²úÆ·Ãû³Æ£º
BitFlowͼÏñ²É¼¯¿¨
ÐÍ ºÅ£º
Alta-AN
²úÆ·Ïêϸ˵Ã÷£º
- x4 PCI Express "short" card
- Super high quality discrete Analog Front End
- Three A-to-Ds per VFG (maximum clock rate: 160 MHz)
- Supports VGA, SVGA, XGA, SXGA, UXGA resolutions and beyond
- Per channel programmable Gain/offset
- Supports single tap and dual tap monochrome cameras
- Supports RGB cameras (24 bits/pixel)
- Supports component YPbPr cameras (YUV 4:4:4)
- Supports asynchronous reset cameras
- Supports partial scan cameras (high frame rates)
- Multiplex between two one-tap or two two-tap cameras
- Programmable Region of Interest (ROI) via sub-windowing acquisition
- External hardware or software trigger
- Acquire at any frame rate
- Supports cameras up to 16K x 16K
- Supports interlaced and progressive scan cameras
- HD/VD/Composite sync signals in/out
- Supports WEN input signal
- Strobe output (programmable timing)
- Provides power to camera (12 V @ 0.5 A)
- Flowthru technology, no on-board frame buffers, zero latency data access
- Efficient interrupt driven architecture, no software polling required
- RoHS compliant
