Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Vector-International¹¤ÒµÏà»ú
²úÆ·Ãû³Æ£º Vector-International¹¤ÒµÏà»ú
ÐÍ ºÅ£º OEM Cameras
²úÆ·Ïêϸ˵Ã÷£º
The VC family of cameras is intended for integration into the user's own vision system. The base model can support several different sensors allowing the designer to tailor the specifications to a particular application
Features
  • Resolutions from WVGA to 5 Megapixels
  • Flexible Window-of-Interest and sub-sampling/binning
  • Tethered Head construction (up to 150mm)
  • Opto-isolated external trigger in/out
  • Compact housing option
  • C-Mount lens fitting option
  • USB 2.0 interface
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
