Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú RSHR4025CV21ÈðÊ¿¼ÑÀÖ(carlogavazzi)¼ÌµçÆ÷
²úÆ·Ãû³Æ£º RSHR4025CV21ÈðÊ¿¼ÑÀÖ(carlogavazzi)¼ÌµçÆ÷
ÐÍ ºÅ£º RSHR4025CV21
Æ· ÅÆ£º 971
RSHR4025CV21ÈðÊ¿¼ÑÀÖ(carlogavazzi)¼ÌµçÆ÷ÏÖ»õÓżۣ¬
ÍâÐͳߴ磺M8*30
ÂÝÎÆ³ß´ç£ºM30*1*25
¸ÐӦƵÂÊ£º2khz
¸ÐÓ¦¾àÀ룺1.5mm
¶î¶¨¹¤×÷µçѹ£º10-30VDC
ѹ½µ¹¤×÷µçѹ£ºÐ¡ÓÚµÈÓÚ2.5VDC
±£»¤µÈ¼¶£ºIP67
ÖÇ·µÈ¼¶£¬¼«ÐÔ±£»¤£¬ÔÝ̬±£»¤£ºPST
Êä³öµçÁ÷£ºÐ¡ÓÚ150MA
Íâ¿Ç²ÄÁÏ£º²»Ðâ¸Ö
LEDָʾ£º»ÆÉ«
RSHR2238CV20 MTR SOFT START 220V,11kW,38A ROTARY SET
RSHR2238CV21 MTR SOFT START 220V,11kW,38A ROTARY SET AUX RELAYS
RSHR2245CV20 RSH SOFTSTART 220V 45A + BYPASS RELAY
RSHR2245CV21 MTR SOFT START 220V,11kW,45A ROTARY SET AUX RELAYS
RSHR4006BV20 RSH SOFTSTART 400V 6A + BYPASS
RSHR4006BV21 RSH SOFTSTART 400V 6A + BYPASS + AUX RELAY + OTP
RSHR4012BV20 RSH SOFTSTART 400V 12A + BYPASS
RSHR4012BV21 RSH SOFTSTART 400V 12A + BYPASS + AUX RELAY + OTP
RSHR4018BV20 RSH SOFTSTART 400V 18A + BYPASS
RSHR4018BV21 RSH SOFTSTART 400V 18A + BYPASS + AUX RELAY + OTP
RSHR4025CV20 RSH SOFTSTART 400V 25A + BYPASS RELAY
RSHR4025CV21 RSH SOFTSTART 400V 25A + BYPASS RELAY + AUX RELAY
RSHR4025CV32 3 PH SOFT START 400V 25A 24-550VAC/DC IN LINE
RSHR4025CV33 3 PH SOFT START 400V 25A 24-550VAC/DC IN DELTA
RSHR4025CV38 3 PH SOFT START 400V 25A 24-550VAC/DC SCROLL
RSHR4032CV32 3 PH SOFT START 400V 32A 24-550VAC/DC IN LINE
RSHR4032CV33 3 PH SOFT START 400V 32A 24-550VAC/DC IN DELTA
RSHR4032CV38 3 PH SOFT START 400V 32A 24-550VAC/DC SCROLL
RSHR4038CV20 MTR SOFT START 400V,18.5kW,38A ROTARY SET
RSHR4038CV21 MTR SOFT START 400V,18.5kW,38A ROTARY SET AUX RELAYS
RSHR4045CV20 RSH SOFTSTART 400V 45A + BYPASS RELAY
RSHR4045CV21 RSH SOFTSTART 400V 45A+B/PAS REL+AUX REL
RSHR4806BV20 RSH SOFTSTART 480V 6A + BYPASS
RSHR4806BV21 RSH SOFTSTART 480V 6A + BYPASS + AUX RELAY + OTP
RSHR4812BV20 RSH SOFTSTART 480V 12A + BYPASS
RSHR4812BV21 RSH SOFTSTART 480V 12A + BYPASS + AUX RELAY + OTP
RSHR4818BV20 RSH SOFTSTART 480V 18A + BYPASS
RSHR4818BV21 RSH SOFTSTART 480V 18A + BYPASS + AUX RELAY + OTP
RSHR4825CV20 RSH SOFTSTART 480V 25A + BYPASS RELAY
RSHR4825CV21 RSH SOFTSTART 480V 25A+B/PAS REL+AUX REL
RSHR4825CV32 3 PH SOFT START 480V 25A 24-550VAC/DC IN LINE
RSHR4825CV33 3 PH SOFT START 480V 25A 24-550VAC/DC IN DELTA
RSHR4832CV32 3 PH SOFT START 480V 32A 24-550VAC/DC IN LINE
RSHR4832CV33 3 PH SOFT START 480V 32A 24-550VAC/DC IN DELTA
RSHR4838CV20 MTR SOFT START 480V,22kW,38A ROTARY SET
RSHR4838CV21 RSH SOFTSTART 480V 38A + BYPASS RELAY AUX RELAYS
RSHR4845CV20 RSH SOFTSTART 480V 45A + BYPASS RELAY
RSHR4845CV21 MTR SOFT START 480V,30kW,45A ROTARY SET AUX RELAYS
RSHR6006BV20 RSH SOFTSTART 600V 6A + BYPASS
RSHR6006BV21 RSH SOFTSTART 600V 6A + BYPASS + AUX RELAY + OTP
RSHR6012BV20 RSH SOFTSTART 600V 12A + BYPASS
RSHR6012BV21 RSH SOFTSTART 600V 12A + BYPASS + AUX RELAY + OTP
RSHR6018BV20 RSH SOFTSTART 600V 18A + BYPASS
RSHR6018BV21 RSH SOFTSTART 600V 18A + BYPASS + AUX RELAY + OTP
RSHR6025DV20 RSH SOFTSTART 600V 25A + BYPASS RELAY
RSHR6025DV21 MTR SOFT START 600V,18.5kW,25A ROTARY SET AUX RELAYS
RSHR6025DV32 3 PH SOFT START 600V 25A 24-660VAC/DC IN LINE
RSHR6025DV33 3 PH SOFT START 600V 25A 24-660VAC/DC IN DELTA
RSHR6032DV32 3 PH SOFT START 600V 32A 24-660VAC/DC IN LINE
RSHR6032DV33 3 PH SOFT START 600V 32A 24-660VAC/DC IN DELTA
RSHR6038DV20 MTR SOFT START 600V,22kW,38A ROTARY SET
RSHR6038DV21 MTR SOFT START 600V,22kW,38A ROTARY SET AUX RELAYS
RSHR6045DV20 RSH SOFTSTART 600V 45A + BYPASS RELAY
RSHR6045DV21 MTR SOFT START 600V,30kW,45A ROTARY SET AUX RELAYS
RSHRM06BV20 RSH SOFTSTART 190-530V 6A + BYPASS
RSHRM06BV21 RSH SOFTSTART 190-530V 6A + BYPASS + AUX RELAY + OTP
RSHRM12BV20 RSH SOFTSTART 190-530V 12A + BYPASS
RSHRM12BV21 RSH SOFTSTART 190-530V 12A + BYPASS + AUX RELAY + OTP
RSHRM18BV20 RSH SOFTSTART 190-530V 18A + BYPASS
RSHRM18BV21 RSH SOFTSTART 190-530V 18A + BYPASS + AUX RELAY + OTP
RSHRM25CV34 3 PH SOFT START 220-480V 25A 24-550VAC/DC IN LINE
RSHRM25CV35 3 PH SOFT START 220-480V 25A 24-550VAC/DC IN DELTA
RSHRM32CV34 3 PH SOFT START 220-480V 32A 24-550VAC/DC IN LINE
RSHRM32CV35 3 PH SOFT START 220-480V 32A 24-550VAC/DC IN DELTA
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
