Form Factor |
Pico-ITX motherboard |
Processor |
Onboard AMD Dual-core T56N 1.65 GHz |
Memory |
1 x 204-pin DDR3 1066/1333 SO-DIMM up to 4.0 GB |
Chipset |
AMD A55E FCH |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Serial ATA Interface |
1 x SATAII interface. ( Note: Supply 5V power from the board only ) |
VGA Interface |
Integrated AMD Radeon HD 6300 series graphic |
LVDS Interface |
18-bit single channel LVDS interface. ( LP-180X only ) |
| DVI Interface |
onboard 20-pin DVI interface. ( LP-180D only ) |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
1 x Intel® 82583V Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
Mini-PCIe socket |
Internal I/O Port |
2 x RS232, 4 x USB2.0, 1 x LPC, 1 x DC_out |
External I/O Port |
1 x PS/2 keyboard/mouse, 1 x RJ45 LAN, 1 x VGA |
Power Requirement |
Single DC 5V input |
Board Dimension |
100mm x 72 mm (L x W) |
Temperature |
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC |
