| Input |
| Rated voltage value Vin rated |
400 V¡500 V |
| Voltage range |
320 V¡550 V |
| Wide-range input |
ÊÇ |
| Mains buffering at Iout rated, min. |
6 ms |
| Ï߯µÂÊ |
50 Hz/60 Hz |
| Rated line range |
47 Hz...63 Hz |
| ÊäÈëµçÁ÷ / [nicht versorgt - bei Nennwert der Eingangsspannung 120 V]/[nicht versorgt - Nennwert] |
1.1 A |
| Input current / at nominal level of the input voltage 500 V |
0.9 A |
| Switch-on current limiting (+25 ¡ãC), max. |
35 A |
| I2tÖµ |
0.7 A²¡¤s |
| Output |
| Êä³öµçѹ |
24 V |
| Total tolerance, static ¡À |
3 % |
| Static mains compensation, approx. |
0.1 % |
| Static load balancing, approx. |
0.2 % |
| Residual ripple peak-peak, max. |
100 mV |
| Spikes peak-peak, max. (bandwidth: 20 MHz) |
200 mV |
| Adjustment range |
24 V¡28.8 V |
| Product feature / output voltage adjustable |
ÊÇ |
| ¶¯×÷ÑÓ³Ùʱ¼ä |
2.5 s |
| Voltage increase time / of the output voltage / maximum |
500 ms |
| Êä³öµçÁ÷ |
20 A |
| Current range |
0 A¡20 A |
| delivered active power / typ. |
480 W |
| constant overload current / at short-circuit during run-up / typical |
23 A |
| short-term overload current / at short-circuit during operation / typical |
60 A |
| Duration of overloading ability for excess current / on short-circuiting during the operational phase |
25 ms |
| Parallel switching for enhanced performance |
ÊÇ |
| Numbers of parallel switchable units for enhanced performance |
2 |
