Form Factor |
3.5" Single Board Computer |
Processor |
Onboard AMD Dual-core T56N 1.65 GHz |
Memory |
1 x DDR3 1066/1333 SO-DIMM up to 4.0 GB |
Chipset |
AMD A55E FCH |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Serial ATA Interface |
2 x Serial ATA II interface up to 300MB/s |
| SSD Interface |
1 x CFast socket on solder side |
VGA Interface |
Integrated AMD Radeon HD 6300 series graphic |
LVDS Interface |
18-bit single channel LVDS interface |
| DVI Interface |
onboard 20-pin DVI interface |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
1 x Intel® 82583V Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
Mini-PCIe & Mini-PCI sockets |
Internal I/O Port |
1 x RS232/422/485 & 4 x RS232, 1 x GPIO, 1 x CDIN, 1 x SMBus,
1 x Audio, 1 x IrDA, 4 x USB2.0, 1 x LPT, 1 x DVI, 1 x LVDS |
External I/O Port |
1 x PS/2 keyboard/mouse, 1 x RJ45 LAN, 1 x VGA, 2 x USB2.0,
1 x RS232 |
Power Requirement |
DC 5V ~ 24V input |
Board Dimension |
146mm x 101 mm (L x W) |
Temperature |
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC |
