̨ÍåïÈÊMOUJEN½Å̤¿ª¹ØMFS-1011-1£¬MFS-1021-1
MINIATUREСÐÍ
MFS-1011-1 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/1M 1A1B (1CO) 1kg ABS PLASTIC
ABS ËÜÄz
MFS-1011-2 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/2M 1A1B (1CO) 1kg ABS PLASTIC
ABS ËÜÄz
MINIATURE WITH LOCK СÐ͸½¹Ì¶¨Æ¬
MFS-1012-1 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/1M 1A1B (1CO) 1kg ABS PLASTIC
ABS ËÜÄz
MFS-1012-2 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/2M 1A1B (1CO) 1kg ABS PLASTIC
ABS ËÜÄz
MEDIAN TYPE ˜ËœÊÐÍ
MFS-1021-1 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/1M 1A1B (1CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1021-2 10A 250VAC MV-300A20 x 1PC 0.75mm2 , 3C/2M 1A1B (1CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1022-1 10A 250VAC MV-300A20 x 2PC 0.75mm2 , 6C/1M 2A2B (2CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1022-2 10A 250VAC MV-300A20 x 2PC 0.75mm2 , 6C/2M 2A2B (2CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1031-1 15A 250VAC MJ2-1704 x 1PC 0.75mm2 , 3C/1M 1A1B (1CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1031-2 15A 250VAC MJ2-1704 x 1PC 0.75mm2 , 3C/2M 1A1B (1CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1032-1 15A 250VAC MJ2-1704 x 2PC 0.75mm2 , 6C/1M 2A2B (2CO) 3kg ALUMIAUM CASTING äXºÏ½ð
MFS-1032-2 15A 250VAC MJ2-1704 x 2PC 0.75mm2 , 6C/2M 2A2B (2CO) 3kg ALUMIAUM CASTING äXºÏ½ð
