²úÆ·Ãû³Æ£º
LED»·ÐιâÔ´
ÐÍ ºÅ£º
LJ-LX03
ÐͺÅLJ-LX03 LED »·Ð͹âÔ´LED Light Source
¹¦ÄÜFeature
ÎÞÉÁ˸ No Flash
½ÚÄÜÊ¡µç Save Power
³¬³¤20,000СʱʹÓÃÊÙÃü Super Long Life 20,000hrs
¹âÔ´ÁÁ¶È¿Éµ÷ 0~100%Adjustable Light Intensity0~100%
ɫβ»±ä Constant color temperature
µÍ·¢ÈÈÁ¿ Low Heat
¹æ¸ñ Specification
ÊäÈëµçѹ Input Voltage AC100~240V
ÊäÈëµçѹƵÂÊ Input Power Frequency 50/60Hz
ÊäÈ빦ÂÊ Input Power 4W
Êä³öµçÁ÷ Output Current 180mA
Êä³öµçÁ÷¿ØÖÆ·½Ê½ Output Type Ö±Á÷¶¨µçÁ÷¿ØÖÆ·½Ê½ DC Lighting Type
¹âÔ´ÁÁ¶È¿Éµ÷·¶Î§ Light Intensity Adjustable 0~100%
LED¹âÉ« LED Color °×É«¼°ÆäËü¹âÉ«¿ÉÑ¡ White or Other Light Color
LEDÊÙÃü LED Life 20,000Сʱ 20,000hrs
¹¤×÷¾àÀë Working Distance 55~160mm
¹¤×÷»·¾³ÎÂʪ¶È Temperature and Humidity 0~45¡æ/16~85%RH
¹¤×÷ÄÚ¾¶ Ring Diameter Inside Max§¶61mm
ÍâÐγߴç(mm) Dimension(mm) Íâ¾¶§¶95x¸ßx29x³¤125.5
