¡ô¼ò¼Û
WB2014LÊǵ¥´¥µãÐʹſؿª¹Ø£¬ËüÊÇÒ»¿îͨÓÃС¹¦ÂÊÂÌÉ«²£Á§³£¿ª¸É»É¿ª¹Ø,²£Á§¹Ü³¤14.2mm¡¢Ö±¾¶2.3mm¡¢×ܳ¤¶È44mm¡£µ±´Å³¡¿¿Ê±¿ª¹Ø½Óͨ£¬µ±´Å³¡³·Àëʱ¿ª¹Ø¶ÏÁË£¬¸Ã¿ª¹Ø¿ÉÓõç´ÅÌú¿ØÖÆ£¬»òÓÃÓÀ´ÅÌú¿ØÖÆ£¬Ò²¿ÉÒÔÊÇÁ½ÕߵĽáºÏ¡£¿ÉÓÃÓÚ¼ì²âÔª¼þ¡¢¼ÌµçÆ÷¡¢Âö³å¼ÆÊýÆ÷»òÀàËÆ×°Ö㬾ßÓм«¸ßµÄ¹¤ ×÷ÊÙÃü¼°¿É¿¿ÐÔ¡£
¡ôÌØµã£º
1¡¢ ¶¯×÷ËÙ¶ÈѸËÙ
2¡¢ ÊÊÓÃÓÚ¶¯×÷ƵÂʸߵIJúÆ·
3¡¢ ´¥µã¾ßÓм«¸ßµÄ·ÀÄÍÊ´ÐÔºÍÄÍÄ¥ËðÐÔ
4¡¢ ʹÓÃÊÙÃü³¤£¬¿É»ñµÃÎȶ¨µÄ¿ª¹Ø¶¯×÷
¡ôÓÃ;
¿ÉÓÃÓÚ´Å¿ª¹Ø¿ØÖƼì²â£ºÓ¦Óð²·À±¨¾¯ÏµÍ³£¬½Ó½ü´«¸ÐÆ÷£¬ÃÅ´Å¿ª¹Ø£¬Åܲ½»ú£¬¼Æ³ÌÆ÷£¬Íæ¾ßµç·£¬µÈ¿ØÖƵç·ÖÐ
Part No. |
ÐͺŠ|
WB2014L |
Total Length |
×ܳ¤¶È |
44 mm |
Glass Length |
²£Á§³¤¶È |
14.2 mm |
Glass Diameter |
Ö±¾¶ |
2.3 mm |
Contact Form |
´¥µãÐÎʽ |
1A (SPST-NO) |
Contact Position |
´¥µãλÖà |
SYM |
Contact Material |
´¥µã²ÄÖÊ |
Ru |
Contact Rating |
´¥µã¸ºÔØ |
10W |
Max. Switching Voltage |
×î´ó¿ª¹Øµçѹ |
100 VDC / VAC |
Max. Switching Current |
×î´ó¿ª¹ØµçÁ÷ |
0.1A |
Contact Resistance (at initial value) |
½Ó´¥µç×è ( ³õʼֵ ) |
100 mOhms |
Pull In Value (AT) |
Æô¶¯Öµ |
10-35 |
Drop Out Value (AT) |
ÊÍ·ÅÖµ |
5 |
Operation Time |
¶¯×÷ʱ¼ä |
1.0 mSec.(Max.) |
Release Time |
ÊÍ·Åʱ¼ä |
0.4 mSec.(Max.) |
Breakdown Voltage |
Ä͸ßѹ |
220VDC(AT<25)/ 250VDC(AT>25) |
Contact Capacitance |
´¥µãµçÈÝ |
0.7 pF |
Insulation Resistance |
¾øÔµµç×è |
1010Ohms |
Resonant Frequency |
гÕñƵÂÊ |
4 kHz |
Operation Temperature |
¹¤×÷ζȷ¶Î§ |
-60 ¡æ ~+155 ¡æ |
High Humidity |
×î¸ßʪ¶È |
98% (Max.) |
Operation Frequency |
×î¸ß¹¤×÷ƵÂÊ |
100 Hz |
Electrical Life |
µçÆøÊÙÃü |
106(5V ,10mA) 105(24V, 400mA) |
Test Coil |
²âÊÔÏßȦ |
5000 ¡¡870 Ohm |
Leads |
ÒýÏ߽Š|
Gold-Plated ¶Æ |
Safety |
°²È«ÈÏÖ¤ |
SGS |
