CARLO GAVAZZIÈðÊ¿¼ÑÀ̵ּçÆ÷RCP11003230VAC
ÌØÕ÷£ºÄÚÖûº³åÆ÷£¬×Ô´øÉ¢ÈÈÆ¬°ëµ¼Ì忪¹ØÔª¼þ£¬ÊʺÏ45-65HZ£¬¹¤Æµµç·£¬¶î¶¨¾øÔµµçѹ´óÓÚµÈÓÚ400VMS
¿ØÖƵçѹ·¶Î§£º4.25-36VDC
×î´óÊäÈëµçÁ÷£º12MA
Êä³ö¹æ¸ñ£º2A£¬50A£¬75A£¬100A
×îС¹¤×÷µçÁ÷£º350MAMS
¹¦ÂÊÒòÊý£º´óÓÚµÈÓÚ0.5
¹¤×÷ζȣº30ÖÁ80¶È
¶Ë×Ó£º½ÓÏß¶Ë×Ó
ÈÏÖ¤/±ê×¼£ºCE-UL-CSA
RCP11003110VDC Undecal relay 3CO contacts DC coil
RCP11003110VDC/4 Undecal relay 3CO contacts DC coil
RCP11003110VDC/5 Undecal relay 3CO contacts DC coil
RCP11003110VDC/6 Undecal relay 3CO contacts DC coil
RCP11003120VAC Undecal relay 3CO contacts AC coil
RCP11003120VAC/4 Undecal relay 3CO contacts AC coil
RCP11003120VAC/5 Undecal relay 3CO contacts AC coil
RCP1100312VAC Undecal relay 3CO contacts AC coil
RCP1100312VAC/4 Undecal relay 3CO contacts AC coil
RCP1100312VAC/5 Undecal relay 3CO contacts AC coil
RCP1100312VDC Undecal relay 3CO contacts DC coil
RCP1100312VDC/4 Undecal relay 3CO contacts DC coil
RCP1100312VDC/5 Undecal relay 3CO contacts DC coil
RCP1100312VDC/6 Undecal relay 3CO contacts DC coil
RCP11003240VAC Undecal relay 3CO contacts AC coil
RCP11003240VAC/4 Undecal relay 3CO contacts AC coil
RCP11003240VAC/5 Undecal relay 3CO contacts AC coil
RCP1100324VAC Undecal relay 3CO contacts AC coil
RCP1100324VAC/4 Undecal relay 3CO contacts AC coil
RCP1100324VAC/5 Undecal relay 3CO contacts AC coil
RCP1100324VDC Undecal relay 3CO contacts DC coil
RCP1100324VDC/4 Undecal relay 3CO contacts DC coil
RCP1100324VDC/5 Undecal relay 3CO contacts DC coil
RCP1100324VDC/6 Undecal relay 3CO contacts DC coil
RCP1100348VAC Undecal relay 3CO contacts AC coil
RCP1100348VAC/4 Undecal relay 3CO contacts AC coil
RCP1100348VAC/5 Undecal relay 3CO contacts AC coil
RCP1100348VDC Undecal relay 3CO contacts DC coil
RCP1100348VDC/4 Undecal relay 3CO contacts DC coil
RCP1100348VDC/5 Undecal relay 3CO contacts DC coil
RCP1100348VDC/6 Undecal relay 3CO contacts DC coil
RCP1100360VDC Undecal relay 3CO contacts DC coil
RCP1100360VDC/4 Undecal relay 3CO contacts DC coil
RCP1100360VDC/5 Undecal relay 3CO contacts DC coil
RCP1100360VDC/6 Undecal relay 3CO contacts DC coil
