| Technical specifications |
| Input |
| Supply voltage / 1 / at AC / nominal value |
120 V |
| Supply voltage / 2 / at AC / nominal value |
230 V |
| Input voltage / 1 / at AC |
85 V¡132 V |
| Input voltage / 2 / at AC |
170 V¡264 V |
| Wide-range input |
·ñ |
| Mains buffering at Iout rated, min. |
20 ms |
| Ï߯µÂÊ |
50 Hz/60 Hz |
| Rated line range |
47 Hz...63 Hz |
| ÊäÈëµçÁ÷ / [nicht versorgt - bei Nennwert der Eingangsspannung 120 V]/[nicht versorgt - Nennwert] |
4.1 A |
2 A |
| Switch-on current limiting (+25 ¡ãC), max. |
65 A |
| Duration of current limiting / at 25 ¡ãC / typical |
3 ms |
| I2tÖµ |
3.3 A²¡¤s |
| Output |
| Êä³öµçѹ |
24 V |
| Total tolerance, static ¡À |
3 % |
| Static mains compensation, approx. |
0.1 % |
| Static load balancing, approx. |
0.5 % |
| Residual ripple peak-peak, max. |
150 mV |
| Residual ripple peak-peak, typ. |
50 mV |
| Spikes peak-peak, max. (bandwidth: 20 MHz) |
240 mV |
| Spikes peak-peak, typ. (bandwidth: 20 MHz) |
150 mV |
| Adjustment range |
22.8 V¡28 V |
| Product feature / output voltage adjustable |
ÊÇ |
| ¶¯×÷ÑÓ³Ùʱ¼ä |
0.1 s |
| Voltage rise, typ. |
50 ms |
| Êä³öµçÁ÷ |
10 A |
| Current range |
0 A¡12 A |
| delivered active power / typ. |
288 W |
| short-term overload current / at short-circuit during run-up / typical |
30 A |
| Duration of overloading ability for excess current / on short-circuiting during the start-up |
100 ms |
| short-term overload current / at short-circuit during operation / typical |
33 A |
| Duration of overloading ability for excess current / on short-circuiting during the operational phase |
200 ms |
| Parallel switching for enhanced performance |
ÊÇ |
| Numbers of parallel switchable units for enhanced performance |
2 |
