²úÆ·Ãû³Æ£º LV-67J
ÐÍ ºÅ£º LV-67J
Æ· ÅÆ£º 735
Specification
Form Factor
Mini-ITX Motherboard
Processor
3rd and 2nd Generation Intel® Core™ i7/ i5/ i3/Celeron® Desktop Processor.
Package Type: FCLGA1155
Memory
2 x DDR3 1066/1333 SO-DIMM up to 16 GB
Chipset
Intel® BD82Q77 PCH
Integrated Graphics
Intel® Core™ integrated HD Graphics Technology
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset with internal timer for 1min/s ~ 255min/s
Power Management
ACPI 1.0 compliant, supports power saving mode
Serial ATA Interface
Intel® Q77 PCH built-in 2 x Serial ATAII interface up to 300MB/s
& 2 x Serial ATAIII interface up to 600MB/s
Support RAID 0, 1, 5, 10 and Intel Rapid Storage Technology.
VGA Interface
Onboard DSUB15 connector for VGA interface
DVI Interface Onboard 20-pin DVI interface
Audio Interface
Realtek ALC888 HD Audio
LAN Interface
1 x Intel® 82574L Gigabit Ethernet Controller
1 x Intel® 82579LM Gigabit Ethernet Controller
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extended Interface
1 x PCIE X 16 Gen3 slot‚ 1 x Mini PCI socket,1 x PCIE Mini card
Support mSATA or Mini_Card for option
Internal I/O Port
1 x RS232/422/485, 1 x GPIO port, 1 x CDIN connector,1 x Audio
connector, 1 x IrDA connector, 1 x SMBUS connector and
4 x USB 2.0 ports.
External I/O Port
1 x PS/2 Keyboard/Mouse Port, 2 x RJ45 LAN ports, 1 x DB15
VGA port, 4 x USB3.0 ports and 3 x Serial Port.
External Audio
Line-in, MIC-in, Front, Rear, Center/Subwoofer and Optical SPDIF
outputs.
Power Requirement
Standard 24-pin ATX power supply (20-pin is compatible) and
P4 4-pin 12V
Board Dimension
170 mm x 170 mm (L x W)
Temperature
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
