²úÆ·Ãû³Æ: I-7188E8
²úÆ·½éÉÜ: 7¡ÁRS-232£¬1¡ÁRS-485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷¡£
²úÆ·ÌØµã: ´ø80188 40MHzǶÈëʽCPU
Ö§³Ö¶àÖÖTCP/IP¹¦ÄÜ£¬°üÀ¨TCP,UDP,IP,ICMP,ARP
Ô¶³ÌÅäÖúÍÕï¶Ï
COM¿ÚÇý¶¯Ö§³ÖÖжϺÍ1K¶ÓÁÐÊäÈëºÍÊä³ö»º³å
ÄÚ½¨EEPROM
7¶ÎLEDÏÔʾ(I-7188E8D)
ÄÚ½¨MiniOS7²Ù×÷ϵͳ
²úÆ·²ÎÊý: CPU
CPU:80188 40MHz»ò¼æÈÝÐÔCPU
Äڴ棺384K bytes
ÉÁ´æ£º512K bytes
EEPROM£º2K Bytes
¿´ÃŹ·Ê±ÖÓ£ºÓÐ
ͨÐŽӿÚ
COM1£ºRS-232 (TXD, RXD, RTS, CTS, GND)
COM2£ºRS-485 (D2+, D2-)
COM3£ºRS-232 (TXD, RXD, GND)
COM4£ºRS-232 (TXD, RXD, GND)
COM5£ºRS-232 (TXD, RXD, GND)
COM6£ºRS-232 (TXD, RXD, GND)
COM7£ºRS-232 (TXD, RXD, GND)
COM8£ºRS-232 (TXD, RXD, GND)
Íø¿Ú£º10BASE-T
LEDÏÔʾ
5λ7¶ÎÊýÂë¹Ü£ºÓУ¨I-7188E8D£©
ϵͳLEDÏÔʾ£ºÓÐ
³ß´ç
I-7188E8(D)£º123 mm x 72 mm x 33 mm ( W x L x H )
²Ù×÷»·¾³
¹¤×÷ζȣº-25 ¡ãC ~ 75 ¡ãC
´æ´¢Î¶ȣº-40 ¡ãC ~ 80 ¡ãC
µçÔ´
±£»¤£ºµçÔ´·´½Ó±£»¤
¹©µçµçѹ£º10 ~ 30 VDC
¹¦ºÄ£ºI-7188E8 2W , I-7188E8D 3W
¶©»õÐÅÏ¢£º
I-7188E8 CR 7¶Ë¿ÚRS-232£¬1¶Ë¿ÚRS-485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷
I-7188E8D CR ´øLEDÏÔʾµÄI-7188E8
Ïà¹Ø²úÆ·£º
I-7188E5 4¶Ë¿ÚRS-232£¬1¶Ë¿ÚRS-485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷
I-7188E3 1¶Ë¿ÚRS-232£¬1¶Ë¿ÚRS-485£¬1¶Ë¿ÚRS-422/485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷
I-7188EX-MTCP I-7188EX-MTCP / I-7188EXD-MTCP MudbusÍø¹Ø
¿ÉÑ¡¸½¼þ£º
PWR-24/110 24V/0.2AµçÔ´(110V)
PWR-24/220F 24V/0.2AµçÔ´(220V60Hz
¹©Ó¦ÆäËüÈÈÂô²úÆ·£º
ǶÈëʽ¿ØÖÆÆ÷
* I-7188/512 CR CPU:80188 40MHz ´ø512K FlashºÍ256K SRAMµÄǶÈëʽ¿ØÖÆÆ÷£¬ËÄ´®¿Ú£¬MINIOS7²Ù×÷ϵͳ
* I-7188D/512 CR ´øLEDÏÔʾµÄI-7188/512 CR
* I-7188/DOS/512 CR CPU:80188 40MHz ´ø512K FlashºÍ256K SRAMµÄǶÈëʽ¿ØÖÆÆ÷£¬COM1~4£¬ROMDOS²Ù×÷ϵͳ
* I-7188D/DOS/512 CR CPU:80188 40MHz ´ø512K FlashºÍ256K SRAMµÄǶÈëʽ¿ØÖÆÆ÷£¬COM1~4£¬ROMDOS²Ù×÷ϵͳ£¬´øLEDÏÔʾ
* I-7188XA CR CPU:80188 40MHz Ö§³ÖIOÀ©Õ¹×ÜÏßµÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬512K SRAM£¬2·DI£¬2·DO£¬Ëĸö´®¿Ú£¬MINIOS7°æ±¾
* I-7188XAD CR CPU:80188 40MHzÖ§³ÖIOÀ©Õ¹×ÜÏßµÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬512K SRAM£¬2·DI£¬2·DO£¬Ëĸö´®¿Ú£¬MINIOS7°æ±¾£¬´øLEDÏÔʾ
* I-7188XB-512 CR CPU:80188 40MHz Ö§³ÖI/OÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬512K SRAM £¬512K flash £¬´®¿ÚΪCOM1£¬COM2 £¬²Ù×÷ϵͳΪMiniOS7
* I-7188XBD-512 CR CPU:80188 40MHz Ö§³ÖI/OÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬512K SRAM £¬512K flash £¬´®¿ÚΪCOM1£¬COM2 £¬²Ù×÷ϵͳΪMiniOS7£¬´øLEDÏÔʾ
* I-7188XC-512 CR CPU:80188 20MHz Ö§³ÖIOÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬128K SRAM£¬2·DI£¬3·DO£¬Á½¸ö´®¿Ú£¬MINIOS7°æ±¾
* I-7188XCD-512 CR CPU:80188 20MHz Ö§³ÖI/OÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬128K SRAM £¬512K flash £¬´®¿ÚΪCOM1£¬COM2 £¬²Ù×÷ϵͳΪMiniOS7£¬´øLEDÏÔʾ
* I-7188XC/512/RTC CR CPU:80188 20MHz Ö§³ÖI/OÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬128K SRAM £¬512K flash £¬´®¿ÚΪCOM1£¬COM2 £¬²Ù×÷ϵͳΪMiniOS7£¬´øÊµÊ±Ê±ÖÓ
* I-7188XCD/512/RTC CR CPU:80188 20MHz Ö§³ÖI/OÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬128K SRAM £¬512K flash £¬´®¿ÚΪCOM1£¬COM2 £¬²Ù×÷ϵͳΪMiniOS7£¬´øLEDÏÔʾ
ÖÇÄÜͨѶ¿ØÖÆÆ÷
* I-7521 CR ¿ÉѰַµÄRS485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485,1¸öRS485
* I-7521D CR ´øLEDÏÔʾµÄI-7521
* I-7522 CR ¿ÉѰַµÄRS485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485£¬1¸öRS485£¬1¸öRS232
* I-7522D CR ´øLEDÏÔʾµÄI-7522
* I-7522A CR ¿ÉѰַµÄRS422/485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485£¬1¸öRS485£¬1¸öRS422
* I-7522AD CR ´øLEDÏÔʾµÄI-7522A
* I-7523 CR ¿ÉѰַµÄRS485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485£¬1¸öRS485£¬2¸öRS232
* I-7523D CR ´øLEDÏÔʾµÄI-7523
* I-7524 CR ¿ÉѰַµÄRS485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485£¬1¸öRS485£¬3¸öRS232
* I-7524D CR ´øLEDÏÔʾµÄI-7524
* I-7527 CR ¿ÉѰַµÄRS485µ½RS232ת»»Æ÷£¬Ö§³Ö1¸öRS232/RS485£¬1¸öRS485£¬6¸öRS232
* I-7527D CR ´øLEDÏÔʾµÄI-7527
ǶÈëʽ Internet / Ethernet¿ØÖÆÆ÷
* I-7188EA CR ´ø10MÒÔÌ«Íø,512K Flash£¬512K SRAM£¬6·DI£¬7·DO£¬Á½¸ö´®¿Ú£¬MINIOS7°æ±¾
* I-7188EAD CR ´øLEDÏÔʾµÄI-7188EA CR
* I-7188EX CR Ö§³ÖI/OÀ©Õ¹£¨14·Óû§¶¨ÒåI/O£©£¬´ø10MÒÔÌ«Íø£¬512K Flash£¬512K SRAM£¬Á½¸ö´®¿Ú£¬MINIOS7°æ±¾
* I-7188EXD CR ´øLEDÏÔʾµÄI-7188EX CR
I-7188EF-016 CR ´ø10MÒÔÌ«Íø£¬512K Flash£¬512K SRAM£¬Á½¸ö´®¿Ú£¬MINIOS7°æ±¾ Ö§³Ö250Kbps Frnet×ÜÏß
I-7188EFD-016 CR ´øLEDÏÔʾµÄI-7188EF-016 CR
Internet ͨѶ¿ØÖÆÆ÷
* I-7188E1 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬¾ßÓÐ1¸öRS232
* I-7188E1D CR ´øLEDÏÔʾµÄI-7188E1D CR
* I-7188E2 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³Ö1¸öRS232ºÍ1¸öRS485
* I-7188E2D CR ´øLEDÏÔʾµÄI-7188E2 CR
* I-7188E3 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³Ö1¸öRS232£¬1¸öRS485£¬1¸öRS422/485ºÍ4·DI£¬4·DO
* I-7188E3D CR ´øLEDÏÔʾµÄI-7188E3 CR
* I-7188E3-232 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³ÖÁ½¸öRS232£¬1¸öRS485ºÍ4·DI£¬4·DO
* I-7188E3D-232 CR ´øLEDÏÔʾµÄI-7188E3£232 CR
* I-7188E4 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³ÖÈý¸öRS232ºÍ1¸öRS485
* I-7188E4D CR ´øLEDÏÔʾµÄI-7188E4 CR
* I-7188E5 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³ÖËĸöRS232ºÍ1¸öRS485
* I-7188E5D CR ´øLEDÏÔʾµÄI-7188E5 CR
* I-7188E5-485 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³ÖËĸöRS485ºÍ1¸öRS232
* I-7188E5D-485 CR ´øLEDÏÔʾµÄI-7188E5£485 CR
* I-7188E8 CR ´®¿ÚתÒÔÌ«ÍøµÄ¿É±à³ÌǶÈëʽ¿ØÖÆÆ÷£¬Ö§³ÖÆß¸öRS232ºÍ1¸öRS485
* I-7188E8D CR ´øLEDÏÔʾµÄI-7188E8 CR
Modbus/TCPǶÈëʽ¿ØÖÆÆ÷
I-7188E2-MTCP CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬI-7188E2 CR
I-7188E2D-MTCP CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬI-7188E2D CR
* I-7188EX-MTCP CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬI-7188EX-512 CR
* I-7188EXD-MTCP CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬI-7188EXD-512 CR
ISaGRAFǶÈëʽ¿ØÖÆÆ÷
* I-7188XG CR Ö§³ÖIOÀ©Õ¹µÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬512K SRAM£¬Á½¸ö´®¿Ú£¬Ö§³ÖISaGRAF±à³Ì
* I-7188XGD CR ´øLEDÏÔʾµÄI-7188XG CR
* I-7188EG CR Ö§³ÖIOÀ©Õ¹£¬´ø10MÒÔÌ«Íø£¬512K Flash£¬512K SRAM£¬Á½¸ö´®¿Ú£¬Ö§³ÖISaGRAF±à³Ì
* I-7188EGD CR ´øLEDÏÔʾµÄI-7188EG CR
7186EǶÈëʽ Internet / Ethernet¿ØÖÆÆ÷
uPAC-5001 CR ¦ÌPAC-5001 ÊÖÕÆÐͿɱà³Ì×Ô¶¯»¯¿ØÖÆÆ÷£¬Ê¹ÓÃCÓïÑÔ½øÐпª·¢£¬512K SRAM
uPAC-5001D CR ´øLEDÏÔʾµÄUPAC-5001
uPAC-5001-FD CR ´ø64MB FlashµÄuPAC-5001 CR
uPAC-5001D-FD CR ´øLEDÏÔʾµÄUPAC-5001-FD
¦ÌPAC-5001P CR ´øPoEµÄuPAC-5001 CR
¦ÌPAC-5001PD CR ´øLEDÏÔʾµÄ¦ÌPAC-5001P CR
uPAC-5002 CR 768KBµÄSRAMµÄCÓïÑԵĦÌPAC- 5000
uPAC-5002D CR ´øLEDÏÔʾµÄuPAC-5002 CR
uPAC-5002-FD CR ´ø256MB FlashµÄuPAC-5002 CR
uPAC-5002D-FD CR ´øLEDÏÔʾµÄUPAC-5002-FD
uPAC-5002-SM CR ´ø512 KBµÄ±¸ÓÃµç³ØµÄSRAMµÄuPAC-5002 CR
uPAC-5002D-SM CR ´øLEDÏÔʾµÄUPAC-5002-SM
¦ÌPAC-5002P CR ´øPoEµÄuPAC-5002 CR
¦ÌPAC-5002PD CR ´øLEDÏÔʾµÄ¦ÌPAC-5002P CR
New uPAC-5201 CR ¦ÌPAC-5201 ÊÖÕÆÐͿɱà³Ì×Ô¶¯»¯¿ØÖÆÆ÷£¬¾ßÓÐGPRS¹¦ÄÜ
New uPAC-5201-FD CR ´ø256MB FlashµÄUPAC-5201
New uPAC-7186EX-G CR ÊÖÕÆÐͿɱà³Ì×Ô¶¯»¯¿ØÖÆÆ÷£¬CPU:80186 80MHz 10/100MÒÔÌ«Íø½Ó¿Ú
New uPAC-7186EXD-G CR ´ø7¶ÎLEDÏÔʾµÄ7186EX CR
¦ÌPAC-7186PEX-G CR ´øPoEµÄUPAC-7186EX
¦ÌPAC-7186PEXD-G CR ´øLEDÏÔʾµÄUPAC-7186PEX
uPAC-7186EG-G CR Ö§³ÖIOÀ©Õ¹£¬´ø10/100MÒÔÌ«Íø£¬512K Flash£¬640K SRAM£¬Á½¸ö´®¿Ú£¬Ö§³ÖISaGRAF±à³Ì
uPAC-7186EGD-G CR ´øLEDÏÔʾµÄuPAC-7186EG CR
New uPAC-7186EX-MTCP-G CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬuPAC-7186EX-G
New uPAC-7186EXD-MTCP-G CR ´ø7¶ÎÊýÂëÏÔʾµÄuPAC-7186EX-MTCP-G CR
¦ÌPAC-7186PEX-MTCP-G CR Ö§³ÖModbus/TCPͨÐÅÐÒéµÄÒÔÌ«Íø¿ØÖÆÆ÷£¬Ó²¼þͬ¦ÌPAC-7186PEX-G CR
¦ÌPAC-7186PEXD-MTCP-G CR ´ø7¶ÎÊýÂëÏÔʾµÄ¦ÌPAC-7186PEX-MTCP-G
uPAC-7186EX-M CR ÊÖÕÆÐͿɱà³Ì×Ô¶¯»¯¿ØÖÆÆ÷£¨½ðÊôÍâ¿Ç£©
uPAC-7186EX-SM CR ¦ÌPAC-7186EϵÁÐ(CÓïÑÔ±à³Ì)¿ÉÀ©Õ¹ÐÍǶÈëʽ¿É±à³Ì¿ØÖÆÆ÷£¬¾ßÓÐ640KµÄSRAM
uPAC-7186EXD-SM CR ´øLEDÏÔʾµÄuPAC-7186EX-SM CR
uPAC-7186EX-FD CR ¦ÌPAC-7186EϵÁÐ(CÓïÑÔ±à³Ì)¿ÉÀ©Õ¹ÐÍǶÈëʽ¿É±à³Ì¿ØÖÆÆ÷£¬¾ßÓÐ64 MB NAND Flash
uPAC-7186EXD-FD CR ´øLEDÏÔʾµÄuPAC-7186EX-FD CR
Seismic SwitchϵÁÐ
GST-43-M CR µØÕð¸Ð²â¿ª¹Ø£¨½ðÊôÍâ¿Ç£©
SAR-713 CR ´ø½ðÊôÍâ¿ÇµÄµØÕ𱨾¯¼Ç¼
I-7188XA/XB/XC/XG/EX/EGµÄI/OÀ©Õ¹°å
Ãæ°ü°åºÍ×Ô¼ì°å
* X000 CR Ãæ°ü°å£¬×¨ÓÃÓÚI-7188XA/XC CR
* X001 CR Ãæ°ü°å£¬×¨ÓÃÓÚI-7188XA/XC CR
* X002 CR Ãæ°ü°å£¬×¨ÓÃÓÚI-7188XA/XB/XC/XG/EX/EG CR
* X003 CR ×Ô¼ì°å£¬×¨ÓÃÓÚI-7188XA/XC CR
* X004 CR ×Ô¼ì°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X005 CR Ãæ°ü°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X006 CR Ãæ°ü°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
Êý×ÖÁ¿ÊäÈë/Êä³ö°å
* X100 CR 8·Êý×ÖÁ¿ÊäÈë°å£¬×¨ÓÃÓÚI-7188XC CR
* X101 CR 8·¼¯µç¼«¿ªÂ·Êä³ö°å£¬×¨ÓÃÓÚI-7188XC CR
* X102 CR 2·CÐͼ̵çÆ÷Êä³ö°å£¬×¨ÓÃÓÚI-7188XC CR
* X103 CR 7·¸ôÀëÊý×ÖÁ¿ÊäÈë°å£¬×¨ÓÃÓÚI-7188XC CR
* X104 CR 8·DI/OÀ©Õ¹°å£¬Ã¿Â·×¨µ¥¶À±à³Ì¶¨ÒåDI»òDO£¬×¨ÓÃÓÚI-7188XC CR
* X105 CR 8·DI/OÀ©Õ¹°å£¬×¨±à³Ì¶¨ÒåΪDI»òDO£¬×¨ÓÃÓÚI-7188XC CR
* X106 CR 3·Êý×ÖÁ¿ÊäÈë/2·¼¯µç¼«¿ªÂ·Êä³ö°å£¬×¨ÓÃÓÚI-7188XC CR
* X107 CR 6·Êý×ÖÁ¿ÊäÈë/7·¼¯µç¼«¿ªÂ·Êä³ö°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X108 CR 2·PWMÊä³ö°å£¬×¨ÓÃÓÚI-7188XC CR
* X109 CR 7·Photo MOS¼ÌµçÆ÷Êä³ö°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X110 CR 14·Êý×ÖÁ¿ÊäÈë°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X111 CR 13·£¨·Ç¸ôÀ룩¼¯µç¼«¿ªÂ·Êä³ö°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X116 CR 6·AÐͼ̵çÆ÷Êä³ö/4·¸ôÀëÊý×ÖÁ¿ÊäÈëÀ©Õ¹°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X119 CR 7·Êý×ÖÁ¿ÊäÈë/7·¼¯µç¼«¿ªÂ·Êä³ö°å£¬×¨ÓÃÓÚI-7188XA/XB/XC/XG/EX/EG CR
XW107 CR 8·¸É½ÓµãÊý×ÖÁ¿ÊäÈ룬8·¼¯µç¼«¿ªÂ·Êä³ö£¨¹àµçÁ÷£©
XW107i CR 8·ʪ½Óµã¸ôÀëÊý×ÖÁ¿ÊäÈ룬8·¼¯µç¼«¿ªÂ·¸ôÀëÊý×ÖÁ¿Êä³ö£¨¹àµçÁ÷£©
* XW509 CR 4·¸ôÀëÊý×ÖÁ¿ÊäÈ룬4·¸ôÀ뼯µç¼«¿ªÂ·Êä³ö£¬´øÓÐ2¸ö·Ç¸ôÀëRS-232´®¿Ú
* XW514 CR 8··Ç¸ôÀëRS-485ͨѶ¿¨
* XW511I CR 4·¸ôÀëRS-485ͨѶ¿¨
Ä£ÄâÁ¿°å¼°¶à¹¦Äܰå
* X200 CR 1·A/D°å£¨0¡«2.5V)£¬×¨ÓÃÓÚI-7188XC CR
* X202 CR 7·A/D°å (0~20mA)£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X203 CR 2·A/D (0~20mA)¡¢2·DI¼°5·DO°å£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X300 CR 2·D/A£¨0¡«4.095V)£¬×¨ÓÃÓÚI-7188XC CR
* X301 CR 1·A/D (0~2.5V)£¬1·D/A(0~4.095V)£¬×¨ÓÃÓÚI-7188XC CR
* X302 CR 1·A/D (¡À5V)£¬1·D/A (¡À5V)£¬×¨ÓÃÓÚI-7188XC CR
* X303 CR 1·A/D (¡À5V)£¬1·D/A (¡À5V)£¬4·DI£¬6·DO£¬×¨ÓÃÓÚI-7188XB/ XG/EX/EG CR
* X304 CR 3·A/D (¡À5V)£¬1·D/A (¡À5V)£¬4·DI£¬4·DO£¬×¨ÓÃÓÚI-7188XB/ XG/EX/EG CR
* X305 CR 7·A/D (¡À5V)£¬1·D/A (¡À5V)£¬2·DI£¬2·DO£¬×¨ÓÃÓÚI-7188XB/ XG/EX/EG CR
* X306 CR 2·A/D (¡À10V)£¬×¨ÓÃÓÚI-7188XC CR
* X308 CR 4·A/D (0~10V)£¬6·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X310 CR 1·A/D (0~10V)£¬1·A/D (0~20mA)£¬2·D/A (0~10V)£¬3·DI£¬3·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
X324 CR 4ͨµÀ¼¯µç¼«¿ªÂ·Êä³ö/4ͨµÀÄ£ÄâÁ¿Êä³ö¶à¹¦ÄÜÀ©Õ¹°å(ÓÃÓÚI-7188XB/XG/EX/EG, ¦ÌPAC-7186XB/XG/EX/EG-FM/SM/SD/FD,¦ÌPAC-7186XB/XG/EX/EG-FM/SM/SD/FD)
¼ÆÊýÆ÷À©Õ¹°å
* X400 CR 3·16λ¶¨Ê±/¼ÇÊýÀ©Õ¹°å¡£ÓÃÓÚI-7188XC CR
ÖÇÄÜͨѶÀ©Õ¹°å
* X500 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·9ÏßRS-232£¬¿ÉÇý¶¯Modem£¬×¨ÓÃÓÚI-7188XC CR
* X501 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬×¨ÓÃÓÚI-7188XC CR
* X502 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬1·3ÏßRS-232£¬×¨ÓÃÓÚI-7188XC CR
* X503 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X504 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬1·9ÏßRS-232£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X505 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³ÖÈý·5ÏßRS-232£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X506 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³ÖÁù·3ÏßRS-232£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X507 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·RS-422£¬4·DI£¬4·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X508 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬4·DI£¬4·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X509 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³ÖÁ½Â·3ÏßRS-232£¬4·DI£¬4·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X510-128 CR ´®¿ÚÀ©Õ¹£¬Ö§³Ö1·3ÏßRS-232£¬5·DI£¬5·DO£¬´ø128K Bytes EEPROM£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X510-256 CR ´®¿ÚÀ©Õ¹£¬Ö§³Ö1·3ÏßRS-232£¬5·DI£¬5·DO£¬´ø256K Bytes EEPROM£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X511 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³ÖÈý·RS-485£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG CR
* X518 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³Ö1·5ÏßRS-232£¬8·DO£¬×¨ÓÃÓÚI-7188XB/XG/EX/EG
* X561 CR ´®¿ÚÀ©Õ¹°å£¬Ö§³ÖÈý·3ÏßRS-232£¬´ø64MB Flash£¬×¨ÓÃÓÚI-7188XA/XB/XC/XG/EX/EG CR
´æ´¢Æ÷À©Õ¹
* X600 CR 4M FlashÀ©Õ¹°å£¬¿ÉÓÃÓÚI-7188XA/XB/XC/EX CR
* X601 CR 8M FlashÀ©Õ¹°å£¬¿ÉÓÃÓÚI-7188XA/XB/XC/EX CR
* X607 CR 128KB SRAM£¨´øµç³Ø£©À©Õ¹°å£¬¿ÉÓÃÓÚI-7188XA/XB/XC/EX CR
* X608 CR 512KB SRAM£¨´øµç³Ø£©À©Õ¹°å£¬¿ÉÓÃÓÚI-7188XA/XB/XC/EX CR
Ô˶¯¿ØÖÆÀ©Õ¹
X702 CR 2Öá±àÂë/¼ÆÊýÆ÷À©Õ¹°å£¬¿ÉÓÃÓÚI-7188XB/XG/EX/EG CR
X703 CR 3Öá±àÂë/¼ÆÊýÆ÷À©Õ¹°å£¬¿ÉÓÃÓÚI-7188XB/XG/EX/EG CR
