CheckSight P83B
1/3
CCD
1042 x 768
32
global
color
CheckSight P133B
1/2.7
CCD
1300 x 968
8
global
color
CheckSight P142AB
1/2
CCD
1360 x 1024
15
global
color
CheckSight P141B
2/3
CCD
1360 x 1024
20
global
color
CheckSight P202B
1/1.8
CCD
1624 x 1236
14
global
color
CheckSight P203B
1/2.7
CCD
1640 x 1232
9
global
color
CheckSight R312AB
1/2
CMOS
2048 x 1536
12
rolling
color
CheckSight R502B
1/2.5
CMOS
2592 x 1944
10
rolling
color
Sensors:
CCD and CMOS, 8, 10, 12 bit
Resolutions:
VGA up to 5 Mpixel
Color:
monochrome or color with Bayer pattern on sensor, a realtime, high performance 5x5 color decoder is integrated in FPGA for color cameras
Lens mount:
C-mount or CS-mount (option)
Optical filters:
IR-cut filter is built-in a, s standard, others as option (see list)
Processor:
1.6GHz Intel Atom Z530 CPU
Memory:
1GB 533MHz DDR2 RAM
Storage:
3.6GB onboard flash memory, industrial grade compact flash
Hardware LUT:
yes
Operating System:
Windows Embedded or Linux
Dimensions:
112 x 72 x 66 mm
Digital inputs
2 x TTL, 4 x opto insulated
Digital outputs
Graphics:
1 x DVI-D
Serial inteface:
RS 232, 3 x USB2
Network:
1 x Gigabit Ethernet
Operating voltages:
10 - 26 VDC
GeniCam compliant
yes
Image acquisition:
any GenTL compliant software, Simplon SDK (C/C++/.Net)
Processor:
Memory:
1GB 533MHz DDR2 RAM
Storage:
Hardware LUT:
yes
Operating System:
Dimensions:
112 x 72 x 66 mm
Digital inputs
Digital outputs
Graphics:
1 x DVI-D
Serial inteface:
RS 232, 3 x USB2
Network:
Operating voltages:
10 - 26 VDC
GeniCam compliant
yes
Image acquisition:
Processor:
Memory:
1GB 533MHz DDR2 RAM
Storage:
Hardware LUT:
yes
Operating System:
Dimensions:
112 x 72 x 66 mm
Digital inputs
Digital outputs
Graphics:
1 x DVI-D
Serial inteface:
RS 232, 3 x USB2
Network:
Operating voltages:
10 - 26 VDC
GeniCam compliant
yes
Image acquisition:
Processor:
Memory:
1GB 533MHz DDR2 RAM
Storage:
Hardware LUT:
yes
Operating System:
Dimensions:
112 x 72 x 66 mm
Digital inputs
Digital outputs
Graphics:
1 x DVI-D
Serial inteface:
RS 232, 3 x USB2
Network:
Operating voltages:
10 - 26 VDC
GeniCam compliant
yes
Image acquisition:
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
