| Form Factor |
Mini barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board / CPU |
Inside Motherboard : LV-67G
Support CPU : 2nd generation Intel® Core8482; i7/i5/i3 in LGA 1155 |
| Drive Bay |
1 x internal 3.5¡± HDD or 2 x internal 2.5¡± HDD space or
2 x external 2.5¡± HDD space by drive cage |
| Extensive slot |
1 x PCI-Express X16 slot , Mini-PCIe & Mini-PCI sockets |
| Thermal Control |
1 x 6 cm system cooling Fan |
| Front Panel |
Power On / Off switch
LED for Power On/Off and HDD activity
2 x USB ports
Mic-in / Ear phone |
| Rear Side I/O |
1 x PS/2 Keyboard/Mouse
1 x VGA
1 x DVI
1 x RS232/422/485 + 2 x RS232
4 x USB 2.0
2 x RJ-45 Intel® Giga LAN
2 x cutout for DB9 COM port ( Can't be used when use 3.5" HDD or
external 2.5" HDD )
1 x cutout for antenna |
| Environment |
Operating Temperature: 0 ~ 40ºC |
| Power supply |
250 watt power supply |
| Dimension |
300 x 220 x 80 mm | To enhance your industrial embedded applied application, COMMELL Industrial Computer provides industrial Single Board Computer (SBC), industrial embedded applied server, workstation, transaction, client terminal platform and related products and integration service. The product lines of COMMELL include: http://www.commell.cn/product_2.asp?id=282 |
¿Ïí®µÄ¸Å¿ö
̨Íå¿Ïí®£¨COMMELL£© ÖÂÁ¦ÓÚÌṩ¸ßÆ·Öʹ¤Òµ¼ÆËã»úƽ̨¼°½â¾ö·½°¸£¬¸üרҵ¡¢¸üÌù½ü¡¢¸üÖ±½ÓµÄ·þÎñÓÚ¹¤ÒµPCÊг¡¡£
ƾ½èרҵ»¯µÄR&D¼°QAÍŶӣ¬¿Ïí®Éè¼Æ¡¢ÖÆÔì¡¢ÐÐÏú°å¿¨¼¶¡¢ÏµÍ³¼¶Ó빤ҵǶÈëʽ²úƷϵͳ¼¯³É·þÎñÈ«Çò·¶Î§µÄIPC/SBCÁìÓò£¬¾ÏúÉÌÓëϵͳ¼¯³ÉÉÌÄܸüÓÐЧ¸üÈÝÒ×µÄÉý¼¶ËûÃǵĽâ¾ö·½°¸¡£
¿Ïí®³ýÁËΪÖ÷Á÷IPCÊг¡Ìṩ¸ßÆ·Öʱê×¼²úÆ·Ö®Í⣬ͬʱҲ¿É¸ù¾Ý¿Í»§µÄ²»Í¬ÐèÇóÌṩרҵµÄODM¼°OEM²úÆ·Óë·þÎñ£¬ÒÔ¸ü¹ã·ºµÄ·þÎñÓÚ¹¤ÒµÇ¶Èëʽ´¦ÀíÆ½Ì¨¼°¹¤ÒµPCµÄÓ¦ÓÃÌṩ¸ü¼ÑµÄ½â¾ö·½°¸¡£
½ñÌ죬ÔÚÊÀ½ç¸÷µØÔ½À´Ô½¶àµÄ»ùÓÚPCµÄÓ¦ÓóöÏÖÔÚÈËÃǵÄÉí±ß£¬¹¤Òµ¡¢Éú»îÓéÀÖµÄ×Ô¶¯»¯ÐèÇóÕýÖð²½ÉîÈëÎÒÃǵÄÉú»î²¢°çÑÝ×ÅÔ½À´Ô½ÖØÒªµÄ½ÇÉ«¡£Îª¸üÃÀºÃµÄÉú»î£¬COMMELL½«¾¡È«Á¦ÎªÊÀ½ç¼°Êг¡Ìṩ¸üºÃµÄ¹¤ÒµPC½â¾ö·½°¸¡£
¿Ïí®µÄʹÃü
Ϊ¸üרҵ¡¢¸üÌù½ü¡¢¸üÖ±½ÓµÄ·þÎñÓÚ¹¤ÒµPCÊг¡£¬¿Ïí®×Ô2001ÄêÆðÔÚÊг¡ÉϽ¨Á¢ÁË×ÔÓÐÆ·ÅÆ¡£Æ¾½èÔÚIPCÁìÓò¶àÄê·á¸»µÄODM / OEM¾Àú¼°ÄÜÁ¦£¬¿Ïí®³ÉΪ¸ßƵ¼°Ç¶Èëʽµ¥°åµçÄÔµÄÁìµ¼³§ÉÌÖ®Ò»¡£
Ìṩ¹¤Òµ¼ÆËãÆ½Ì¨½â¾ö·½°¸
¿Ïí®µÄÄ¿±êÊÇΪ¹¤Òµ¼ÆËã»úÓ¦ÓÃÌṩ¸ü¼ÑµÄ½â¾ö·½°¸£¬Ìṩ¸ß¿É¿¿ÐÔ¡¢¼æÈÝÐÔ¡¢Áé»îµÄ¿ÉÀ©³äÐÔ£¬¸ßЧµ×¹¦ºÄ¼°¶Ô¹¤Òµ¼ÆËãÆ½Ì¨µÄ³¤Ð§Ö§³ÖµÈÒ»ÕûÌ×È«ÃæµÄ¹¤Òµ¼ÆËã½â¾ö·½°¸¡£
¿Ïí®µÄȫϵÁвúÆ·
»ùÓÚ¶àÄê·á¸»µÄODM/OEM¾Àú£¬Ñз¢¡¢Éú²ú¼°Æ·±£ÄÜÁ¦£¬¿Ïí®ÌṩÆëÈ«µÄϵÁвúÆ·°üÀ¨£º¹¤ÒµPICMG CPU¿¨¡¢Ç¶ÈëʽºÍminiboard¡¢PC/104ǶÈëʽ±ê×¼×é¼þ¼°¹¤ÒµPCƽ̨¡£
¹¤ÒµPCƽ̨
ΪÂú×㹤ҵ·þÎñ¡¢¹¤×÷Õ¾¼°½ÚµãÖն˵ÄÓ¦Ó㬿Ïí®Ìṩ¿í·ºµÄ»ùÓÚPC-based¹¤Òµ¼ÆËã´¦ÀíÆ½Ì¨£¬´ÓIntel Pentium 4¼¶µ½386SX-40·ûºÏ¹¤Òµ±ê×¼µÄPICMG¡¢ PISA¡¢ ISA¡¢ EBX¡¢ ETX ¼°ÆäËû¹æ¸ñ¡£Æ¾½èIntelµÄ×îмܹ¹¼°¿Ïí®µÄ¿Æ¼¼ÊµÁ¦£¬¿Ïí®µÄ¹¤ÒµPCÓµÓÐÇ¿´óµÄ¼ÆËã´¦ÀíÄÜÁ¦£¬³öÉ«µÄÓ°Òô/ͼÏñЧ¹û¡¢ÍøÂçÄÜÁ¦£¬ ISA 64mA¸ßËÙÇ÷¶¯£¬Ç¶Èëʽ¹Ì̬µç×ÓÅÌ£¬¶àÖÖPCI/ISAÀ©Õ¹½Ó¿ÚΪ¹¤Òµ¼ÆËãÆ½Ì¨ÌṩÁ˸߿ɿ¿ÐÔ£¬¸ßÖ´ÐÐÁ¦¡¢¼æÈÝÐԺͷ½±ãÁé»îµÄÀ©Õ¹ÐÔÄÜ¡£
ǶÈëʽµ¥°åµçÄÔ
¿Ïí®Ìṩ¹¤ÒµÇ¶Èëʽµ¥°åµçÄÔ°üÀ¨£º PICMG CPU ¿¨£¬PISA/PCI/ISAǶÈëʽslot PC£¬CompactǶÈëʽ miniboard£¬PC/104ºÍETX based±ê׼ģ¿éPC£¬¼°¹¤Òµ¼¶¿É¶¨ÖÆPC-based¼ÆËãÆ½Ì¨¡£¿Ïí®·þÎñÆ÷/¹¤×÷Õ¾¼¶µÄ PICMG CPU¿¨ÓµÓÐÇ¿´óµÄС˵Êý¾Ý´¦ÀíÄÜÁ¦£»Ç¶Èëʽµ¥°åµçÄÔϵÁоßÓе׹¦ºÄ£¬Ãâ·çÉÈ£¬¸ßЧÂʼ°¸ß¶ÈÕûºÏµÄÌØÐÔ¡£Ç¶ÈëʽMiniboard·ûºÏCompact½ô´ÕÐͰ忨µÄ³ß´ç£¬µ×¹¦ºÄ¡£²ÉÓÃall-in-one¼¯³ÉÁË4 COM£¬ 2 LPT£¬ GPIO£¬ PC/104-plus£¬ÉÁÅÌFlash Disk£¬LCDºÍÆäËû½Ó¿ÚµÈÍêÈ«Âú×ãǶÈëʽӦÓ᣶ÔÓÚmini-PCÊг¡£¬¿Ïí®ÌṩÁ˳ߴçΪ170 x 170 mmµÄmini-ITX Ö÷°å¡£¿Ïí®µÄmini-ITXϵÁвúƷΪ¹¤ÒµPCºÍÏû·ÑPCÊг¡ÌṩÁ˺ÏÊÊÇÒ¸ßÆ·ÖʵĽâ¾ö·½°¸¡£ ƾ½èÇ¿´óµÄÑз¢ÊµÁ¦£¬¿Ïí®ÓÚ2002ÄêÔÚÈ«ÇòÊ×·¢ÁËPentium 4¼¶µÄmini-ITX½â¾ö·½°¸¡£
¹¤ÒµÇ¶ÈëʽÍâΧÉ豸
¶ÔÓÚ¹¤Òµ¼ÆËãÓ¦Ó㬿Ïí®ÌṩǶÈëʽ½Ó¿Ú¼°ÍâÉèÄ£¿éÒÔ°ïÖúϵͳ¼¯³ÉÕß½¨Á¢×Ô¼ºµÄ»ùÓÚǶÈëʽģ¿é»¯µÄ½â¾ö·½°¸£¬°üÀ¨PCI-based PC/104-plusÄ£¿é£¬ISA-based PC/104Ä£¿é£¬¹Ì̬µç×ÓÅÌ£¬´®¿ÚºÍGPIOÄ£¿é£¬ AC/DCºÍDC/DCµçÔ´ÊÊÅäÆ÷£¬¿ª·Åʽ·À±¬LCDÃæ°åºÍÆäËûÄ£¿éÍâÉè¡£ÕâЩģ¿éÍâÉèÄÜʹϵͳ¼¯³ÉÕ߸ü·½±ãÁé»îºÍ¸ü¾ßЧÂÊ¡£
¿ÍÖÆ»¯ODM / OEM·þÎñ
¿Ïí®²»½öÌṩ±ê×¼µÄ²úÆ·£¬»¹Ìṩ¿ÍÖÆ»¯ODM/OEM¹¤ÒµPCƽ̨¡£¡°°ïÖú¿Í»§½¨Á¢×Ô¼ºµÄÓÅÊÆ¡±ÊÇ¿Ïí®×¨Òµ»¯ODM / OEM·þÎñµÄ×ÚÖ¼£¬Í¬Ê±Ò²ÊǸüºÃµÄ·þÎñÓÚ¹¤ÒµPCÊг¡µÄ²»Í¬ÁìÓò¡£
