Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú °ÂÍÐÄá¿Ë˹¼ÆÊýÆ÷CT6-I,CT6,CT6-2P
²úÆ·Ãû³Æ£º °ÂÍÐÄá¿Ë˹¼ÆÊýÆ÷CT6-I,CT6,CT6-2P
ÐÍ ºÅ£º CT6-I,CT6,CT6-2P
¡ñ ¿í·¶Î§µçÔ´ÊäÈë¶ÔÓ¦£º½»Á÷100-240V¡¢50/60Hz£¬Ö±Á÷12-24V(Ñ¡Ôñ¹æ¸ñ)¡£
¡ñ Í£µçʱ×Ô¶¯´æ´¢¹¦ÄÜ¡£
¡ñ ¼Ó¡¢¼õË㹦ÄÜ¡£
¡ñ ÄÚװ΢Ð͵çÄÔ¡£
±¾¹«Ë¾´úÀíAUTONICS(°ÂÍÐÄá¿Ë˹) ȫϵÁвúÆ·£¬ÐÍºÅÆëÈ«£¬¼Û¸ñµÍ£º¸ßËÙ¼ÆÊýÆ÷¡¢¹âÏË´«¸ÐÆ÷¡¢×ªËÙ±í¡¢ÏßËÙ±í¡¢¹âµç¿ª¹Ø¡¢½Ó½ü¿ª¹Ø¡¢¼ÆÊ±Æ÷¡¢PIDÎÂ¿ØÆ÷¡¢µçѹ±í¡¢µçÁ÷±í£¬¹âµç´«¸ÐÆ÷£¬Î¢Ð͹âµç´«¸ÐÆ÷£¬Á¬½ÓÆ÷¡¢·´Éä°å£¬¹âÏË£¬Ðýת±àÂëÆ÷£¨¾ø¶ÔÐÍ£©£¨ÔöÁ¿ÐÍ£©£¬LCD¼ÆÊýÆ÷£¬ÊýÏÔ¼ÆÊ±/¼ÆÊýÆ÷£¬Ô¤Ëã¼ÆÊýÆ÷£¬Ä£Äâ¼ÆÊ±Æ÷£¬ÊýÏÔ¼ÆÊ±Æ÷£¬LCD¼ÆÊ±Æ÷£¬²åÍ·£¬²å×ù£¬LCDתËÙ±í£¬ÏßËÙ¶È±í£¬ÏÔʾµ¥Ôª£¬Ãæ°å±í£¬¶àÓÃÃæ°å±íµÈ......
LCD¼ÆÊýÆ÷
LA7N-1£¬LA7N-2£¬LA7N-3£¬LA7N-4£¬LA7N-1R£¬LA7N-2R£¬LA7N-3R£¬LA7N-4R£¬LA7N-F£¬LA7N-FR£ºW48*H24MM
ÊýÏÔ¼ÆÊýÆ÷
FS5B W48*H24MM
FS4A W48*H24MM 100-240VAC,12-24VDC INPUT NPN
ÊýÏÔ¼ÆÊ±¼ÆÊýÆ÷
µ¥Ô¤ÉèFX4S£¬FX4£¬FX6£¬FX4H
˫ԤÉèFX4-2P*£¬FX6-2P*£¬FX4H-2P£¬FX4L-2P£¬FX6L-2P
ÏÔʾרÓÃFX4Y-I,FX6Y-I,FX5S-I,FX4-I,FX6-I,FX4H-I,FX4L-I,FX6L-I
FX4Y-1 W72*H36MM INPUT NPN
FX6Y-1
FX5S-1 W48*H48MM 100-240VAC,12-24VDC INPUT NPN
FX4S W48*H48MM INPUT NPN
FX4-1 W72*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6-1 W72*H72MM INPUT PNP
FX4 W72*H72MM INPUT PNP
FX6 W72*H72MM INPUT PNP
FX4-2P W72*H72MM INPUT PNP
FX6-2P W72*H72MM INPUT PNP
FX4H-1 W48*H96MM 100-240VAC,12-24VDC INPUT PNP
FX4L-1 W48*H96MM INPUT PNP
FX4H-2P W48*H96MM INPUT PNP
FX4H W144*H72MM INPUT PNP
FX6L-1 W144*H72MM INPUT PNP
FX4L-2P W144*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6L-2P W144*H72MM INPUT PNP
ÊýÏÔ¼ÆÊ±¼ÆÊýÆ÷
CT4S W48*H48MM INPUT NPN/PNP
CT4S-2P W48*H48MM INPUT NPN/PNP
CT6S-1 W48*H48MM INPUT NPN/PNP
CT6S W48*H48MM INPUT NPN/PNP
CT6S-2P W48*H48MM INPUT NPN/PNP
CT6-1 W72*h72MM 100-240VAC,24-60VDC INPUT NPN/PNP
CT6 W72*h72MM INPUT NPN/PNP
CT6-2P W72*h72MM INPUT NPN/PNP
Ä£Äâ¼ÆÊ±Æ÷
AT8AN 100-240VAC/24-240VDC(12DCV)24,48VAC,110.220VAC,12,24,48,100VDC 8PIN SOCKET
AT11DN 11PIN SOCKET
AT11EN 8PIN SOCKET
AT8SDN W48*H48mm 110,220VAC,24,48,100/110VDC 0.5SEC-100SEC
AT8PSN W48*H48mm 110,220VAC24,48,100/110VDC 0.5,1.5,10SEC
AT8PMN W48*H48mm 0.5,1.5,10 Min
ATE W48*H48mm 110/220VAC12,24VDC100, 220VAC12.24VDC 1s,3s,6s,10s,30s,60s,
3m,6m,10m,30m,60m,3h,6h,12h,24h
ATE-1,2 W48*H48mm
ÊýÏÔ¼ÆÊ±Æ÷
FS4E W48*H48mm 100-240VAC,12-24VDC
FS5E1 W48*H48mm
LCD¼ÆÊ±Æ÷
LE3S W48*H48mm 100-240VAC,24-240VDC
LE3SA W48*H48mm 110,220VAC
LE3SB W48*H48mm
LE4S W48*H48mm 24-240VAC,24-240VDC
LE4SA W48*H48mm
LE7N-S,M,H,HR w48*H24mm
LE7N-SF,MF,HF,HFR w48*H24mm / input24-240VAC,6-240VDC
LE7D-2 W72*h72mm 100-240VDC MULTITYPE
¹«Ë¾Ãû³Æ£º ÍпËÖÇÄÜÒDZíÎÞÎýÓÐÏÞ¹«Ë¾
µç »°£º 0510 82845021 15161522622 / ²ÜêÍ
ÊÖ»ú£º 15061829426
µØ Ö·£º ÎÞÎýÊлÝÉ½ÇøÑô¹â100¹ú¼Ê³Ç165ºÅ
ÓÊ ±à£º 214000
Ö÷ Ò³£º http://wx.tuoke.com
  • 4-20mA/0-10VÐźŸôÀëÆ÷
  • ͶÈëʽҺλ±äËÍÆ÷
  • 4λ°ë½»Á÷µçÁ÷±í
  • DP3-SVA1A
  • Ò»Èë¶þ³öÐźŸôÀëÆ÷ 4-20ma
  • ÐźÅËþµÆ
  • 0-1AÐźŸôÀëÆ÷ÅäµçÆ÷
  • ´øÉÏÏÂÏÞ´¥µãÊä³öµçÁ÷±íµçѹ±í
  • Âö³åÐźÅתËÙ±í
  • PIDοØÒÇ
