ÎÒ˾רҵ¹©Ó¦µÂ¹ú±¾µÂ¶ûBENDERȫϵÁвúÆ· ÒÔÏÂΪ¾ßÌåÐͺźͲÎÊý
IR125Y-2 INSULATION MONITORING DEVICE DC / AC 9,6...100V 50/60Hz
IR125Y-4 INSULATION MONITORING DEVICE AC19,2-264V50/60Hz DC19,2-308V
IR125Y-426 INSULATION MONITORING DEVICE AC 9,6-138V 50/60Hz DC9,6-138V
IR125Y-47 INSULATION MONITORING DEVICE AC19,2...264V / DC19,2...308V
IR125Y-495 INSULATION MONITORING DEVICE AC19,2-264V50/60Hz DC19,2-308V
IR125YW-2 INSULATION MONITORING DEVICE DC / AC 9,6...100V 50/60Hz
IR125YW-4 INSULATION MONITORING DEVICE AC19,2-264V50/60Hz DC19,2-308V
IR140Y-3 INSULATION MONITORING DEVICE AC 0...138V 50...400Hz
IR140Y-4 INSULATION MONITORING DEVICE AC 0...300V 50...400Hz
IR140Y-40 INSULATION MONITORING DEVICE AC 0...300V 50...400Hz
IR140Y-413 INSULATION MONITORING DEVICE AC 0...300V 50...400Hz
IR140Y-421 INSULATION MONITORING DEVICE AC 0...300V 50...400Hz
IR145Y-3 INSULATION MONITORING DEVICE DC / AC 0...138V 15...400Hz
IR145Y-313 INSULATION MONITORING DEVICE DC / AC 0...138V 15...400Hz
IR145Y-321 INSULATION MONITORING DEVICE DC / AC 0...138V 15...400Hz
IR145Y-4 INSULATION MONITORING DEVICE DC / AC 0...300V 15...400Hz
IR145Y-413 INSULATION MONITORING DEVICE DC / AC 0...300V 15...400Hz
IR145Y-421 INSULATION MONITORING DEVICE DC / AC 0...300V 15...400Hz
IR145Y-423 INSULATION MONITORING DEVICE DC / AC 0...300V 15...400Hz
IR1570-434 INSULATION MONITORING DEVICE 3AC/AC 0...480V / DC 0...480V
IR1570-435 INSULATION MONITORING DEVICE 3AC/AC 0...480V / DC 0...480V
IR1570W-435 INSULATION MONITORING DEVICE 3AC/AC 0...480V / DC 0...480V
IR1575-434 INSULATION MONITORING DEVICE 3AC/AC 0...480V / DC 0...480V
IR1575-435 INSULATION MONITORING DEVICE 3AC/AC 0...480V / DC 0...480V
IR1575PG1-434 INSULATION MONITORING DEVICE 3AC/AC 20...480V / DC20...480V
IR1575PG1-435 INSULATION MONITORING DEVICE 3AC/AC 20...480V / DC20...480V
IR1575PG1W-435 INSULATION MONITORING DEVICE 3AC/AC 20...480V / DC20...480V
IR420-D4-1 INSULATION MONITORING DEVICE AC 42...460 Hz 0...300 V
IR420-D4-2 INSULATION MONITORING DEVICE AC 42...460 Hz 0...300 V
IR420-D6-1 INSULATION MONITORING DEVICE AC 42...460 Hz 0...300 V
IR420-D6-2 INSULATION MONITORING DEVICE AC 42...460 Hz 0...300 V
IR423-D4-2W INSULATION MONITORING DEVICE 3AC/AC 0...300V / DC 0...300V
IR425-D4-1 INSULATION MONITORING DEVICE AC/DC 0...300 V 15...460 Hz
IR425-D4-2 INSULATION MONITORING DEVICE AC/DC 0...300 V 15...460 Hz
IR450R-4 INSULATION MONITORING DEVICE AC 0...276V 45...420Hz
IR450RT-4 INSULATION MONITORING DEVICE AC 0...276V 45...420Hz
IR450Y-4921 INSULATION MONITORING DEVICE AC 0...276V 45...420Hz
IR457R-4 INSULATION MONITORING DEVICE AC 0... 35V 45...420Hz
IR470LY2-40 INSULATION MONITORING DEVICE AC 0...575V 50...400Hz
IR470LY2-4061 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LY2-409 INSULATION MONITORING DEVICE AC 0...575V 50...400Hz
IR470LY2-60 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY2-6012 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY2-6013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY2-6015 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY2-6021 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY2T-6013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-40 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-40 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LY-4011 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4012 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4015 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4016 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4017 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4018 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4021 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4023 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LY-4090 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYRB-40 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LYRB-4015 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LYRB-4016 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LYRB-4021 INSULATION MONITORING DEVICE AC/3(N)AC 0...793V 50...400Hz
IR470LYT2-6021 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-40 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4015 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4018 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4021 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4090 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYT-4091 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYTRB-4013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYW-40 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYW-4013 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYW-4018 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR470LYW-4021 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR474LY-421 INSULATION MONITORING DEVICE AC 0-690V 15-400Hz / DC 0-400V
IR474LY-4921 INSULATION MONITORING DEVICE AC 0-690V 15-400Hz / DC 0-400V
IR475LY-4 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-413 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-415 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-416 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-417 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-418 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-421 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-423 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LY-P49213 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYRB-4 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-4 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-413 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-421 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-423 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-429 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYT-4921 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR475LYTRB-413 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...480V
IR478LY-4 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IR478LY-416 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IRDH265-3 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH265-322 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH265-323 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH265-4 INSULATION MONITORING DEVICE 3AC/AC 0...690V / DC 0...500V
IRDH275-415 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275-4227 INSULATION MONITORING DEVICE 3AC/AC 0...150V / DC 0...150V
IRDH275-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275-49327 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275-49335DB INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275B-4227 INSULATION MONITORING DEVICE 3AC/AC 0...150V / DC 0...150V
IRDH275B-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275B-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275B-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275BM-727 INSULATION MONITORING DEVICE AGH675S-7
IRDH275B-R427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275B-R435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275BU-627 INSULATION MONITORING DEVICE AGH575S-6
IRDH275BU-635 INSULATION MONITORING DEVICE AGH575S-6
IRDH275BW-4135 INSULATION MONITORING DEVICE 3AC/AC 0...70V / DC 0...70V
IRDH275BW-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275BW-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275BW-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275U-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275W-4227 INSULATION MONITORING DEVICE 3AC/AC 0...150V / DC 0...150V
IRDH275W-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275W-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH275W-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH365-3 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH365-322 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH365-323 INSULATION MONITORING DEVICE 3AC/AC 0...440V / DC 0...220V
IRDH365-4 INSULATION MONITORING DEVICE 3AC/AC 0...690V / DC 0...500V
IRDH375-415 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375-4227 INSULATION MONITORING DEVICE 3AC/AC 0...150V / DC 0...150V
IRDH375-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375B-415 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375B-4227 INSULATION MONITORING DEVICE 3AC/AC 0...150V / DC 0...150V
IRDH375B-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375B-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375B-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375BW-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375BW-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375W-425 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375W-427 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH375W-435 INSULATION MONITORING DEVICE 3AC/AC 0...793V / DC 0...650V
IRDH575B1-4227 INSULATION MONITORING DEVICE 3AC/AC 20...150V/DC 20...150V
IRDH575B1-4235 INSULATION MONITORING DEVICE 3AC/AC 20...150V/DC 20...150V
IRDH575B1-425 INSULATION MONITORING DEVICE 3AC/AC 20...575V/DC 20...575V
IRDH575B1-427 INSULATION MONITORING DEVICE 3AC/AC 20...575V/DC 20...575V
IRDH575B1-435 INSULATION MONITORING DEVICE 3AC/AC 20...575V/DC 20...575V
IRDH575B1W-4227 INSULATION MONITORING DEVICE 3AC/AC 20...150V/DC 20...150V
IRDH575B1W-4235 INSULATION MONITORING DEVICE 3AC/AC 20...150V/DC 20...150V
IRDH575B1W-435 INSULATION MONITORING DEVICE 3AC/AC 20...575V/DC 20...575V
IRDH575B2-435 INSULATION MONITORING DEVICE 3AC/AC340...760V/DC 340...575V
IRDH575B2W-435 INSULATION MONITORING DEVICE 3AC/AC340...760V/DC 340...575V
IREH470Y2-6 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
IREH470Y2-613 INSULATION MONITORING DEVICE AC 0...793V 50...400Hz
