²úÆ·Ãû³Æ£º
PCI-1711U
ÐÍ ºÅ£º
PCI-1711U
Main Features
- 16-ch single-ended analog input
- 12-bit A/D converter, with up to 100 kHz sampling rate
- Programmable gain
- Automatic channel/gain scanning
- Onboard FIFO memory (1,024 samples)
- Two 12-bit analog output channels
- 16-ch digital input and 16-ch digital output
- Onboard programmable counter
PCI-1711U and PCI-1711UL are powerful, but low-cost multifunction cards for the PCI bus. PCI-1711U comes with 2 analog output channels, while the PCI-1711UL doesn¡¯t. Thus, PCI-1711UL represents a cost saver for those that do not need analog output.
