Form Factor |
Pico-ITX Motherboard |
CPU |
Intel® AtomTM processor N2800, 1.86 GHz ( LP-172N )
Intel® AtomTM processor D2700, 2.13 GHz ( LP-172D ) |
Memory |
1 x 204-pin DDR3-800/1066 SO-DIMM up to 4.0 GB
Support Non-ECC, unbuffered memory only |
Chipset |
Intel® NM10 Express Chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 3.0 compliant, supports power saving mode |
Integrated Graphics |
Intel® integrated extreme GMA 3650 Technology |
LVDS Interface |
Onboard 18-bit single channel LVDS ( LP-172N )
Onboard 18/24-bit single channel LVDS ( LP-172D ) |
Serial ATA Interface |
1 x SATAII interface with 300MB/s transfer rate |
Audio Interface |
Realtek ALC888 HD Codec |
LAN Interface |
1 x Intel® 82583V Gigabit Ethernet controller |
Expansion Interface |
1 x PCIe mini card socket.
Support mSATA SSD ( Optional ).
( Need to be informed before purchase for hardware modification ) |
Internal I/O Port |
1 x Audio, 4 x USB2.0, 1 x SATAII, 2 x RS232, 1 x LPC
1 x LVDS, 1 x LED backlight with jumper setting for 3.3V / 5V |
External I/O Port |
1 x VGA, 1 x RJ45, 1 x PS2 |
Power Requirement |
5V DC input |
Board Dimension |
100mm x 72mm |
Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
