¸½¼þ
| ²úÆ·ÃèÊö | ||
| PCL-10120-1E | IDC-20 pin socket connector with flat cable | |
| PCL-10120-2E | IDC-20 pin socket connector with flat cable | |
| PCL-10137-1E | DB-37 connector with double-shielded cable | |
| PCL-10137-2E | DB-37 connector with double-shielded cable | |
| PCL-10137-3E | DB-37 connector with double-shielded cable | |
| PCLD-8115-AE | Industrial Wiring Terminal Board with CJC Circuit | |
| PCLD-880-AE | Wiring Terminal Board with Flat Cables and Adapter | |
