CARLO GAVAZZIÈðÊ¿¼ÑÀÖPPB01CM23ÈýÏàµçѹ±£»¤¼ÌµçÆ÷
ÍâÐͳߴ磺99.9*22.5*83.5£¨µ¼¹ì°²×°£©
¹¦ÄÜ£º¹ý/Ç·µçѹÏàÐò£¬È±Ïà¼à¿Ø¼ÌµçÆ÷£¬3Ïà+N£¨×Ô¹©µçÔ´£©£¬2¶ÀÁ¢µ÷½Úµã£¬NÐÍÎÞÏàÐò¹¦ÄÜ£¬WÐÍͨ¹ýL-N¹©µç
²âÁ¿·¶Î§£º208-480AC
×î´ó¸ºÔØÄÜÁ¦£º1*SPDT£¬5A/250VAC
×î´ó¸ºÔØÄÜÁ¦£º5A/24VDC
µçÆøÊÙÃü£º´óÓÚ1*10000000´Î
µçÔ´µçѹ£º208-480VAC
ÈÏÖ¤£ºCE-UL-CSA
PPB01CM23£º 240 VAC 3-PH OVER/UNDER VOLT. RLY
PPB01CM23N£º PPB01CM23N 3-PHASE VOLTAGE LEVEL RELAY REV.3
PPB01CM48£º£º 480 VAC 3-PH OVER/UNDER VOLT. RLY
PPB01CM48N£º£º PPB01CM48N 3-PHASE VOLTAGE LEVEL RELAY REV.
PPB01CM48NW4£º PPB01CM48NW4 3-PHASE VOLTAGE LEVEL RELAY REV.3
PPB01CM48W4£º PPB01CM48W4 3-PHASE VOLTAGE LEVEL RELAY REV.3
PPB02CM23£º 240 VAC 3-PH ASYMMETRY RLY
PPB02CM48£º 480 VAC 3-PH ASYMMETRY RLY
PPC01DM23£º 240 VAC 3-PH VOLT. MULTIFUNCTION RLY
PPC01DM48£º 480 VAC 3-PH VOLT. MULTIFUNCTION RLY
PPC71DM23£º PPC71DM23 3-PHASE MONITORING RELAY REV.0
PPC71DM48£º PPC71DM48 3-PHASE MONITORING RELAY REV.0
