| Transmission rate |
| ´«ÊäÂÊ / ÔÚ½Ó¿Ú 1 ´¦ |
10 Mbit/s¡100 Mbit/s |
| Interfaces |
| Number of electrical connections |
- at interface 1 / in accordance with Industrial Ethernet
2 |
1 |
| Supply voltage, current consumption, power loss |
| µçѹÀàÐÍ / ¹©µçµçѹ |
DC |
| ¹©µçµçѹ |
5 V |
- [nicht versorgt - extern]
24 V |
| Relative positive tolerance / at 24 V / with DC |
20 % |
| Relative negative tolerance / at 24 V / with DC |
15 % |
| ÏûºÄµÄµçÁ÷ |
- [nicht versorgt - aus R¨¹ckwandbus] / [nicht versorgt -bei24 V] / [nicht versorgt - bei DC] / [nicht versorgt - typisch]
0.2 A |
- [nicht versorgt - aus externer Versorgungsspannung] /[nichtversorgt - bei 24 V] / [nicht versorgt - bei DC] / [nicht versorgt -typisch]
0.16 A |
0.2 A |
| ËðºÄÓÐЧ¹¦ÂÊ |
5.8 W |
| Permitted ambient conditions |
| »·¾³ÎÂ¶È |
-40 ¡ãC¡70 ¡ãC |
-40 ¡ãC¡70 ¡ãC |
| Ïà¶ÔµÄ¿ÕÆøÊª¶È / ÔÚ25 ¡ãCʱ / ÎÞÀäÄý / ÔÚÔËÐн׶Π/ ×î´óµÄ |
95 % |
| ·À»¤µÈ¼¶IP |
IP20 |
| Design, dimensions and weight |
| ¿í¶È |
40 mm |
| ¸ß¶È |
125 mm |
| Éî¶È |
120 mm |
| ¾»ÖØ |
0.22 kg |
