¹©Ó¦ÑôÃ÷½Ó½ü¿ª¹ØPS-05N£¬PS-05P£¬PS-05NB£¬PS-05PBÏÖ»õ¹©Ó¦
̨ÍåÑôÃ÷fotek·½Ðͽӽü¿ª¹Ø
LS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
LS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
LS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
LS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
SP-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
SP-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
BS-02N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-02P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PP-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
PS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
PS-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-10N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-10P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-15N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-15P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-10S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
PS-15S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
PS-05S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë5mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
Ô²ÖùÐͽӽü¿ª¹Ø
PM08-01N Êä³ö״̬NO Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë1.0mm ¹¤×÷µçѹ10-30VDC ·´Ó¦ÆµÂÊ2.5KHz
PM08-01NB NC
PM08-01P NO PNP
PM08-02PB NC
PM08-02N NO NPN 2.0mm 10-30VDC 2.5KHz
PM08-02NB NC
PM08-02P NO PNP
PM08-02PB NC
PM12-02N-S NO NPN 2.0mm 10-30VDC 2.5KHz
PM12-02NB-S NC
PM12-02P-S NO PNP
PM12-02PB-S NC
PM12-04N Êä³ö״̬NO Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ¹¤×÷µçѹ10-30VDC ·´Ó¦ÆµÂÊ2.5KHz
PM12-04N-S NO NPN 4.0mm 10-30VDC 2.5KHz
PM12-04NB-S NC PM12-04P-S NO PNP
PM12-04PB-S NC PM12-02N NO NPN 2.0mm 10-30VDC 2.5KHz
PM12-02NB NC PM12-02P NO PNP
PM12-02PB NC PM12-04N NO NPN 4.0mm 10-30VDC 20Hz
PM12-04NB NC PM12-04P NO PNP
PM12-04PB NC PM12-02S NO NPN 2.0mm 90-250VAC 20Hz
PM12-02S NC PM12-04S NO PNP 4.0mm PM012-04SB NC
