AUTOINCSº«¹ú°ÂÍÐÄá¿Ë˹ԤÉèÐͼÆÊý/¼ÆÊ±Æ÷FX5S-I
* ¼ÆÊýËÙ¶ÈÉý¼¶ : 1cps/30cps/2kcps/5kcps
* ¿ÉÑ¡µçѹÊäÈë(PNP) »òÎÞµçѹÊäÈë(NPN)
* ¼ÓÈë Up/Down ¼ÆÊýģʽ
* ¿ÉÒÔÉ趨СÊýµã(¹Ì¶¨Ð¡ÊýµãÏÔʾ)
* ¿íµçÔ´ÊäÈëʹÓ÷¶Î§ :100-240VAC 50/60Hz, 12-24VAC/DC(¿ÉÑ¡)
* ͨ¹ýÄÚ²¿DIP¿ª¹Ø¿ÉÑ¡Ôñ¼ÆÊýÆ÷/¼ÆÊ±Æ÷ģʽ
* ¶àÖÖʱ¼ä·¶Î§Ñ¡Ôñ
* ÄÚÖÃ΢´¦ÀíÆ÷
LCD¼ÆÊýÆ÷ LA7N-1£¬2£¬3£¬4 W48XH24mm LA7N-1R.2R.3R.4R LA7N-F.FR
ÊýÏÔ¼ÆÊýÆ÷ FS5B W48XH48mm 100~240VDC 12-24VDC INPUT NPN FS4A
ÊýÏÔ¼ÆÊ±/¼ÆÊýÆ÷ FX4Y-I W72XH36mm 100~240VDC 12-24VDC INPUT NPN.PNP FX6Y-I
FX5S-I W48XH48mm FX4S FX4-I W72XH72mm FX6-I FX4 FX6
FX4-2P FX6-2P FX4H-I W48XH96mm FX4H FX4H-2P
FX4L-I W144XH72mm FX6L-I FX4L-2P
FX6L-2P CT4S W48XH48mm CT4S-2P CT6S-I CT6S CT6S-2P
CT6-1 W72XH72mm 100~240VDC 24-80VDC CT6 CT6-2P
Ô¤Ëã¼ÆÊýÆ÷ F4BM W72XH72mm 110/220VAC INPUT PNP
F6BM F4AM F6AM F4AM-2P 100~240VAC F6AM-2P L4BM W144XH72mm 110/220VAC
L6BM L4AM-2P 100~240VAC L6AM-2P
Ä£Äâ¼ÆÊ±Æ÷ AT8A W48XH48mm 24.48VAC 110/220VAC 12.24.48.100VDC
AT8B AT11D W48XH46mm AT11E AT8SD W48XH48mm 110/220VAC 12.24.48.100VDC 5.10.50.100SEC
AT8PS "0.5,10,1,5SEC" AT8PM "0.5,1,5,10MIN"
ATE 110/220VAC 12.24VDC "1S,3S,6S,10S,30S,60S,3M,6M,10M,30M,60M,3H,6H,12H,24H" ATE-1£¬2
ÊýÏÔ¼ÆÊ±Æ÷ FS4E W48XH48mm 100~240VAC.12~24VDC FS5EI
LCD¼ÆÊ±Æ÷ LE3S 100~240VAC.24~240VDC LE3SA
LE3SB LE4S 24~240VAC.24~240VDC LE4SA "LE7N-S,M,H,HR" W48XH24mm
"LE7N-SF,MF,HF,HFR" INPUT24~240VAC 6~240VDC LE7D-2 w72Xh72mm 100~240VAC MULTI TYPE
²åÍ· FGB48-BL¡¢GR BRACKET PGB48-W
²å×ù PG-08 8PIN SOCKET PG-11 11PIN SOCKET PS-08 8PIN SOCKET PS-11 11PIN SOCKET
LCDתËÙ±í LR7N-S1£¬S10 W48XH24mm LR7N-M60 M600
תËÙ±í S5C W48XH48mm 100~240VAC£¬12~24VDC INPUT PNP M5Y-C W72XH36mm M4W-C W96XH48mm
M5W-C F4C w72Xh72mm 110/220VAC F4C-P
תËÙ±í F4C-2P 100~240VAC INPUT PNP F5C w72Xh72mm 110/220VAC F5C-P F5C-2P 100~240VAC
