¡ô¼ò¼Û
WB3020LÊǵ¥´¥µãÐʹſؿª¹Ø£¬ËüÊÇÒ»¿î¹ú²úͨÓÃС¹¦ÂÊÂÌÉ«²£Á§³£¿ª¸É»É¿ª¹Ø¡£²£Á§¹Ü³¤20mm¡¢Ö±¾¶3mm¡¢×ܳ¤¶È52mm¡£µ±´Å³¡¿¿Ê±¿ª¹Ø½Óͨ£¬µ±´Å³¡³·Àëʱ¿ª¹Ø¶Ï¿ª£¬¸Ã¿ª¹Ø¿ÉÓõç´ÅÌú¿ØÖÆ£¬»òÓÃÓÀ´ÅÌú¿ØÖÆ£¬£¬Ò²¿ÉÒÔÊÇÁ½ÕߵĽáºÏ¡£¿ÉÓÃÓÚ¼ì²âÔª¼þ¡¢¼ÌµçÆ÷¡¢Âö³å¼ÆÊýÆ÷»òÀàËÆ×°Ö㬾ßÓм«¸ßµÄ¹¤ ×÷ÊÙÃü¼°¿É¿¿ÐÔ¡£
¡ôÌØµã£º
1¡¢ ¶¯×÷ËÙ¶ÈѸËÙ
2¡¢ ÊÊÓÃÓÚ¶¯×÷ƵÂʸߵIJúÆ·
3¡¢ ´¥µã¾ßÓм«¸ßµÄ·ÀÄÍÊ´ÐÔºÍÄÍÄ¥ËðÐÔ
4¡¢ ʹÓÃÊÙÃü³¤£¬¿É»ñµÃÎȶ¨µÄ¿ª¹Ø¶¯×÷
¡ôÓÃ;
¿ÉÓÃÓÚ´Å¿ª¹Ø¿ØÖƼì²â£ºÓ¦Óð²·À±¨¾¯ÏµÍ³£¬½Ó½ü´«¸ÐÆ÷£¬ÃÅ´Å¿ª¹Ø£¬Åܲ½»ú£¬¼Æ³ÌÆ÷£¬Íæ¾ßµç·£¬µÈ¿ØÖƵç·ÖÐ
Part No. |
ÐͺŠ|
WB3020L |
Total Length |
×ܳ¤¶È |
52 mm |
Glass Length |
²£Á§³¤¶È |
20 mm |
Glass Diameter |
Ö±¾¶ |
3.0mm |
Contact Form |
´¥µãÐÎʽ |
1A £¨SPST-NO£© |
Contact Position |
´¥µãλÖà |
SYM |
Contact Material |
´¥µã²ÄÖÊ |
Ru |
Contact Rating |
´¥µã¸ºÔØ |
10W |
Max. Switching Voltage |
×î´ó¿ª¹Øµçѹ |
180VDC / 130VAC |
Max. Switching Current |
×î´ó¿ª¹ØµçÁ÷ |
0.5A |
Contact Resistance (at initial value) |
½Ó´¥µç×è ( ³õʼֵ ) |
150 mOhms |
Pull In Value (AT) |
Æô¶¯Öµ |
10-40 |
Drop Out Value (AT) |
ÊÍ·ÅÖµ |
4 |
Operation Time |
¶¯×÷ʱ¼ä |
1.0 mSec.(Max.) |
Release Time |
ÊÍ·Åʱ¼ä |
0.3 mSec.(Max.) |
Breakdown Voltage |
Ä͸ßѹ |
220VDC(AT<20) 280VDC(AT>20) |
Contact Capacitance |
´¥µãµçÈÝ |
0.4 pF |
Insulation Resistance |
¾øÔµµç×è |
109Ohms |
Resonant Frequency |
гÕñƵÂÊ |
2.6 kHz |
Operation Temperature |
¹¤×÷ζȷ¶Î§ |
-60¡æ~+125¡æ |
High Humidity |
×î¸ßʪ¶È |
98% (Max.) |
Operation Frequency |
×î¸ß¹¤×÷ƵÂÊ |
100 Hz |
Electrical Life |
µçÆøÊÙÃü |
106£¨5V£¬10mA£© 105£¨24V£¬250mA£© |
Test Coil |
²âÊÔÏßȦ |
5000 550 Ohm |
Leads |
ÒýÏ߽Š|
Gold-Plated ¶ÆÒø |
Safety |
°²È«ÈÏÖ¤ |
SGS |
