Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Autonics°ÂÍÐÄá¿Ë˹ζȿØÖÆÆ÷TZN4H-14C
²úÆ·Ãû³Æ£º Autonics°ÂÍÐÄá¿Ë˹ζȿØÖÆÆ÷TZN4H-14C
ÐÍ ºÅ£º TZN4H-14C
TZ4M-14R,14C,14S  TZ4M-24R,24C,24S  TZ4M-R4R,R4C,R4S  TZ4M-A4R,A4C,A4S
TZ4M-T4R,T4C,T4S  TZ4M-B4R,B4C,B4S
ÍâÐγߴç;[W72*H72*L113mm]
¹¦ÄÜ;¶àÖÖ´«¸ÐÆ÷ÊäÈ빦ÄÜ:13ÖÖÊäÈ뷽ʽ
     Ë«ÖØPID¹¦ÄÜ; PIDF (¸ßËÙ¿ØÖÆ)»òPIDS(ÂýËÙ¿ØÖÆ) ¿ÉÑ¡
     ¶àÖÖÊä³ö¹¦ÄÜ: Relay, SSR
     4---20mADCµçÔ´Êä³ö(for control) ,4----20mADC´«ËÍÊä³ö(PV) SUB Êä³ö;EVENT1,EVENT2
µçÔ´:100-240VAC 50/60HZ
ÏÔʾÀàÐÍ;7¶Î LEDÏÔʾ(¹ý³ÌÖµ;ºìÉ«  É趨ֵ:ÂÌÉ«)
TZN4H-14R,14C,14S TZN4H-24R,24C,24S TZN4H-R4R,R4C,R4S TZN4H-A4R,A4C,A4S
TZN4H-T4R,T4C,T4S  TZN4H-B4R,B4C,B4S
ÍâÐγߴç;[W48*H96*L90mm]
µçÔ´µçѹ;100 TO 240VAC  50/60HZ
ÏÔʾÀàÐÍ:7¶ÎLEDÏÔʾ(PV:ºìÉ«  SV:ÂÌÉ«)
TZN4W-14R,14C,14S TZN4W-24R,24C,24S TZN4W-R4R,R4C,R4S TZN4W-A4R,A4C,A4S
TZN4W-T4R,T4C,T4S TZN4W-B4R,B4C,B4S
ÍâÐγߴç;[W96*H48*L90mm]
TZN4S-14R,14C,14S
ÍâÐγߴç;[W48*H48*L90mm]
µçÔ´µçѹ; 100 TO 240VAC  50/60HZ
TZN4M-14R,14C,14S  TZN4M-24R,24C,24S TZN4M-R4R,R4C,R4S TZN4M-A4R,A4C,A4S
TZN4M-T4R,T4C,T4S  TZN4M-B4R,B4C,B4S
ÍâÐγߴç;[W72*H72*L85mm]
TZN4L-14R,14C,14S TZN4L-24R,24C,24S TZN4L-R4R,R4C,R4S TZN4L-A4R,A4C,A4S
TZN4L-T4R,T4C,T4S TZN4L-B4R,B4C,B4S
ÍâÐγߴç;[W96*H96*L90mm]
TZ4H-14R,14C,14S TZ4H-24R,24C,24S TZ4H-R4R,R4C,R4S TZ4H-A4R,A4C,A4S
TZ4H-T4R,T4C,T4S TZ4H-B4R,B4C,B4S
ÍâÐγߴç;[W48*H96*L100mm]
µçÔ´µçѹ;100—240VAC  50/60HZ
ÏÔʾÀàÐÍ;7¶ÎLEDÏÔʾ[¹ý³ÌÖµ:ºìÉ«  É趨ֵ:ÂÌÉ«]
TZ4W-14R,14C,14S TZ4W-24R,24C,24S TZ4W-R4R,R4C,R4S TZ4W-A4R,A4C,A4S
TZ4W-T4R,T4C,T4S TZ4W-B4R,B4C,B4S
ÍâÐγߴç:[W96*H48*L100mm]
TZ4L-14R,14C,14S TZ4L-24R,24C,24S TZ4L-R4R,R4C,R4S TZ4L-A4R,A4C,A4S
TZ4L-T4R,T4C,T4S  TZ4L-B4R,B4C,B4S
ÍâÐγߴç;[W96*H96*L100mm]
µçÔ´µçѹ; 100—240VAC  50/60HZ
TB42-14R,14C,14S,14N  ÍâÐγߴç:[ÏÔÊ¾Ãæ°å;W60*H60mm]  [¿ØÖÆÃæ°å:W65*H78mm]
ÌØÕ÷:¸ßÐÔÄÜ,Ê¡µç
¸ù¾ÝÓû§ÏëÒª°²×°Áé»î·½±ã
ÏÔÊ¾Ãæ°å¿É°´Óû§ÒªÇó±ä¸ü
         (ÔÊÐí¹¤×÷µçѹ:90 TO 110%)
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
