FOTEK̨ÍåÑôÃ÷QL-05N£¬QL-05PÏÖ»õ¹©Ó¦
̨ÍåÑôÃ÷fotek·½Ðͽӽü¿ª¹Ø
LS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
LS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
LS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
LS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
SP-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
SP-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
BS-02N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-02P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
BS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PP-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PP-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 800Hz
PS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC 2KHz
PS-04N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
PS-04P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 2KHz
PS-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-05N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-05P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-08N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PL-08P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 800Hz
PS-10N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-10P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-15N Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-15P Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 10-30VDC 500Hz
PS-10S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë10mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
PS-15S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë15mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
PS-05S Êä³öÐÎʽSCR ¸ÐÓ¦¾àÀë5mm Ç°Ãæ¸ÐÓ¦ 90-250VAC 20Hz
