Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ³¬Éù²¨ÒºÎ»¼ÆSono Tracker
²úÆ·Ãû³Æ£º ³¬Éù²¨ÒºÎ»¼ÆSono Tracker
ÐÍ ºÅ£º Sono Tracker
ÃÀ¹úƽµÏ¿­ÌØBindicator³¬Éù²¨ÒºÎ»¼ÆSono Tracker
Ô­Àí£º¸ù¾Ý̽ͷ·¢Éä½ÓÊÕÉù²¨µÄʱ¼ä²îÀ´²âËã¾àÀ룬¼Ì¶ø×ª»»³ÉÎïλ
ÌØµã£º¼¼Êõ³ÉÊ죬
      °²×°¼òµ¥²Ù×÷±ã½Ý
      ÊÊÓ÷¶Î§¹ã
ÐͺÅÈçÏ£ºSON-A-A-Y-A-A-A  SON-B-A-Y-A-AA SON-C-A-A-Y-A-AA  SON-C-A-B-Y-K-A
¿ìËÙÅäÖÃ
²Ëµ¥Çý¶¯µÄ¿ìËÙ³ÉÁ¢£¬ÔÚ²»µ½5·ÖÖÓ
Ä£¿é»¯Éè¼Æ ¿ÉÅäÖõĴ«¸ÐÆ÷£¬¼ÌµçÆ÷£¬
µçѹ£º
110/230 VAC (+/- 10%), 50/60 Hz or 24 VDC 110/230 VAC£¨+ / - 10£¥£©£¬50/60 Hz»ò24 VDC
Power requirement:20 VAEnvironmental:»·¾³£º
Operating Temperature: ¹¤×÷ζȣº
-5¡ã to 122¡ã F (-20¡ã to 50¡ã C) -5¡ãµ½122¡ãF£¨-20¡ãÖÁ50¡ãC¼ä£©
Storage Temperature: ´æ´¢Î¶ȣº
-22¡ã to 140¡ã F (-30¡ã to 60¡ã C)Humidity: 1% to 95% -22¡ãµ½140»ªÊ϶ȣ¨-30¡ãÖÁ60¡ãC£©Êª¶È£º1£¥ÖÁ95£¥
(non-condensing) £¨·ÇÀäÄý£©
Enclosures: ¸½¼þ£º
NEMA 4X fiberglass reinforced polyester (FRP) with 24-key, ·ûºÏNEMA 4X²£Á§ÏËάÔöÇ¿¾Ûõ¥£¨FRP£©£¬24¼ü sealed elastomer keypad or NEMA 4X stainless steel. ÃÜ·âÏ𽺰´¼ü»òNEMA 4X²»Ðâ¸Ö¡£
SonoTracker™ has NEMA 4X compression molded SonoTracker™·ûºÏNEMA 4Xģѹ fiberglass, reinforced polyester and a silicon door gasket. ²£Á§ÏËάÔöÇ¿¾Ûõ¥ºÍ¹èÃÅ·âÌõ¡£
Features and Benefits ÌØµãºÍÓŵã Versatile
The transducers are designed´«¸ÐÆ÷Éè¼Æ
for your specific application¾ßÌåÓ¦ÓÃand environment.ºÍ»·¾³¡£ Available in ¿ÉÔÚ
frequencies of 14kHz, 22kHz, 14KHZ£¬22kHzµÄƵÂÊ£¬ 24 kHz and 43kHz to fit a 24 kHzºÍ43kHz£¬ÒÔÊÊÓ¦ variety of materials and ¶àÖÖ²ÄÁÏ£¬²¢
distances. Our transducers have anÎÒÃǵĴ«¸ÐÆ÷ÓÐaccuracy of 1% of rated span¶î¶¨Á¿³ÌµÄ1£¥µÄ¾«¶È
in approved bulk solidsÔÚÅú×¼µÄÉ¢×°¹ÌÌå applications and 0.25% ofÓ¦ÓúÍ0.25£¥ rated span in approved liquid ¶î¶¨¿ç¶ÈÔÚÅú×¼µÄÒºÌåapplications.Ó¦Óá£
The range of sensors allows you to read levels from 1 foot to beyond 100 feet in solids. ¸÷ÖÖ¸÷ÑùµÄ´«¸ÐÆ÷£¬¿ÉÒÔÈÃÄã´Ó1Ó¢³ßµ½³¬¹ý100Ó¢³ß¡£ The ¡°
BT-55 transducer has an extremely narrow beam angle, allowing it to be used in challenging BT-55´«¸ÐÆ÷ÓÐÒ»¸ö¼«ÆäÏÁÕ­µÄ¹âÊø½Ç£¬ÔÊÐíËü±»ÓÃÓÚÔÚ³äÂúÌôÕ½
applications. Ó¦ÓᣠAdditionally, the same unit does open channel flow and differential level measurements.¡£
Description ÃèÊö
BT-26 CPVC Sensor BT-26 CPVCµÄ´«¸ÐÆ÷
BT-26 CPVC Sensor with TC BT-26µÄCPVC´«¸ÐÆ÷ÓëTC
BT-26 Stainless Steel Sensor BT-26²»Ðâ¸Ö´«¸ÐÆ÷
BT-26 Stainless Steel Sensor with TC BT-26ÓëTC²»Ðâ¸Ö´«¸ÐÆ÷
BT-55 CPVC Sensor BT-55 CPVCµÄ´«¸ÐÆ÷
BT-61 CPVC Sensor with TC BT-61µÄCPVC´«¸ÐÆ÷ÓëTC
BT-61 CPVC Sensor BT-61 CPVCµÄ´«¸ÐÆ÷
BT-101 CPVC Sensor with TC BT-101 CPVCµÄ´«¸ÐÆ÷ÓëTC
BT-101 CPVC Sensor BT-101 CPVCµÄ´«¸ÐÆ÷
¹«Ë¾Ãû³Æ£º ÉϺ£ÖÙÊ¥×Ô¶¯»¯¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 60830448-808 / ºÎ±¾¸Õ
ÊÖ»ú£º 13524919661
µØ Ö·£º ÉϺ£ãÉÐÐÆÖÌη505Ū6ºÅ804ÊÒ
ÓÊ ±à£º 201112
Ö÷ Ò³£º http://www.nohken1718.com
  • TC1-SÃÀ¹úKistler-Morse³ÆÖØ´«¸ÐÆ÷
  • LD360s™Ñ¹Ëõ³ÆÖØ´«¸ÐÆ÷ÃÀ¹úÃÀ¹úKM
  • ÃÀ¹úKistler-MorseÐźŴ¦ÀíÆ÷STXplus
  • KM³¬Éù²¨´«¸ÐÆ÷SCºÍUCϵÁÐ
  • ÃÀ¹úKM³ÆÖØÏÔʾÒÇSVS2000
  • WEIGH II³ÆÖØÏÔʾÒÇ£¨ÃÀ¹úKM
  • LD II/LD3ÃÀ¹úKM½ô´ÕÐͳÆÖØ´«¸ÐÆ÷
  • ÃÀ¹úKM³ÆÖØ´«¸ÐÆ÷Load Stands
  • L-CellÃÀ¹úKMÌùƬʽ³ÆÖØ´«¸ÐÆ÷
  • ÃÀ¹úKMÌùƬʽ³ÆÖØ´«¸ÐÆ÷Microcell
