²úÆ·¹æ¸ñ£º
ÏÔʾÆ÷: 10.4" TFT LCD
´¦ÀíÆ÷: 32λ RISC CPU 200MHz
ÄÚ´æ:4MB DRAM, 2MB flash memory
I/O:´®Ðвº:¡¡ RS-232 port x 1(Á¬½ÓPC»ò¸½Êô×°ÖÃ)
RS-232/485 port x 1 (Á¬½ÓPLC)
RTC & Åä·½¿¨:ÄÚ½¨(Åä·½¿¨ 128kB)
×ÔÎÒÕï¶Ï:µçÔ´Òì³£Õì²â
ÊäÈëµçѹ:21-25 VDC
µçÔ´µç×è:500VAC (1 min.)
¾øÔµµç×è:Exceed 50M¦¸ at 500VDC
ÏûºÄµçÁ÷:430 mA @ 24VDC
CE:·ûºÏ EN50081-2 ¼° EN50082-2 ±ê×¼
FCC:·ûºÏ FCC µÈ¼¶A
ÈË»ú³ß´ç HxWxD:315x238x62mm
¿ª¿×³ß´ç:302 x 225 mm
ÖØÁ¿:Approx.2.0 kg
¹¦ÄÜÌØµã£º
10.4" TFT LCD
32λ RISC CPU 200MHz
ÏÔʾÆ÷: ÏÔʾÆ÷ÀàÐÍ
TFT²ÊɫҺ¾§ÏÔʾÆ÷
ÏÔʾÆ÷³ß´ç(diagonal) 10.4"
É«²Ê 256 É«
·Ö±æÂÊ 640 x 480
ÁÁ¶È (cd/m2) 400
±³¹â CCFLx2
¶Ô±È 300:1
´¥¿Ø°å:
´¥¿ØÃæ°å:4 Ïßµç×èʽ
´¥¿Ø¾«È·¶È:2mm
±íÃæÓ²¶È:4H
»·¾³¹æ¸ñ:
ÄÍÕð¶È:10 to 25 Hz (X,Y,Z ·½Ïò 2G / 30minutes)
±£»¤µÈ¼¶:IP65 Ãæ°æ (·ÀË®OÐÍ»·³Äµæ)
¹¤×÷ζÈ:0~45¡£C
¹¤×÷ʪ¶È:10-90% RH (²»½á¶)
