TZ-7100,TZ-7110СÐÍÏÞ¶¯¿ª¹Ø,ÉîÛÚÌìΪÏÖ»õÓżÛ
ÌØÕ÷¡¡.Òý¶¯Æ÷ÖÖÀà¶à£¬ÇÒÓж¯×÷λÖÿɵ÷ÕûÖ®Éè¼Æ(Èç(TZ-7121)¡¡
.Íâ¿Ç°ü¸²Ç¿»¯Ëܽº£¬·ÀË®¡¢·ÀÓÍ¡¢½ÏTMÐÍ΢¶¯¿ª¹ØÓиü¸ßµÄ»úеǿ¶È£¬Äͳå»÷¡£
·¹æ¸ñ¡¡£®¶î¶¨Öµ¶î¶¨µçѹ(V)·Çµç¸ÐÐÔ¸ºÔØ(A)µç¸ÐÐÔ¸ºÔØ(A)µç×èÐÔ¸ºÔصÆÅݸºÔصç¸ÐÐÔ¸ºÔØÂí´ïµç×èN.C.N.O.N.C.N.O.N.C.N.O.N.C.N.O.125 VAC250 VAC480 VAC1010331.52.51.251.50.7510102.552.531.51.50.758 VAC14 VAC30 VAC125 VAC250 VAC101080.50.2531.531.531.50.40.26660.050.03656552.50.050.03×¢£º
1.µç¸ÐÐÔ¸ºÔØ£º¹¦ÂÊÒòËØ=0.4£ºÊ±¼ä³£Êý=7msec¡¡¡¡
2.µÆÅݸºÔØÖ®Í»ÈëµçÁ÷ΪÎȶ¨µçÁ÷Ö®10±¶£¬Âí´ï¸ºÔØÖ®Í»ÈëµçÁ÷ΪÎȶ¨µçÁ÷Õâ6±¶¡£¡¡
.½ÓµãÐÍʽ¡¡£®ÌØÐÔ¡¡
²Ù×÷ËÙ¶È¡¡0.01mmÖÁ50cm/sec(ËøÖùÈûÐÍ)¡¡
¶¯×÷ƵÂÊ¡¡120´Î/·Ö¡¡
½Óµãµç×è¡¡15mΩÒÔÏÂ(³õÆÚ)¡¡
¾øÔµµç×è¡¡100mΩÒÔÉÏ(ÔÚ500VDC)¡¡
Ä͵çѹ¡¡·ÇÁ¬Ðø¶Ë×Ӽ䡡1,000VAC, 50/60Hz³ÖÐø1·ÖÖÓ¡¡
ÔØµçÁ÷ºÍÎÞÔØµçÁ÷Áã¼þ¼ä¡¡Óë¶Ë×ӺͽӵØÖ®¼ä¡¡
1,500VAC 50/60Hz³ÖÐø1·ÖÖÓ¡¡Õñ¶¯¡¡
Îó¶¯×÷Ä;㺡¡10ÖÁ50Hz, 1.5mmË«Õñ·ù¡¡³å»÷¡¡
»úеÄ;ãº1,000m/s2(Ô¼.100G’S)¡¡
Îó¶¯×÷Ä;ãº300m/s2(Ô¼.30G’S)¡¡
ÖÜΧζȡ¡Ê¹ÓÃʱ£º-10ÖÁ+80¡æ¡¡
ʪ¶È¡¡95%RHÒÔÏÂ(ÔÚ+20ÖÁ+35¡æ)¡¡
ʹÓÃÊÙÃü¡¡
»úе£º 10,000,000´ÎÒÔÉÏ(ÔڶOTÖµÏÂ)
µçÆø£º 500,000´ÎÒÔÉÏ¡¡ÖØÁ¿¡¡Ô¼ 60g¡¡
±£»¤¹¹Ôì¡¡IEC : IP65
ÐÍʽTZ-7100TZ-7110TZ-7310TZ-7311TZ-7312TZ-7120TZ-7140TZ-7121TZ-7141TZ-7124OF¡¡
×î´ó600g600g600g600g600g150g220g180g240g200gRF¡¡
×îС100g100g100g100g100g40g60g50g80g80gPT¡¡
×î´ó2.0mm2.0mm2.0mm2.0mm2.0mm13.5mm8.5mm11.0mm6.5mm6.5mmOT¡¡
×îС0.8mm5.0mm6.0mm6.0mm6.0mm4.0mm2.5mm3.0mm2.0mm2.0mmMD¡¡
×î´ó0.8mm0.8mm0.8mm0.8mm0.8mm3.2mm2.0mm2.4mm1.5mm1.5mmOP¡¡¡¡¡¡¡¡
21.8 ± 1.2mm33.3 ±1.2mm25 ± 1mm25 ± 1mm40 ± 1mm40 ± 1mm50 ± 1mmFP¡¡¡¡¡¡¡¡
35mm32mm46 ÐÍʽTZ-7144TZ-7166 OF¡¡
×î´ó280g120gRF¡¡
×îС100gPT¡¡
×î´ó6.5mm25mmOT¡¡
×îС2.0mm11mmMD¡¡
×î´ó1.5mmOP50 ± 1.2mmFP¡¡56mm
