Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú I-7188XGãü¸ñISaGRAFǶÈëʽ¿ØÖÆÆ÷
²úÆ·Ãû³Æ£º I-7188XGãü¸ñISaGRAFǶÈëʽ¿ØÖÆÆ÷
ÐÍ ºÅ£º I-7188XG
Æ· ÅÆ£º 191
²úÆ·Ãû³Æ: I-7188XG
²úÆ·½éÉÜ:  Ö§³ÖISaGRAF±à³ÌµÄ7188ϵÁÐǶÈëʽ¿ØÖÆÆ÷£¬COM¡Á2¡£
²úÆ·ÌØµã: ÓëI-7188XG½¨Á¢ModbusÁ¬½Ó
ÔÚÓ¦ÓÃÖУ¬I-7188XG ¿ØÖÆÆ÷¿Éµ±×÷Modbus "Slave" ºÍ/»ò Modbus "Master"¿ØÖÆÆ÷¡£µ±×÷ΪModbus Slave£¬¿ÉʹÓà I-7188XG ¿ØÖÆÆ÷µÄCOM1 (RS-232/RS-485) Á¬½Óµ½PCs »òÆäËûHMI ²úÆ·¡£µ±×÷ΪModbus Master£¬¿ÉʹÓÃCOM2 (RS-485) ÓëÖ§³ÖModbusЭÒéµÄÆäËûPLCs »òÉ豸¡£
Modbus RTU/TCP Slave Ports
Modbus RTU£¨RS-232/485/422£©£º×î´ó2¸öModbus RTU Slave ports
Modbus TCP/IP£º×î´ó4¸öModbus TCP Slave Á¬½Ó
Modbus RTU Master Ports
Modbus RTU£¨RS-232/485/422£©£º×î´ó2¸öModbus RTU Master ports
À©Õ¹°å/Ô¶³ÌI/O Ä£¿é
I/O À©Õ¹°å
I-7188XGÓÐ1¸öI/OÀ©Õ¹×ÜÏßÄܲåÈë1¸öÀ©Õ¹I/O°å¡£¿ÉÓõÄI/O À©Õ¹°åÊÇX107¡¢X202¡¢X203¡¢X303¡¢X304¡¢X305¡¢X503¡¢X504¡¢X505¡¢X506¡¢X507¡¢X508¡¢X509¡¢X510 µÈ¡£
ΪԶ³ÌI/OÁ¬½ÓI-7000 ÓëI-87K Ä£¿é
I-7188XG ¿ØÖÆÆ÷¿ÉʹÓÃCOM2 (RS-485)¶Ë¿ÚÁ¬½Óãü¸ñ¿Æ¼¼¡°I-7000¡±Óë¡°I-87K¡±ÏµÁÐÔ¶³ÌI/O Ä£¿é¡£¸ÃÅäÖÃÔÚÐèÇó·Ö²¼Ê½Ô¶³ÌµÄÓ¦ÓÃϵͳÖзdz£ÓÐÓá£
ÓÉFbus½øÐÐÊý¾Ý½»»»
Fbus£¨RS-485 ÍøÂ磩
I-7188XG¿ÉʹÓÃËüµÄRS-485 ¶Ë¿Ú£¨COM2£©Í¨¹ýFbusͨѶ»úÖÆ½øÐн»»¥¡£Fbus¿ÉʹÓù㲥Êý¾Ýµ½Ã¿¸ö¿ØÖÆÆ÷»òÿ¸ö¿ØÖÆÆ÷¿ÉÇëÇó·¢ËÍ»ò½ÓÊÕͬ´¦ÔÚÒ»¸öFbusÍøÂçÖÐµÄÆäËû¿ØÖÆÆ÷µÄÊý¾Ý¡£
Êý¾Ý¼Ç¼
Êý¾Ý¡¢ÈÕÆÚÓëʱ¼ä¿É´æ´¢ÔÚX607/X608ÖУ¬È»ºóPC¿Éͨ¹ýRS-232/RS-485¶ÁÈ¡ÕâЩÊý¾Ý¡£
Ô¶³ÌÏÂÔØ³ÌÐò£ºModem_Link
Modem_LinkÊÇÒ»¿îÈí¼þ£¬ÓÉãü¸ñ¿Æ¼¼Éè¼Æ£¬ÐèÒª°²×°µ½PCÖеÄISaGRAF Èí¼þÖС£Modem_LinkÌṩͨ¹ýÆÕͨµÄmodemÓÉÀ©Õ¹°åX504µÄCOM4Ô¶³ÌÏÂÔØISaGRAF³ÌÐòµ½I-7188EGµÄ¼òÒ×·½·¨¡£ÄãÒ²¿ÉÒÔ¼àÊÓÿ¸öI/OºÍÊý¾Ý£¬Èç¹û³ÌÐòÔÊÐíµÄ»°£¬¿Éͨ¹ýModem¿ØÖÆËü¡£
PWM £ºÂö¿íµ÷ÖÆÊä³ö
²¢ÐÐDOÀ©Õ¹°å¿ÉÍê³ÉPWM Êä³ö¡£Ã¿¸ö¿ØÖÆÆ÷×î¶àÖ§³Ö8ͨµÀ¡£Off=1 ms & On=1 msʱ£¬×î´óÂö¿íΪ500 Hz¡£ÓÐЧµÄÊä³ö·½²¨£ºOff = 1 ~ 32767 ms£¬On= 1 ~ 32767 ms¡£
²¢ÐÐDI ¼ÆÊýÆ÷
0²ÛÉϵIJ¢ÐÐDI °å¿É½ÓÊÕ¼ÆÊýÆ÷¶à´ï500 Hz£¬×îСÂö¿í > 1 ms¡£Ã¿¸ö¿ØÖÆÆ÷×î¶àÖ§³Ö8ͨµÀ¡£¼ÆÊýÊýÖµ£º32-bit¡£
SMS£¨¶ÌÐÅÏ¢·þÎñ£©
ISaGRAF PACs¿É½áºÏGSM Modem Ö§³ÖSMS(¶ÌÐÅÏ¢·þÎñ)¡£ÕâÔÊÐíÓû§¿É´ÓËûµÄµç»°ÇëÇóÐÅÏ¢»ò¿ØÖÆÄ³Ð©Çé¿öµ½ISaGRAF PAC¡£³ý´ËÖ®Í⣬¸ÃPACÒ²¿É·¢ËÍÐÅÏ¢ºÍ±¨¾¯µ½Óû§µç»°ÖС£
²úÆ·²ÎÊý: CPU
CPU£º80188-40 MHz
SRAM£º512 KB
ÉÁ´æ£º512 KB
EEPROM£º2048 bytes
NVRAM£º31 bytes
RTC£¨ÊµÊ±Ê±ÖÓ£©£ºÓÐ
64-bit Ó²¼þÐòÁкţºÓÐ
ÄÚÖÿ´ÃŹ·£ºÓÐ
À©Õ¹×ÜÏߣºÓÐ
NET ID£ºÈí¼þÉèÖã¬1~255
LEDÏÔʾ£ºÓУ¨½öI-7188XGD£©
×î´ó´úÂëÈÝÁ¿£º64 KB (Appli.x8m  < 64K)
½Ó¿Ú
COM1£ºRS-232/RS-485£¬³ÌÐòÏÂÔØ¶Ë¿Ú
COM2£ºRS-485£¬ÄÚÖÃãü¸ñרÀû´®¿Ú×ÔÊÊÓ¦ÐÂÆ¬£¬³ÌÐòÏÂÔØ¶Ë¿Ú
PWM£¨Âö¿íµ÷ÖÆ£©Êä³ö
ËùÓеÄXxxxϵÁÐDOÀ©Õ¹°å¾ùÖ§³ÖÂö¿íµ÷ÖÆÊä³ö¡£Ò»¸ö¿ØÖÆÆ÷×î¶àÖ§³Ö8ͨµÀÊä³ö¡£
Off=1 & On=1 msʱ£¬×î´ó500Hz
Êä³ö·½²¨£ºOff: 1 ~ 32767 ms£¬On: 1 ~ 32767 ms
¼ÆÊýÆ÷
²¢ÐÐDI¼ÆÊýÆ÷£º
ËùÓÐXxxxϵÁÐDIÀ©Õ¹°å¾ùÖ§³ÖDI¼ÆÊý¹¦ÄÜ¡£
Ò»¸ö¿ØÖÆÆ÷×î´óÖ§³Ö8ͨµÀ¡£¼ÆÊýÊýÖµ£º32-bit
×î´ó500 Hz£¬×îСÂö¿í > 1 ms
Ô¶³ÌDI¼ÆÊýÆ÷£º
ËùÓÐÔ¶³ÌI-7000 & I-87KµÄDIÄ£¿é¾ùÖ§³Ö¼ÆÊý¹¦ÄÜ£¬×î´ó100 Hz£¬¼ÆÊýÊýÖµ£º0 ~ 65535
Ô¶³Ì¸ßËÙ¼ÆÊýÆ÷£º
¿ÉÑ¡ I-87082£º100 KHz£¨×î´ó£©£¬32-bit
ЭÒé
Modbus SlaveЭÒ飺
¶à´ï2¸öCOM¶Ë¿Ú£¨COM1£¬COM2»òÀ©Õ¹°åÉϵÄCOM3£©Ö§³ÖModbus RTU SlaveЭÒ飬¿ÉÁ¬½Óµ½ISaGRAF¡¢PC/HMI/OPC Server ¼°MMI panels¡£
Modbus MasterЭÒ飺
¶à´ï2¸öCOM¶Ë¿Ú£¨COM2ºÍÀ©Õ¹°åÉϵÄCOM3£©Ö§³ÖModbus RTU/ASCII MasterЭÒ飬¿ÉÁ¬½Óµ½ÆäËûModbus Slave I/OÉ豸¡£
Ô¶³ÌI/O£º
COM2»òCOM3£¨RS-485£¬Èç¹ûÓеϰ£©Ö§³ÖI-7000 I/O Ä£¿é£¨I-87Kµ×°å»òRU-87P4/8 + I-87K Slave I/OÄ£¿é£©£¬×÷ΪԶ³ÌI/O¡£Ò»¸ö¿ØÖÆÆ÷×î´óÖ§³Ö64¸öI/OÄ£¿é¡£
Fbus£º
ÄÚÖÃCOM2¶Ë¿Ú¿ÉʵÏÖãü¸ñ¿Æ¼¼ISaGRAF PACs¼äÊý¾Ý½»»»¡£
SMS£¨¶ÌÐÅÏ¢·þÎñ£©£º
COM1£¨COM3£ºRS-232»òCOM4£ºRS-232£¬Èç¹ûÓеϰ£©ÖеÄÒ»¸ö£¬ÄÜÁ¬½Óµ½GSM modemÖ§³ÖSMS¡£Óû§¿Éͨ¹ýµç»°ÇëÇóÊý¾Ý/¿ØÖÆ¿ØÖÆÆ÷¡£¿ØÖÆÆ÷Ò²ÄÜ·¢ËÍÊý¾ÝºÍ±¨¾¯µ½Óû§µÄµç»°ÖС£¿ÉÑ¡µÄGSM modems£ºSupreme ( 850/900/1800/1900 GSM/GPRS External Modem)¡£
Óû§×Ô¶¨ÒåЭÒ飺
Óû§¿Éͨ¹ý´®¿ÚͨѶ¹¦ÄÜ¿é±àд×Ô¼ºµÄЭÒéÓ¦Óõ½COM1¡¢COM2£¨COM3 ~ COM8£¬Èç¹ûÓеϰ£©¡£
Modem Link£º
Ö§³ÖPCͨ¹ýX504µÄCOM4Ô¶³ÌÏÂÔØ¼°¼àÊÓ¿ØÖÆÆ÷¡£
MMICON/LCD£º
COM¶Ë¿Ú£¨COM3£ºRS-232£¬Èç¹ûÓеϰ£©Ö§³Öãü¸ñ¿Æ¼¼µÄMMICON¡£MMICONÅ䱸һ¸ö240 x 64 µãÕóµÄLCDºÍÒ»¸ö4 x 4¼üÅÌ¡£Óû§¿ÉʹÓÃËüÀ´ÏÔʾͼÏñ¡¢×Ö·û´®¡¢ÕûÊý¡¢¸¡µãÊý¼°¿ÉÊäÈë×Ö·û¡¢×Ö·û´®¡¢ÕûÊýºÍ¸¡µãÊý¡£
µç³Øºó±¸SRAM
I-7188XG/7188XGDͨ¹ý²åÔÚÀ©Õ¹I/O×ÜÏßÉϵÄX607/X608¿ÉÖ§³Ö¶à´ï1024¸ö±£³ÖÐͱäÁ¿¡£Êý¾Ý¿É´æ´¢ÔÚX607/X608ÉÏ£¬ÇÒPC¿Éͨ¹ýCOM1»òEthernet¶ÁÈ¡ÕâЩÊý¾Ý¡£PCÒ²¿ÉÏÂÔØÔ¤Ïȶ¨ÒåµÄÊý¾Ýµ½X607/X608ÖС£¿ÉÑ¡£ºX607£º128 KB£¬X608£º512 KB
»·¾³
¹¤×÷ζȣº-25 ¡æ ~ 75 ¡æ
´æ´¢Î¶ȣº-40 ¡æ ~ 80 ¡æ
Ïà¶Ôʪ¶È£º5 ~ 90%, ÎÞÀäÄý
µçÔ´
±£»¤£ºÄÚÖõçÔ´±£»¤ºÍÍøÂç±£»¤µç·
µçÔ´µçѹ£º+10 ~ +30 VDC
¹¦ºÄ£ºI-7188XG£º2 W
         I-7188XGD£º3 W
¶©»õÐÅÏ¢£º
I-7188XG CR Ö§³ÖIOÀ©Õ¹×ÜÏßµÄI-7188¿ØÖÆÆ÷£¬512K Flash£¬512K SRAM£¬Á½¸ö´®¿Ú£¬Ö§³ÖISaGRAF±à³Ì(RoHS)
I-7188XGD CR ´øLEDÏÔʾµÄI-7188XG CR
Ïà¹Ø²úÆ·£º
¦ÌPAC-7186EG  ÕÆÉÏÐÍÒÔÌ«ÍøISaGRAF PAC (80186, 80 MHz, 10/100 Base-TX )
I-7188EG  ÒÔÌ«ÍøISaGRAF PAC (80188, 40 MHz, 10 Base-T)
I-8437-80  ISaGRAFÐÍÒÔÌ«Íø4²Û80MǶÈëʽ¿É±à³Ì×Ô¶¯»¯¼ÆËã»ú
I-8837-80  ISaGRAFÐÍÒÔÌ«Íø8²Û80MǶÈëʽ¿É±à³Ì×Ô¶¯»¯¼ÆËã»ú
¿ÉÑ¡¸½¼þ£º
KA-52F  24V/1A µçÔ´
DIN-KA52F  24V/1A µçÔ´(DINµ¼¹ì°²×°)
ACE-540A  24V/1.7A µçÔ´(±Ú°å°²×°)
DIN-540A  24V/1.7A µçÔ´(DINµ¼¹ì°²×°)
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÅô¿Øµç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 0755 61309550£¬1£¬2£¬3 / Äß¹¤
ÊÖ»ú£º 400-777-9880
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÉϲ½ÄÏ·¹úÆó´óÏÃÓÀ»ÔÂ¥12Â¥C×ù
ÓÊ ±à£º 518031
Ö÷ Ò³£º http://www.szpk.cn
  • ÑлªÆµÂÊÄ£¿é
  • A-822PGH/S/A-822PGL/S
  • Ñлª¼ÌµçÆ÷Êä³öÄ£¿é
  • DIO-24 24·Êý×ÖÁ¿ÊäÈëÊä³ö¿¨
  • PISO-730 PCI×ÜÏß
  • P16R16DIO ISA×ÜÏß
  • ISO-AD32H 32/16·200kHz¸ß/µÍÔöÒæ12λA/D¿¨
  • A-826PG/A-826PG/S
  • P8R8DIO 8·¸ôÀëÊý×ÖÁ¿ÊäÈë/8·¼ÌµçÆ÷Êä³ö¿¨
  • ISO-AD32L 2λ/32·µ¥¶Ë/16·²î·ÖÄ£ÄâÁ¿ÊäÈ뿨
