Carlo GavazziÈðÊ¿¼ÑÀÖRMIA4524VDC£¬RMIA21024VDC£¬RN1F48I50Öмä¼ÌµçÆ÷
ÍâÐͳߴ磺56*35.5*35.5
´¥µã¶ÔÊý£º2¶Ô£¬3¶Ô£¬4¶Ô
¶î¶¨µçÁ÷£º25A£¬50A£¬90A£¬110A
´¥µãµçÁ÷£º10A
µçÆøÊÙÃü£º´óÓÚ100000´Î
¿ª¹Ø¹¦ÂÊ£º2500VA×èÐÔ¸ºÔØ
µçѹ·¶Î§£º6-12-24-48-60VDC
µçѹ·¶Î§£º6-12-24-49-115-120-230VAC
¾øÔµµÈ¼¶£ºEN61810-5
¹¦ÂÊ£º1.5W
±ê×¼ÅäÖ㺲âÊÔ/ÐźŵÆ/LED
ÈÏÖ¤/±ê×¼£ºCE-UL-CSA
RMIA210110DC£º RMI relay 2 contact CO DC coil
RMIA210120AC£º RMI relay 2 contact CO AC coil
RMIA21012AC£º RMI relay 2 contact CO AC coil
RMIA21012DC£º RMI relay 2 contact CO DC coil
RMIA210220AC£º RMI relay 2 contact CO AC coil
RMIA210240AC£º RMI relay 2 contact CO AC coil
RMIA21024AC£º RMI relay 2 contact CO AC coil
RMIA21024DC£º RMI relay 2 contact CO DC coil
RMIA21048AC£º RMI relay 2 contact CO AC coil
RMIA21048DC£º RMI relay 2 contact CO DC coil
RMIA21060DC£º RMI relay 2 contact CO DC coil
RMIA45110VDC£º RMI relay 4 contact CO DC coil
RMIA45120VAC£º RMI relay 4 contact CO AC coil
RMIA4512VAC£» RMI relay 4 contact CO AC coil
RMIA4512VDC£» RMI relay 4 contact CO DC coil
RMIA45220VAC£» RMI relay 4 contact CO AC coil
RMIA45240VAC£» RMI relay 4 contact CO AC coil
RMIA4524VAC£º RMI relay 4 contact CO AC coil
RMIA4524VDC£» RMI relay 4 contact CO DC coil
RMIA4548VAC£º RMI relay 4 contact CO AC coil
RMIA4548VDC£º RMI relay 4 contact CO DC coil
RMIA4560VDC£» RMI relay 4 contact CO DC coil
RMIB210110DC£º RMI relay 2 contact CO DC coil, PCB term.
RMIB210120AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB21012AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB21012DC£º RMI relay 2 contact CO DC coil, PCB term.
RMIB210220AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB210240AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB21024AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB21024DC£º RMI relay 2 contact CO DC coil, PCB term.
RMIB21048AC£º RMI relay 2 contact CO AC coil, PCB term.
RMIB21048DC£º RMI relay 2 contact CO DC coil, PCB term.
RMIB21060DC£º RMI relay 2 contact CO DC coil, PCB term.
RMIB45110VDC£º RMI relay 4 contact CO DC coil, PCB term.
RMIB45120VAC£º RMI relay 4 contact CO AC coil, PCB term.
RMIB4512VAC£º RMI relay 4 contact CO AC coil, PCB term.
RMIB4512VDC£º RMI relay 4 contact CO DC coil, PCB term.
RMIB45220VAC£º RMI relay 4 contact CO AC coil, PCB term.
RMIB45240VAC£» RMI relay 4 contact CO AC coil, PCB term.
RMIB4524VAC£» RMI relay 4 contact CO AC coil, PCB term.
RMIB4524VDC£º RMI relay 4 contact CO DC coil, PCB term.
RMIB4548VAC£º RMI relay 4 contact CO AC coil, PCB term.
RMIB4548VDC£º RMI relay 4 contact CO DC coil, PCB term.
RMIB4560VDC£º RMI relay 4 contact CO DC coil, PCB term.
