Main Features
- 16-ch single-ended analog input
- 12-bit A/D converter, with up to 100 kHz sampling rate
- Programmable gain
- Automatic channel/gain scanning
- Onboard FIFO memory (1,024 samples)
- 16-ch digital input and 16-ch digital output
- Onboard programmable counter
PCI-1711U and PCI-1711UL are powerful, but low-cost multifunction cards for the PCI bus. PCI-1711U comes with 2 analog output channels, while the PCI-1711UL doesn¡¯t. Thus, PCI-1711UL represents a cost saver for those that do not need analog output.
²úÆ·ÃèÊö |
PCI-1711UL-CE |
100k, 12bit Low-cost Multi Uni PCI Card w/o AO |
