²úÆ·Ãû³Æ£º
I-7550
ÐÍ ºÅ£º
| ²úÆ·Ãû³Æ: |
I-7550 |
| ²úÆ·½éÉÜ: |
PROFIBUS´ÓÕ¾µ½RS-232/RS-422/RS-485ת»»Ä£¿é¡£ |
| ²úÆ·ÌØµã: |
ÐÒé²ã DP-V0 ´Ó¶Ë Ö§³Ö PROFIBUS ´«ÊäËÙÂÊ(Kbps) 9.6, 19.2, 45.45, 93.75, 187.5, 500, 1500, 3000, 6000, 12000 ´«ÊäËÙÂÊÉèÖà ×Ô¶¯Õì²â ×î´óÊäÈëÊý¾Ý×Ö³¤ 128 Bytes ×î´óÊä³öÊý¾Ý×Ö³¤ 128 Bytes µØÖ·É趨 0~126 DIPÉ趨 COM 1 RS-232/422/485 ÄÚÖá°Self Tuner¡± Ä£¿é COM 1 ²¨ÌØÂÊ (Kbps) 1.2, 2.4, 4.8, 9.6, 19.2, 38.4, 57.6, 115.2 COM 1 Êý¾Ý¸ñʽ 7/8 data bits, No/Odd/Even parity, 1 stop bit Ö¸±ê PWR, ERR, ¼°RUN LED DC¸ôÀë±£»¤ PROFIBUS ¶Ë 3000VDC |
| ²úÆ·²ÎÊý: |
CPU£º80186, 80MHz »òÏà¼æÈÝ Äڴ棺512K bytes ÉÁ´æ£º512K bytes EEPROM£º16K Bytes RTC£ºÓÐ 64λӲ¼þÐòÁкţºÓÐ ÄÚÖÿ´ÃŹ·£ºÓÐ COM1£ºRS-232 (TXD, RXD, RTS, CTS, GND) PROFIBUS½Ó¿Ú£º9-pin D-Sub(ĸ¿Ú) PROFIBUS¿ØÖÆÆ÷£ºSiemens SPC3 PROFIBUSÊÕ·¢Æ÷£ºADI ADM2486 iCoupler¸ôÀëÊÕ·¢Æ÷ ´«ÊäËÙÂÊ£º¸ß´ï 10Mbps ³ß´ç 118mm x 72mm x 33mm (H x W x D) ÔËÐÐζȣº-25¡æ ~ +75¡æ ´æ´¢Î¶ȣº-40¡æ ~ +80¡æ ʪ¶È£º5~95% (·ÇÄý¶) µçÔ´£º+10 ~ +30VDC (·ÇÎÈѹ) ¹¦ºÄ 2.5W |
| ¶©»õÐÅÏ¢£º |
| I-7550 |
PROFIBUS / RS-232/422/485 ת»»Æ÷ | |
| Ïà¹Ø²úÆ·£º |
| I-7550 |
PROFIBUS / RS-232/422/485 ת»»Æ÷ | | |
¹©Ó¦ÆäËüÈÈÂô²úÆ·£º
FR-2000ͨѶ¿¨ FRB-100 CR PCI×ÜÏß1¸öFRnet×ÜÏß¶Ë¿ÚͨѶ¿¨ FRB-200 CR PCI×ÜÏß2¸öFRnet×ÜÏß¶Ë¿ÚͨѶ¿¨ FRB-200U CR ͨÓÃÐÍPCI×ÜÏß2¸öFRnet×ÜÏß¶Ë¿ÚͨѶ¿¨ FR-2000 I/OÄ£¿é FR-32P/DIN CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ32·¸ôÀëÊý×ÖÁ¿ÊäÈë FR-16R/DIN CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ16·AÐͼ̵çÆ÷Êä³ö FR-32R/DIN CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ32·AÐͼ̵çÆ÷Êä³ö FR-2000¿ØÖÆÆ÷ I-7188EF-016 CR FRnet×ÜÏßÒÔÌ«Íø¿É±à³Ì×Ô¶¯»¯¿ØÖÆÆ÷¡¢¾ßÓÐ1¸öEthernet½Ó¿Ú¡¢1¸öRS-232½Ó¿Ú¡¢1¸öRS-485½Ó¿Ú I-7188EFD-016 CR ´ø5λ7¶ÎLEDÏÔʾµÄI-7188EF-016 CR FR-2000 DI/OÄ£¿é FR-2017iT CR 8µ¥¶Ë»ò16²î·Ö¸ôÀë¸ßµçѹ±£»¤ºÍ¸ôÀëͨÐÅÏß·ģÄâÁ¿ÊäÈëÄ£¿é FR-2053 CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ16·¸ôÀëÊý×ÖÁ¿ÊäÈë¡¢Frnet½Ó¿ÚΪ20Õë±âƽµçÀ FR-2053T CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ16·¸ôÀëÊý×ÖÁ¿ÊäÈë¡¢Frnet½Ó¿ÚΪ20ÕëÂݶ¤½ÓÍ· FR-2053S CR 3Pin µÄ±£»¤Á¬½ÓÆ÷¡¢16·¸ôÀëÊý×ÖÁ¿ÊäÈëÄ£¿é FR-2053HT CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿ÊäÈë·Ö²¼Ê½I/OÄ£¿é£¬Ö§³Ö×î¸ß²¨ÌØÂÊ1Mbps FR-2053TA CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿ÊäÈëÄ£¿é£¨3.5~30VDC¸ßµç룬0~1VDCΪµÍµç룩 FR-2053IT CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿ÊäÈëÄ£¿é£¨19~30VDC¸ßµç룬0~11VDCΪµÍµç룩 FR-2053ITR CR ´øÓиôÀëͨѶÏßµÄ16·ԴµçÁ÷/¹àµçÁ÷Ð͸ôÀëÊý×ÖÁ¿ÊäÈëÄ£¿é FR-2054T CR 8ͨµÀÊý×ÖÁ¿Êä³ö£¨¹àµçÁ÷NPN£©8ͨµÀÊý×ÖÁ¿ÊäÈë FR-2057 CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ16·¸ôÀëÊý×ÖÁ¿Êä³ö¡¢Frnet½Ó¿ÚΪ20Õë±âƽµçÀ FR-2057T CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ16·¸ôÀëÊý×ÖÁ¿Êä³ö¡¢Frnet½Ó¿ÚΪ20ÕëÂݶ¤½ÓÍ· FR-2057S CR 3Pin µÄ±£»¤Á¬½ÓÆ÷¡¢16·¸ôÀëÊý×ÖÁ¿Êä³öÄ£¿é FR-2057TA CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿Êä³öÄ£¿é FR-2057TW CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿´óµçÁ÷Êä³öÄ£¿é£¨250mA£© FR-2057IT CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿Êä³öÄ£¿é£¨100mA£© FR-2057ITR CR ´øÓиôÀëͨѶÏßµÄ16·¹àµçÁ÷Ð͸ôÀëÊý×ÖÁ¿Êä³öÄ£¿é FR-2057HT CR 16ͨµÀ¸ôÀëÊý×ÖÁ¿Êä³öÄ£¿é FR-2057HTA CR ¸ßËÙµÄFR-2057TAÄ£¿é£¬×î¸ßͨѶËÙÂʿɴï1MHz FR-2152T CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ8·¸ôÀëÊý×ÖÁ¿ÊäÈë FR-2156T CR FRnet×ÜÏßI/OÄ£¿é£¬¾ßÓÐ8·¸ôÀëÊý×ÖÁ¿Êä³ö FR-2000ͨѶģ¿é I-8172-G CR 2-port FRnet×ÜÏßͨѶģ¿é MagicWireϵÁÐ MA-11 CR ÊÊÓÃÓÚPLCµÄÊäÈëÐÍMagicWire,32Êý×ÖÁ¿ÊäÈëͨµÀ¡£DP¿ª¹ØµØÖ·£º0-7¡£VIL=1.5V;VIH=3.5V MA-12 CR ÊÊÓÃÓÚPLCµÄÊäÈëÐÍMagicWire,32Êý×ÖÁ¿ÊäÈëͨµÀ¡£DP¿ª¹ØµØÖ·£º0-7¡£VOL=0.4V;VOH=3.5V MA-21 CR ÊÊÓÃÓÚPLCµÄÊäÈëÐÍMagicWire,32Êý×ÖÁ¿ÊäÈëͨµÀ¡£DP¿ª¹ØµØÖ·£º8-15¡£VIL=1.5V;VIH=3.5V MA-22 CR ÊÊÓÃÓÚPLCµÄÊäÈëÐÍMagicWire,32Êý×ÖÁ¿ÊäÈëͨµÀ¡£DP¿ª¹ØµØÖ·£º8-15¡£VOL=10.4V;VOH=3.5V MD-11 CR ÊÊÓÃÓÚI-8000µÄÊäÈëÐÍMagicWire MD-12 CR ÊÊÓÃÓÚI-8000µÄÊä³öÐÍMagicWire CAN×ÜÏßÄ£¿é I-8120 CR (I-8KCAN-G) 1¶Ë¿ÚCAN×ÜÏßÄ£¿é(²¢ÐУ¬°«¿¨) I-8120W-G CR 1¶Ë¿ÚCAN×ÜÏßÄ£¿é(²¢ÐУ¬¸ß¿¨£© I-87120-G CR (I-87KCAN-G ) 1¶Ë¿ÚCAN×ÜÏßÄ£¿é(´®ÐÐ) I-8123W-G CR 1¶Ë¿Ú¸ßÐÔÄÜCANopenÖ÷վģ¿é I-87123-G CR (I-87KCPM) 1¶Ë¿ÚCANopenÖ÷վģ¿é£¨´®ÐУ© I-87124-G CR(I-87KDNM) 1¶Ë¿ÚµÄDeviceNet½Ó¿Ú I-8124W-G CR 1¶Ë¿ÚÄ£¿éµÄDeviceNetÖ÷Ë«¿ÚRAM CANÀ©Õ¹µ¥Ôª CAN-8124 CR (ÔI-8KDNS1-G) DeviceNET´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ1¸öI/OÀ©Õ¹²å²Û CAN-8224 CR (ÔI-8KDNS2-G) DeviceNET´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ2¸öI/OÀ©Õ¹²å²Û CAN-8424 CR (I-8420-G) DeviceNET´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ4¸öI/OÀ©Õ¹²å²Û CAN-8123 CR (ÔI-8KCPS1-G) CANopen´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ1¸öI/OÀ©Õ¹²å²Û CAN-8223 CR (ÔI-8KCPS2-G) CANopen´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ2¸öI/OÀ©Õ¹²å²Û CAN-8423 CR (I-8421-G) CANopen´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ4¸öI/OÀ©Õ¹²å²Û CAN-2000 ϵÁÐ CAN-2017D CR Ö§³ÖDeviceNetÐÒéµÄ8ͨµÀÄ£ÄâÁ¿ÊäÈëÄ£¿é CAN-2018D CR Ö§³ÖDeviceNetÐÒéµÄ8ͨµÀÈȵçżÊäÈëÄ£¿é CAN-2024D CR Ö§³ÖDeviceNetÐÒéµÄ4ͨµÀÄ£ÄâÁ¿Êä³öÄ£¿é CAN-2024C CR 4ͨµÀ14λģÄâÊä³öCANopenͨѶģ¿é CAN-2053C CR 16ͨµÀ¸ôÀëÊý×ÖÊäÈëCANopenͨѶģ¿é CAN-2057C CR 16ͨµÀÄ£¿é¼¯µç¼«¿ªÂ·Êä³öCANopenͨѶģ¿é CAN-2054C CR 8ͨµÀ¸ôÀëÊý×ÖÊäÈëºÍ8ͨµÀ¸ôÀëÊý×ÖÊä³öCANopenͨѶģ¿é CAN-2088C CR 8ͨµÀPWM£¬8ͨµÀ¸ßËÙ¼ÆÊýÆ÷CANopenͨѶģ¿é CAN-2024D CR 4ͨµÀ14λģÄâÊä³öDeviceNetÄ£¿é CAN-2053D CR 16ͨµÀ¸ôÀëÊý×ÖÊäÈëDeviceNetÄ£¿é CAN-2057D CR 16ͨµÀÄ£¿é¸ôÀ뿪¼¯Êý×ÖÊä³öDeviceNetÄ£¿é CAN-2054D CR 8ͨµÀ¸ôÀëÊý×ÖÊäÈëºÍ8ͨµÀ¸ôÀëÊý×ÖÊä³öDeviceNetÄ£¿é CAN-2088D CR 8ͨµÀPWM£¬8ͨµÀ¸ßËÙ¼ÆÊýÆ÷DeviceNetÄ£¿é CAN×ÜÏßǶÈëʽ¿ØÖÆÆ÷ uPAC-7186EXD-CAN CR CAN×ÜÏßÒÔÌ«Íø¿É±à³Ì×Ô¶¯»¯¿ØÖÆÆ÷¡¢¾ßÓÐ1¸öEthernet½Ó¿Ú¡¢1¸öRS-232´®¿Ú¡¢1¸öRS-485´®¿Ú I-7188XBD-CAN-G CR CAN×ÜÏ߿ɱà³Ì×Ô¶¯»¯¿ØÖÆÆ÷¡¢¾ßÓÐ1¸öRS-232´®¿Ú¡¢1¸öRS-485´®¿Ú CAN×ÜÏßת»»Æ÷Ä£¿é I-2532 CR CAN¡Á1£¬ST£¨¶àÄ££©¡Á1ת»»Æ÷ I-2533 CR CAN¡Á1£¬ST£¨¶àÄ££©¡Á1Íø½ÓÆ÷£¨Ç°ºó¶ËµÄ²¨ÌØÂÊ¿ÉΪ²»Ò»Ñù£© I-2534 CR ¹¤Òµ4¶Ë¿ÚCAN×ÜÏß¿ª¹Ø I-7530-G CR 1¸öCANתRS-232Ä£¿é I-7530A-G CR 1¸öCANתRS-232/RS-485/RS-422Ä£¿é I-7530A-MR CR Modbus RTUתCANת»»Æ÷ I-7530-FT-G CR ÖÇÄÜRS-232/CANµÍËÙÈÝ´íת»»Æ÷ CANÏÖ³¡×ÜÏßÍø¹Ø I-7231D-G CR CANopen´ÓÕ¾µ½DCONÐÒéÍø¹ØÄ£¿é I-7232D-G CR CANopen´ÓÕ¾µ½Modbus/RTUÖ÷Õ¾Íø¹ØÄ£¿é I-7241D-G CR DeviceNet´ÓÕ¾µ½DCONÐÒéÍø¹ØÄ£¿é I-7242D-G CR DeviceNet´ÓÕ¾µ½Modbus/RTUÖ÷Õ¾Íø¹ØÄ£¿é I-7243D-G CR DeviceNetÖ÷Õ¾µ½Modbus/TCP´ÓÕ¾Íø¹ØÄ£¿é I-7531-G CR CAN×ÜÏ߸ôÀëÖÐ¼ÌÆ÷ I-7532-G CR CAN×ÜÏßÇŽÓÄ£¿é I-7540D-G CR 1¿ÚCANתEthernetÄ£¿é I-7540D-WF CR CANתWiFiת»»Æ÷ GW-7228-G CR J1939/Modbus RTUÍø¹Ø GW-7243D-G CR Modbus TCP/RTU/ASCIIÖ÷Õ¾µ½DeviceNet´ÓÕ¾µ½Íø¹ØÄ£¿é GW-7433D-G CR 1¸öCANopen×ÜÏßÖ÷Õ¾µ½Modbus/TCP´ÓÕ¾Íø¹ØÄ£¿é GW-7434D-G CR 1¸öDeviceNet×ÜÏßÖ÷Õ¾µ½Modbus/TCP´ÓÕ¾Íø¹ØÄ£¿é GW-7472 CR(IPGW-710) EtherNet/IP adapter to Modbus RTU master Íø¹Ø CAN×ÜÏßͨѶ¿¨ PISO-CM100U-T CR ͨÓÃÐÍPCI ×ÜÏß´øÓÐ5ÕëÂݶ¤½ÓÏß¶Ë×Ó¡¢¸ôÀëCANͨѶ¿ÚµÄÖÇÄÜCAN ½Ó¿Ú¿¨ PISO-CM100U-D CR ͨÓÃÐÍPCI ×ÜÏß´øÓÐ9ÕëDÐͲåÍ·¡¢¸ôÀëCANͨѶ¿ÚµÄÖÇÄÜCAN ½Ó¿Ú¿¨ PISO-DNM100-D CR PCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜDeviceNet×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ·£¨ÄÚÖÃCPU£© PISO-DNM100-T CR PCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜDeviceNet×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ·£¨ÄÚÖÃCPU£© PISO-DNM100U-D CR ͨÓÃPCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜDeviceNet×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ·£¨ÄÚÖÃCPU£© PISO-DNM100U-T CR ͨÓÃPCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜDeviceNet×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ·£¨ÄÚÖÃCPU£© PISO-CPM100U-D CR ͨÓÃÐÍPCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜCANopen×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ·£¨ÄÚÖÃCPU£© PISO-CPM100U-T CR ͨÓÃÐÍPCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜCANopen×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ·£¨ÄÚÖÃCPU£© PISO-CPM100-D CR PCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜCANopen×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ·£¨ÄÚÖÃCPU£© PISO-CPM100-T CR PCI×ÜÏß1¿Ú¸ôÀëÖÇÄÜCANopen×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ·£¨ÄÚÖÃCPU£© PISO-CAN200U-D CR ͨÓÃPCI×ÜÏß2¿Ú¸ôÀëCAN×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ· PISO-CAN200U-T CR ͨÓÃPCI×ÜÏß2¿Ú¸ôÀëCAN×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ· PISO-CAN200E-D CR ´øÓÐ9ÕëDÐͲåÍ·µÄ2¿Ú¸ôÀë±£»¤CANͨѶ¿¨ PISO-CAN200E-T CR ´øÓÐ5ÕëÂݶ¤½ÓÏß¶Ë×ÓµÄ2¿Ú¸ôÀë±£»¤CANͨѶ¿¨ PCM-CAN100-D CR PCI-104×ÜÏß1¿Ú¸ôÀëCAN×ÜÏßͨѶ°å¡¢CAN¿ÚΪ9ÕëF/M DÐͽÓÍ· PCM-CAN200-D CR PCI-104×ÜÏß2¿Ú¸ôÀëCAN×ÜÏßͨѶ°å¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ· PCM-CAN200P-D CR PC-104+×ÜÏß2¿Ú¸ôÀëCAN×ÜÏßͨѶ°å¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ· PEX-CAN200I-D 2¶Ë¿Ú¸ôÀëµÄCANͨÐÅ¿¨µÄ±£»¤Óë9ÕëD - SubÁ¬½ÓÆ÷ PEX-CAN200I-T 2¶Ë¿Ú5Òý½Å¸ôÀëµÄCANͨÐÅ¿¨µÄ±£»¤ÂÝË¿ÖÕ¶ËÁ¬½ÓÆ÷ PISO-CAN400U-D CR ͨÓÃPCI×ÜÏß4¿Ú¸ôÀëCAN×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ9ÕëDÐͽÓÍ· PISO-CAN400U-T CR ͨÓÃPCI×ÜÏß4¿Ú¸ôÀëCAN×ÜÏßͨѶ¿¨¡¢CAN¿ÚΪ5ÕëÂݶ¤½ÓÍ· PROFIBUS I-7550-G CR PROFIBUS×ÜÏß´ÓÕ¾µ½RS-232/RS-422/RS-485ת»»Ä£¿é GW-7552-G CR PROFIBUS×ÜÏß´ÓÕ¾µ½ModbusÖ÷Õ¾Íø¹ØÄ£¿é GW-7553-G CR PROFIBUS/ModBUS TCPÍø¹Ø PROFI-5045 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24·¸ôÀëÊý×ÖÊä³ö PROFI-5050 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é,16ͨµÀ·Ç¸ôÀëÊý×ÖÁ¿ÊäÈëºÍ8ͨµÀ·Ç¸ôÀëÊý×ÖÊä³ö PROFI-5051 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24·¸ôÀëÊý×ÖÊäÈë PROFI-5052 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬12·¸ôÀëÊý×ÖÊä³ö PROFI-5053 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24··Ç¸ôÀëÊý×ÖÊäÈë PROFI-5055 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬8·¸ôÀëÊý×ÖÊäÈ룬8·¸ôÀëÊý×ÖÊä³ö PROFI-5060 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é8ͨµÀ¸ôÀëÊý×ÖÊäÈëºÍ4·CÐͼ̵çÆ÷Êä³ö PROFI-8155 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ1¸öI/O²å²Û PROFI-8255 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ2¸öI/O²å²Û PROFI-8455 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ4¸öI/O²å²Û HARTϵÁÐ I-7567 CR USBתHARTת»»Æ÷ I-7570 CR ¸ôÀë232/422/485´®¿ÚÖÁHARTת»»Æ÷ HART-710 CR Modbus RTU/ASCII´ÓվתHARTÐÒéÍø¹Ø I-87H17W CR 8ͨµÀHARTµçÁ÷ÊäÈëÄ£¿é CNT-CAN CR CAN×ÜÏßÁ¬½ÓÆ÷ CNT-PROFI CR PROFI ×ÜÏßÁ¬½ÓÆ÷ PMµç±íϵÁÐ PM-2134-100 CR µ¥ÏàËÄ»ØÂ·ÖÇÄܵç±í£¨0~60A£©£¬Ö§³ÖModbus/RTU PM-2133-100 CR 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~60A£©£¬Ö§³ÖModbus/RTU PM-2133-160 CR 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~100A£©£¬Ö§³ÖModbus/RTU PM-2133-240 CR 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~200A£©£¬Ö§³ÖModbus/RTU PM-2134-100-CAN µ¥ÏàËÄ»ØÂ·ÖÇÄܵç±í£¨0~60A£©£¬Ö§³ÖCAN×ÜÏߺÍModbus/RTU PM-2133-100-CAN 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~60A£©£¬Ö§³ÖCAN×ÜÏߺÍModbus/RTU PM-2133-160-CAN 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~100A£©£¬Ö§³ÖCAN×ÜÏߺÍModbus/RTU PM-2133-240-CAN 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¨0~200A£©£¬Ö§³ÖCAN×ÜÏߺÍModbus/RTU PM-3310-60 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¬Ö§³ÖModbus RTU PM-3310-100 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¬Ö§³ÖModbus RTU PM-3310-200 3Ïà½ô´ÕÐÍÖÇÄܵçÁ¦±í£¬Ö§³ÖModbus RTU
