Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú FCi4-14000
²úÆ·Ãû³Æ£º FCi4-14000
ÐÍ ºÅ£º FCi4-14000
²úÆ·Ïêϸ˵Ã÷£º
The FCi4-14000 is intended for applications where normally a 35mm film camera would be used, including machine vision, document scanning, aerial photography.
Features
  • 14 Megapixels - 4560 x 3048
  • 36 x 24 mm sensor (35 mm film format)
  • Flexible Window-of-Interest and sub-sampling
  • Rolling shutter
  • 65 dB dynamic range
  • 12-bit digital output at 60 MHz.pixel rate
  • 3.25 full-frames per second
  • Compact 70 x 70 x 90 mm. (not including lens)
  • F-Mount lens fitting
  • Base Camera Link interface (2 x 12-bit)
  • USB 2.0 interface
¹«Ë¾Ãû³Æ£º ±±¾©Ó¯ÃÀÖǿƼ¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82895362-1201 2007 2005 / ñ¼ÄÈ
ÊÖ»ú£º 18901088856
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØÐÅϢ·1ºÅ¹ú¼Ê¿Æ¼¼´´ÒµÔ°1#1705
ÓÊ ±à£º 100085
Ö÷ Ò³£º www.cnimage.com
  • ¼ÓÄôóProsilica GE1050
  • FLIR TϵÁкìÍâÈÈÏñÒÇ
  • kappa---Zelos-02150 GV
  • ÃÀ¹úSIlicon Imaging¹¤ÒµÏà»ú
  • PHANTA CameraLinkÖÐ¼ÌÆ÷/·ÖÊøÆ÷
  • CVBͼÏñ´¦ÀíÈí¼þ
  • FLIR i40ºìÍâÈÈÏñÒÇ
  • ͼÏñ¼ÓËÙ---Gidel
  • µÂ¹úKappa Êý×ÖÏà»ú
  • BitFlowͼÏñ²É¼¯¿¨
