²úÆ·Ãû³Æ£º
I-7188XADãü¸ñǶÈëʽ¿ØÖÆÆ÷
ÐÍ ºÅ£º
I-7188XAD
| ²úÆ·Ãû³Æ: |
I-7188XA |
| ²úÆ·½éÉÜ: |
MiniOS7¿ÉÀ©Õ¹ÐÍ¿ØÖÆÆ÷,DI¡Á2,DO¡Á2,COM¡Á4¡£ |
| ²úÆ·ÌØµã: |
80188-40 CPU ÄÚÖÃRTC£¬NVRAM£¬EEPROM ÄÚÖô®¿Ú£ºCOM1£¬COM2£¬COM3£¬COM4 ÄÚÖÿ´ÃŹ·¶¨Ê±Æ÷ ÄÚÖõçÔ´±£»¤µç· ÄÚÖÃ64-bitÓ²¼þÐòÁкŠRS-485 3000V¸ôÀë BIOSÖ§³ÖRTCʱ¼äºÍÈÕÆÚ ÄÚÖÃMiniOS7 ³ÌÐòÏÂÔØ¿Ú£ºCOM4 LEDÏÔʾ(½öI-7188XAD) |
| ²úÆ·²ÎÊý: |
CPU CPU£º80188-40 SRAM£º512 KB ÉÁ´æ£º512 KB EEPROM£º2048 Bytes NVRAM£º31 Bytes RTC£¨ÊµÊ±Ê±ÖÓ£©£ºÃë¡¢·Ö¡¢Ê±¡¢ÈÕÆÚ¡¢Ô¡¢Ä꣨1980~2079£© 64-bitÓ²¼þÐòÁкţºÓÐ ÄÚÖÿ´ÃŹ·£ºÓÐ
½Ó¿Ú COM1£ºRS-232/RS-485(ÌøÏßÑ¡Ôñ)£¬Ä¬ÈÏΪRS-232¡£ COM2£ºRS-485£¨D2+£¬D2-£¬ÄÚÖÃãü¸ñרÀû´®¿Ú×ÔÊÊӦоƬ£©£¬16 bytes FIFO£¬¸ôÀëµçѹ£º3000V COM3£ºRS-232 (TxD3, RxD3, GND)£¬1 byte FIFO COM4£ºRS-232 (TxD4, RxD4, GND); ³ÌÐòÏÂÔØ¿Ú£»¿Éµ±×÷ÆÕͨRS-232 ¶Ë¿ÚÀ´Ê¹Óã¬1 byte FIFO
ͨѶËÙÂÊ ËùÓж˿ڣº115.2K bps max
Êý×ÖÁ¿ÊäÈë/Êä³ö Êý×ÖÁ¿ÊäÈë ͨµÀ£º2 ÊäÈëÀàÐÍ£º·Ç¸ôÀë On µçѹµçƽ£º×î´ó+1 VDC £¨½ÓµØ£© Off µçѹµçƽ£º+3.5 ~ 30 VDC£¨¿ªÂ·£© Êý×ÖÁ¿Êä³ö ͨµÀ£º2 Êä³öÀàÐÍ£º¼¯µç¼«¿ªÂ· Êä³öµçÁ÷£º100 mA ×î´ó¸ºÔصçѹ£º+30 VDC
LEDÏÔʾ 5λ7¶ÎÊýÂë¹ÜÏÔʾ£ºÓУ¨½öI-7188XAD£© Red LED£ºÓÐ
I/OÀ©Õ¹×ÜÏß I-7188XA£ºÓÐ I-7188XAD£ºÓÐ
³ß´ç I-7188XA£º119 mm x 72 mm x 33 mm (W x L x H) I-7188XAD£º119 mm x 72 mm x 33 mm (W x L x H)
»·¾³ ¹¤×÷ζȣº-25 ¡æ ~ 75 ¡æ ´æ´¢Î¶ȣº-40 ¡æ ~ 80 ¡æ Ïà¶Ôʪ¶È£º5 ~ 90%£¬ÎÞÀäÄý
µçÔ´ ±£»¤£ºµçÔ´·´¼«ÐÔ±£»¤ µçÔ´µçѹ£º+10 V ~ +30 V ¹¦ºÄ£ºI-7188XA£º2.0W I-7188XAD£º3.0W |
| ¶©»õÐÅÏ¢£º |
| I-7188XA CR |
Ö§³ÖIOÀ©Õ¹×ÜÏßµÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬512K SRAM£¬2·DI£¬2·DO£¬Ëĸö´®¿Ú£¬RS485 3000V¸ôÀë(COM2)£¬MiniOS7°æ±¾(RoHS) | |
