Form Factor |
Mini-ITX Motherboard |
CPU |
Intel® AtomTM processor N2800, 1.86 GHz ( LV-67IN )
Intel® AtomTM processor D2700, 2.13 GHz ( LV-67ID ) |
Memory |
2 x 204-pin DDR3-800/1066 SO-DIMM up to 4.0 GB
Support Non-ECC, unbuffered memory only |
Chipset |
Intel® NM10 Express Chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 3.0 compliant, supports power saving mode |
Integrated Graphics |
Intel® integrated extreme GMA 3650 Technology |
LVDS Interface |
Onboard 18-bit single channel LVDS ( LV-67IN)
Onboard 18/24-bit single channel LVDS ( LV-67ID ) |
| DVI Interface |
Onboard DVI interface with 20-pin connector |
Serial ATA Interface |
2 x SATAII interface with 300MB/s transfer rate |
Audio Interface |
Realtek ALC888 HD Codec |
LAN Interface |
2 x Intel® 82583V Gigabit Ethernet controller |
Expansion Interface |
1 x 32-bit PCI slot , PCIe mini card & Mini-PCI sockets |
Internal I/O Port |
1 x Audio, 2 x USB2.0, 2 x SATAII, 3 x RS232, 1 x LPC, 1 x LPT
1 x LVDS, 1 x DVI, 1 x IrDA |
External I/O Port |
1 x VGA, 2 x RJ45 LAN, 1 x PS2 Keyboard/Mouse, 4 x USB
2 x RS232 & 1 x RS232/422/485, 1 x Audio, 1 x SPDIF |
Power Requirement |
DC 9V ~ 24V input or standard 20-pin ATX power supply |
Board Dimension |
170mm x 170mm |
Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
