Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ̨ÍåïÈÊMOUJENÏÞλ¿ª¹ØM8-8606
²úÆ·Ãû³Æ£º ̨ÍåïÈÊMOUJENÏÞλ¿ª¹ØM8-8606
ÐÍ ºÅ£º M8-8606
M8-8606̨ÍåïÈÊMOUJENÏÞλ¿ª¹Ø£¬ÏúÊ۵绰£º0755-29412191 29412192 13560772612
M8 ϵÁР (Made in Taiwan)
Technical data (ÒŽ¸ñ):
General
Standards IEC/EN 60947
Climatic proofing Damp heat, constant,, to IEC 60068-2-78
Damp heat, cyclic. to IEC 60068-2-30
Ambinet temperature -25 / +70
Mounting position As required
Degree of protection IP66. IP65 for "T" Type with rubber strain
Contacts/switcjing capacity
Rated impulse withstand voltage Uimp VAC 4000
Rated insulation voltage Ui V 400
Overvolatge category/pollution degree III/3
Rated operational current
AC-15 24V Ie A 6
230V/240V Ie A 6
400V/415V Ie A 4
DC-13 24V Ie A 10
110V Ie A 1
220V Ie A 0.5
Contral circuit reliability
at 24V DC / 5mA HF Fault probability <10-7,<1 failure at 107 operations
at 5V DC / 1mA HF Fault probability <10-6,<1 failure at 5x106 operations
Suppy frequency Hz max. 400
Short-circuit rating in the closed state (IEC / EN 60947-5-1)
Fuseless Type PKZM0-10 FAZ-B6/1
Max. Fuseless A gG / gL 10
Short-circuit rating to IEC / EN 60947-5-1
Max. Fuseless A gG / gL 6
Repetition accuracy mm 0.02
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
