²úÆ·Ãû³Æ£º
PCIE-1744
ÐÍ ºÅ£º
PCIE-1744
Main Features
- 4 single-ended analog input channels
- 12-bit A/D converter, with up to 30 MHz sampling rate
- Programmable gain
- Onboard FIFO memory (32,768 samples, each channel)
- 4 A/D converters simultaneously sampling
- Multiple A/D triggering modes
- Programmable pacer/counter
- BoardID8482; switch
- PCI Express V1.0
PCIE-1744 is an advanced high-performance data acquisition card based on the PCI Express bus. With a large FIFO of 32k for each channel, the maximum sampling rate can get up to 30 MS/s, on each channel, with an emphasis on continuous, non-stop, high-speed, streaming data of samples to host memory.
