Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú BitFlowͼÏñ²É¼¯¿¨
²úÆ·Ãû³Æ£º BitFlowͼÏñ²É¼¯¿¨
ÐÍ ºÅ£º NEON-CLB
²úÆ·Ïêϸ˵Ã÷£º
Base Camera Link interface
Power over Camera Link (PoCL)
Supports both PoCL and non-PoCL cameras
Provides Safe Power - full protection from all CL power line faults
Fully backwards compatible with non-PoCL cameras and cables
Half-Size x4 PCI Express Board
Acquire up to 24 bits at 85 MHz
Both CL and I/O connector on one bracket (only one slot needed)
FlowThru technology means that no on-board memory is needed, even with the fastest cameras
DMA at data rates up to 528 MB/S
Supports images up to 256K x 128K
No frame rate limit
Triggers and encoders for external control of acquisition
Programmable signal generator for camera control
Sophisticated triggering modes for complex applications
Acquire variable length frames with line scan cameras
Quadrature encoder support including sophisticated triggering schemes
Encoder divider/multiplier
On board timing generator supports high-resolution exposure control
Drivers, utilities and examples for Windows XP/2003/Vista/Windows 7
Supported on both 32-bit and 64-bit platforms
Drivers for most 3rd party processing environments
Acquire image sequences well beyond the 4GB barrier
RoHS compliant
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
