| Technical specifications |
| Input |
| Rated voltage value Vin rated |
400 V¡500 V |
| Voltage range |
320 V¡550 V |
| Wide-range input |
ÊÇ |
| Mains buffering at Iout rated, min. |
6 ms |
| Ï߯µÂÊ |
50 Hz/60 Hz |
| Rated line range |
47 Hz...63 Hz |
| ÊäÈëµçÁ÷ / [nicht versorgt - bei Nennwert der Eingangsspannung 120 V]/[nicht versorgt - Nennwert] |
1.1 A |
| Input current / at nominal level of the input voltage 500 V |
0.9 A |
| Switch-on current limiting (+25 ¡ãC), max. |
35 A |
| I2tÖµ |
0.7 A²¡¤s |
| Output |
| Êä³öµçѹ |
24 V |
| Total tolerance, static ¡À |
3 % |
| Static mains compensation, approx. |
0.1 % |
| Static load balancing, approx. |
0.2 % |
| Residual ripple peak-peak, max. |
100 mV |
| Spikes peak-peak, max. (bandwidth: 20 MHz) |
200 mV |
| Adjustment range |
24 V¡28.8 V |
| Product feature / output voltage adjustable |
ÊÇ |
| ¶¯×÷ÑÓ³Ùʱ¼ä |
2.5 s |
| Voltage increase time / of the output voltage / maximum |
500 ms |
| Êä³öµçÁ÷ |
20 A |
| Current range |
0 A¡20 A |
| delivered active power / typ. |
480 W |
| constant overload current / at short-circuit during run-up / typical |
23 A |
| short-term overload current / at short-circuit during operation / typical |
60 A |
| Duration of overloading ability for excess current / on short-circuiting during the operational phase |
25 ms |
| Parallel switching for enhanced performance |
ÊÇ |
| Numbers of parallel switchable units for enhanced performance |
2 |
| Efficiency |
| Efficiency at Vout rated, Iout rated, approx. |
90 % |
| Power loss at Vout rated, Iout rated, approx. |
53 W |
| Closed-loop control |
| Dynamic mains compensation (Vin rated ¡À15 %), max. |
1 % |
| Dynamic load smoothing (Iout: 50/100/50 %), Uout ¡À typ. |
2 % |
| Load step setting time 50 to 100%, typ. |
4 ms |
| Load step setting time 100 to 50%, typ. |
4 ms |
| Setting time / maximum |
10 ms |
| Protection and monitoring |
| Current limitation, typ. |
23 A |
| Êä³öµÄÌØÐÔ / ¶Ì·±£»¤ |
ÊÇ |
| Enduring short circuit current / Effective level / typical |
23 A |
| Safety |
| µçλ¸ôÀë |
ÊÇ |
| stray current / maximum |
3.5 mA |
| ºÏ¸ñÖ¤Ã÷ |
ÊÇ |
| ×ʸñÖ¤Ã÷ |
ÊÇ |
| CB approval |
·ñ |
| ·À»¤µÈ¼¶IP |
IP20 |
| EMC |
| Operating data |
| Ambient temperature / in operation |
0 ¡ãC¡70 ¡ãC |
| Ambient temparature / on transport |
-40 ¡ãC¡85 ¡ãC |
| Ambient temparature / in storage |
-40 ¡ãC¡85 ¡ãC |
| Mechanics |
| µçÆøÁ¬½ÓµÄ½á¹¹ÐÎʽ |
ÂÝ˨Á¬½Ó |
| ¿í¶È / Íâ¿ÇµÄ |
160 mm |
| ¸ß¶È / Íâ¿ÇµÄ |
125 mm |
| Éî¶È / Íâ¿ÇµÄ |
125 mm |
| °²×°¿í¶È |
160 mm |
| °²×°¸ß¶È |
225 mm |
| ¾»ÖØ |
2 kg |
| ²úÆ·ÌØµã / Íâ¿ÇµÄ / ¿É˳ÐòÅÅÁеĿÇÌå |
ÊÇ |
| ¹Ì¶¨ÀàÐÍ / ǽ±Ú°²×° |
·ñ |
| ¹Ì¶¨ÀàÐÍ / µ¼¹ì°²×° |
ÊÇ |
