Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Active SiliconͼÏñ²É¼¯¿¨
²úÆ·Ãû³Æ£º Active SiliconͼÏñ²É¼¯¿¨
ÐÍ ºÅ£º LFG Series
Æ· ÅÆ£º 1337
²úÆ·Ïêϸ˵Ã÷£º
The LFG series is a low cost high quality composite/S-Video and monochrome frame grabber. Available for several operating systems and form factors (PCI Express, PCI, PMC, PC/104-Plus & cPCI). Provided with royalty free optimised JPEG and wavelet codecs.
LFG - PCI, PCIe, PMC, PC/104-Plus, cPCI
LFG in PCI Form Factor
The standard PCI format utilising the 32 bit & 64-bit PCI bus as found in standard PCs and Apple Macs. This board can be used in desktop and embedded PCs, as well as for initial development/feasibility before migrating to a more embedded solution based on PC/104-Plus or PMC/cPCI.
LFG in PCI Express Form Factor
The PCI Express format as found in today's PCs and Apple Macs. The next generation of high bandwidth bus, available in x1, x4, x8 & x16 lanes.
LFG in PMC Form Factor
A high end industrial embedded form factor. Used as a mezzanine board in 3U & 6U rack systems, such as VME, supporting both Intel and PowerPC architectures.
LFG in PC/104-Plus Form Factor
The PC/104-Plus LFG utilises the PCI extension to the well established PC/104 (ISA) industrial form factor.
LFG in CompactPCI (cPCI) Form Factor
An embedded form factor in 3U and 6U formats, typically used in industrial and other embedded systems.
LFG4 - PCI Express, PCI64
LFG4 in PCI Express Form Factor
The LFG4-PE1 can acquire video from up to 16 analogue video sources, and can capture the full resolution real-time video from up to 4 sources simultaneously. From a programmer's perspective the LFG4 is equivalent to four standard LFGs in a single PCI Express slot.
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
