Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú QS-05N,QL-05P·½Ðνӽü¿ª¹Ø
²úÆ·Ãû³Æ£º QS-05N,QL-05P·½Ðνӽü¿ª¹Ø
ÐÍ ºÅ£º QS-05N,QL-05P
Æ· ÅÆ£º 28
QS-05N ,QS-05P,QL-05N,QL-05P̨Íå·½Ðͽӽü¿ª¹Ø£¬Ð¿¼Û¸ñ±ãÒË£¬µ«Ã»Óм«ÐÔ±£»¤£¬²¿·ÖÌæ´úPS-05N,PS-05P
1.·½Ðνӽü¿ª¹Ø
2.¿×µÄÖ±¾¶£ºM3
3.Êä³öÐÎʽ£ºNPN,PNP
4.¸ÐÓ¦¾àÀ룺5MM
5.µçѹ£º10-30VDC,2KHZ
·½Ðͽӽü¿ª¹Ø
LS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
LS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
LS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
LS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
SP-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
SP-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
BS-02N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-02P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë2.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
BS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PP-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PP-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   800Hz
PS-04N-V Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PS-04P-V Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm ÉÏ·½¸ÐÓ¦ 10-30VDC   2KHz
PS-04N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
PS-04P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë4.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   2KHz
PS-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-05N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-05P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-08N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë5.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PL-08P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë8.0mm Ç°Ãæ¸ÐÓ¦ 10-30VDC   800Hz
PS-10N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-10P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-15N   Êä³öÐÎʽNPN ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-15P   Êä³öÐÎʽPNP ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 10-30VDC   500Hz
PS-10S Êä³öÐÎʽSCR   ¸ÐÓ¦¾àÀë10mm  Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
PS-15S Êä³öÐÎʽSCR   ¸ÐÓ¦¾àÀë15mm  Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
PS-05S Êä³öÐÎʽSCR   ¸ÐÓ¦¾àÀë5mm  Ç°Ãæ¸ÐÓ¦ 90-250VAC  20Hz
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
