Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú FOTEK½Ó½ü¿ª¹ØPS-15N
²úÆ·Ãû³Æ£º FOTEK½Ó½ü¿ª¹ØPS-15N
ÐÍ ºÅ£º PS-15N
Æ· ÅÆ£º 28
̨ÍåÑôÃ÷fotek·½Ðͽӽü¿ª¹Ø
LS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
LS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
LS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
LS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
SP-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
SP-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
BS-02N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-02P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PP-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
PS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
PS-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-10N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-10P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-15N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-15P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-10S   Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
PS-15S   Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
PS-05S   Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë5mm   Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
Ô²ÖùÐͽӽü¿ª¹Ø
PM08-01N    Êä³ö״̬NO Êä³öÐÎʽNPN  ¸ÐÓ¦¾àÀë1.0mm ¹¤×÷µçѹ10-30VDC ·´Ó¦ÆµÂÊ2.5KHz
PM08-01NB   NC
PM08-01P    NO PNP
PM08-02PB   NC
PM08-02N    NO NPN   2.0mm 10-30VDC 2.5KHz
PM08-02NB   NC
PM08-02P    NO PNP
PM08-02PB   NC
PM12-02N-S  NO  NPN 2.0mm 10-30VDC 2.5KHz
PM12-02NB-S NC
PM12-02P-S  NO PNP
PM12-02PB-S NC
PM12-04N    Êä³ö״̬NO Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ¹¤×÷µçѹ10-30VDC ·´Ó¦ÆµÂÊ2.5KHz
PM12-04N-S  NO  NPN 4.0mm 10-30VDC 2.5KHz
PM12-04NB-S NC    PM12-04P-S NO PNP
PM12-04PB-S NC    PM12-02N   NO NPN 2.0mm 10-30VDC 2.5KHz
PM12-02NB   NC    PM12-02P   NO PNP
PM12-02PB   NC    PM12-04N   NO NPN 4.0mm 10-30VDC 20Hz
PM12-04NB   NC    PM12-04P   NO PNP
PM12-04PB   NC    PM12-02S   NO NPN 2.0mm 90-250VAC 20Hz
PM12-02S    NC    PM12-04S   NO PNP 4.0mm  PM012-04SB NC
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
