CrydomÃÀ¹ú¿ì´ï¹Ì̬¼ÌµçÆ÷H12WD4890PG
Ratings from 25A to 125A @ 48-660 V AC
SCR output for heavy industrial loads
DC control
Zero-crossing (resistive loads) or random-fire (inductive loads) output
¿ì´ï¹Ì̬¼ÌµçÆ÷¡¢Ð¡±£»¤ÕÖKS300
´ó±£»¤ÕÖKS100¡¢660V84137120¡¢DC60S7¡¢D53TP25D-10¡¢XBP4025C/3.5-15V¡¢XBPE4025C/15-32V¡¢XBP4050C/3.5-15V¡¢XBPE4050C/15-32V¡¢XBPE4825C¡¢XBPE4850C
XBPE6060C¡¢CWD4850P¡¢H12WD4850PG¡¢H12WD4890PG¡¢H12WD48125PG¡¢MCPC2450D¡¢XBPW4050C/4-32V¡¢XBPW6060/4-32
H12WD48125, 4-32 VDC, 125 Amps, 48-660 VAC
H12WD48125-10, 4-32 VDC, 125 Amps, 48-660 VAC
H12WD4825, 4-32 VDC, 25 Amps, 48-660 VAC
H12WD4825-10, 4-32 VDC, 25 Amps, 48-660 VAC
H12WD4850, 4-32 VDC, 50 Amps, 48-660 VAC
H12WD4850-10, 4-32 VDC, 50 Amps, 48-660 VAC
H12WD4875, 4-32 VDC, 75 Amps, 48-660 VAC
H12WD4875-10, 4-32 VDC, 75 Amps, 48-660 VAC
H12WD4890, 4-32 VDC, 90 Amps, 48-660 VAC
H12WD4890-10, 4-32 VDC, 90 Amps, 48-660 VAC
H12WD4825PG, H12WD4850PG, H12WD4890PG,
H12WD4825P, H12WD4850P,
H12WD4825, H12WD4850,
H12WD485OPG, H12WD489OPG,
H12WD485OP,H12WD485O
