| Technical specifications |
| Input |
| Supply voltage / 1 / at AC / nominal value |
120 V |
| Supply voltage / 2 / at AC / nominal value |
230 V |
| Input voltage / 1 / at AC |
85 V¡132 V |
| Input voltage / 2 / at AC |
170 V¡264 V |
| Wide-range input |
·ñ |
| Mains buffering at Iout rated, min. |
20 ms |
| Ï߯µÂÊ |
50 Hz/60 Hz |
| Rated line range |
47 Hz...63 Hz |
| ÊäÈëµçÁ÷ / [nicht versorgt - bei Nennwert der Eingangsspannung 120 V]/[nicht versorgt - Nennwert] |
2.1 A |
1.15 A |
| Switch-on current limiting (+25 ¡ãC), max. |
32 A |
| Duration of current limiting / at 25 ¡ãC / typical |
3 ms |
| I2tÖµ |
0.8 A²¡¤s |
| Output |
| Êä³öµçѹ |
24 V |
| Total tolerance, static ¡À |
3 % |
| Static mains compensation, approx. |
0.1 % |
| Static load balancing, approx. |
0.5 % |
| Residual ripple peak-peak, max. |
150 mV |
| Residual ripple peak-peak, typ. |
50 mV |
| Spikes peak-peak, max. (bandwidth: 20 MHz) |
240 mV |
| Spikes peak-peak, typ. (bandwidth: 20 MHz) |
150 mV |
| Adjustment range |
22.8 V¡28 V |
| Product feature / output voltage adjustable |
ÊÇ |
| ¶¯×÷ÑÓ³Ùʱ¼ä |
0.1 s |
| Voltage rise, typ. |
50 ms |
| Êä³öµçÁ÷ |
5 A |
| Current range |
0 A¡6 A |
| delivered active power / typ. |
144 W |
| short-term overload current / at short-circuit during run-up / typical |
17 A |
| Duration of overloading ability for excess current / on short-circuiting during the start-up |
100 ms |
| short-term overload current / at short-circuit during operation / typical |
17 A |
| Duration of overloading ability for excess current / on short-circuiting during the operational phase |
200 ms |
| Parallel switching for enhanced performance |
ÊÇ |
| Numbers of parallel switchable units for enhanced performance |
2 |
| Efficiency |
| Efficiency at Vout rated, Iout rated, approx. |
87 % |
| Power loss at Vout rated, Iout rated, approx. |
17 W |
| Closed-loop control |
| Dynamic mains compensation (Vin rated ¡À15 %), max. |
0.3 % |
| Dynamic load smoothing (Iout: 50/100/50 %), Uout ¡À typ. |
1 % |
| Load step setting time 50 to 100%, typ. |
0.2 ms |
| Load step setting time 100 to 50%, typ. |
0.2 ms |
| Protection and monitoring |
| Current limitation |
6.4 A¡6.6 A |
| Êä³öµÄÌØÐÔ / ¶Ì·±£»¤ |
ÊÇ |
| Enduring short circuit current / Effective level / typical |
10 A |
| Safety |
| µçλ¸ôÀë |
ÊÇ |
| stray current / maximum |
3.5 mA |
| stray current / typical |
0.4 mA |
| ºÏ¸ñÖ¤Ã÷ |
ÊÇ |
| ×ʸñÖ¤Ã÷ |
ÊÇ |
| FM approval |
·ñ |
| CB approval |
ÊÇ |
| ·À»¤µÈ¼¶IP |
IP20 |
| EMC |
| Operating data |
| Ambient temperature / in operation |
0 ¡ãC¡60 ¡ãC |
| Ambient temparature / on transport |
-40 ¡ãC¡85 ¡ãC |
| Ambient temparature / in storage |
-40 ¡ãC¡85 ¡ãC |
| Mechanics |
| µçÆøÁ¬½ÓµÄ½á¹¹ÐÎʽ |
ÂÝ˨Á¬½Ó |
| ¿í¶È / Íâ¿ÇµÄ |
50 mm |
| ¸ß¶È / Íâ¿ÇµÄ |
125 mm |
| Éî¶È / Íâ¿ÇµÄ |
125 mm |
| °²×°¿í¶È |
50 mm |
| °²×°¸ß¶È |
225 mm |
| ¾»ÖØ |
0.5 kg |
| ²úÆ·ÌØµã / Íâ¿ÇµÄ / ¿É˳ÐòÅÅÁеĿÇÌå |
ÊÇ |
| ¹Ì¶¨ÀàÐÍ / ǽ±Ú°²×° |
·ñ |
| ¹Ì¶¨ÀàÐÍ / µ¼¹ì°²×° |
ÊÇ |
