²úÆ·Ãû³Æ£º
GW-7552
ÐÍ ºÅ£º
GW-7552
| ²úÆ·Ãû³Æ: |
GW-7552 |
| ²úÆ·½éÉÜ: |
PROFIBUS´ÓÕ¾µ½ModbusÖ÷Õ¾Íø¹Ø¡£ |
| ²úÆ·ÌØµã: |
ÐÒé²ã DP-V0 ´Ó¶Ë Ö§³Ö PROFIBUS ´«ÊäËÙÂÊ(Kbps) 9.6, 19.2, 45.45, 93.75, 187.5, 500, 1500, 3000, 6000, 12000 ´«ÊäËÙÂÊÉèÖà ×Ô¶¯Õì²â ×î´óÊäÈëÊý¾Ý×Ö³¤ 128 Bytes ×î´óÊä³öÊý¾Ý×Ö³¤ 130 Bytes µØÖ·É趨 0~126 DIPÉ趨 Ö§³ÖModbusģʽ Ö÷/´Ó Ö§³ÖModbus¸ñʽ RTU/ASCII COM 1 RS-232/422/485 ÄÚÖÃ×ÔÊÊӦģ¿é COM 1 ²¨ÌØÂÊ (Kbps) 1.2, 2.4, 4.8, 9.6, 19.2, 38.4, 57.6, 115.2 COM 1 Êý¾Ý¸ñʽ 7/8 data bits, No/Odd/Even parity, 1 stop bit Ö¸±ê PWR, ERR, ¼°RUN LED DC¸ôÀë±£»¤ PROFIBUS ¶Ë 3000VDC |
| ²úÆ·²ÎÊý: |
CPU£º80186, 80MHz »òÏà¼æÈÝ Äڴ棺512K bytes ÉÁ´æ£º512K bytes EEPROM£º16K Bytes RTC £ºÓÐ 64λӲ¼þÐòÁкţºÓÐ ÄÚÖÿ´ÃŹ·£ºÓÐ COM1£ºRS-232 (TXD, RXD, RTS, CTS, GND) PROFIBUS½Ó¿Ú£º 9-pin D-Sub(Female) PROFIBUS¿ØÖÆÆ÷£ºSiemens SPC3 PROFIBUSÊÕ·¢Æ÷£ºADI ADM2486 iCoupler Isolated Transceiver ´«ÊäËÙÂÊ£º¸ß´ï 10Mbps ³ß´ç£º118mm x 72mm x 33mm(H x W x D) ÔËÐÐζȣº-25¡æ ~ 75¡æ ´æ´¢Î¶ȣº-40¡æ ~ 80¡æ Ïà¶Ôʪ¶È£º5~95% (·ÇÄý¶) µçÔ´£º+10 ~ +30V/DC (·ÇÎÈѹ) ¹¦ºÄ 2.5W |
¹©Ó¦ÆäËüÈÈÂô£º
I-7550-G CR PROFIBUS×ÜÏß´ÓÕ¾µ½RS-232/RS-422/RS-485ת»»Ä£¿é GW-7552-G CR PROFIBUS×ÜÏß´ÓÕ¾µ½ModbusÖ÷Õ¾Íø¹ØÄ£¿é GW-7553-G CR PROFIBUS/ModBUS TCPÍø¹Ø PROFI-5045 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24·¸ôÀëÊý×ÖÊä³ö PROFI-5050 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é,16ͨµÀ·Ç¸ôÀëÊý×ÖÁ¿ÊäÈëºÍ8ͨµÀ·Ç¸ôÀëÊý×ÖÊä³ö PROFI-5051 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24·¸ôÀëÊý×ÖÊäÈë PROFI-5052 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬12·¸ôÀëÊý×ÖÊä³ö PROFI-5053 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬24··Ç¸ôÀëÊý×ÖÊäÈë PROFI-5055 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é£¬8·¸ôÀëÊý×ÖÊäÈ룬8·¸ôÀëÊý×ÖÊä³ö PROFI-5060 CR PROFIBUS·Ö²¼Ê½I/0Ä£¿é8ͨµÀ¸ôÀëÊý×ÖÊäÈëºÍ4·CÐͼ̵çÆ÷Êä³ö PROFI-8155 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ1¸öI/O²å²Û PROFI-8255 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ2¸öI/O²å²Û PROFI-8455 CR PROFIBUS×ÜÏß´ÓÕ¾À©Õ¹µ¥Ôª£¬¾ßÓÐ4¸öI/O²å²Û
