Main Features
- 17" SXGA TFT LCD with touchscreen
- Front panel is NEMA4/IP65 compliant
- Control box with gull-wing design for easy installation and maintenance
- Flat-sealed front panel
- Front USB access and system reset function
- Supports 2 x 2.5" SATA HDDs and RAID 0/1 compatibility
- Dual Gigabit Ethernet with Intel vPro technology
- Offers two expansion slots for PCI add-on cards
- Intel® Core 8482;2 Quad CPU (up to 2.8 GHz) / Core 8482;2 Duo CPU (up to 3.0 GHz)
- System memory supports dual channel DDR3 SDRAM up to 4GB
IPPC-6172A is an Industrial Panel PC with front USB access, supports the powerful Intel Core 2 Quad/Core 2 Duo, high speed DDR3 memory, two expansion PCI slots and slim type DVD-RW. The processor and chipset combination form the foundation of vPro, Intel¡¯s next generation digital office platform, offering remote out-of-band manageability, improved security, and energy efficient performance. Two SATA hard drive interfaces with RAID 0,1 support provides data security. The flat-sealed front panel design also allows easier cleaning and liquid run off. Also the control box has a gull-wing design for easy component installation and maintenance.
²úÆ·ÃèÊö |
IPPC-6172A-R1AE |
17" SXGA IPPC C2Q,C2D 2PCIs w/ TS |
