Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú BitFlowͼÏñ²É¼¯¿¨
²úÆ·Ãû³Æ£º BitFlowͼÏñ²É¼¯¿¨
ÐÍ ºÅ£º RoadRunner
²úÆ·Ïêϸ˵Ã÷£º
32-bit/33MHz bus master PCI bus interface board
Flow-Thru architecture featuring a Scatter/Gather DMA engine that supports the direct transfer of data to VGA or system memory in real-time with no latency or CPU usage
Acquires image sizes up to 512K by 32K pixels (vertical size is unlimited for line scan cameras)
LVDS/RS422 (32-bit) area or line scan camera interface supporting a single camera with up to 4 8-bit channels, two synchronized cameras or two multiplexed asynchronous cameras (model dependent)
9 user-programmable I/O signals (4 inputs and 5 outputs)
Multiple trigger modes
Up to 40MHz acquisition for LVDS and 30MHz for RS-422 (contact us for higher clock rates)
On-the-fly reformatting for multi-tap cameras
Standard 8-bit in/12-bit out LUT
Optional 16-bit in/16-bit out LUT available
Cables and configuration files for more than 200 industrial cameras
Drivers and DLLs for Windows NT, 2000 and XP
Supported by all versions of the BitFlow SDK
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
